Question about Tecumseh Horizontal Tiller Engine 8 Hp, 1" X 2 57/64" Shaft, Modelno. Hm80 - 155656x
Replace rod hp snow king Tecumseh
Simpest way to replace rod .Do I need to take off drive side cover
4 Suggested Answers
  • 430 Answers
SOURCE: I have a tecumseh 7 horse (Snow King) motor that
That does not sound like a complete Tecumseh model number.
You have several options... Your first and probably best option would be your local small engine repair shop. They may even have the parts in stock, if not in stock will likely have it in a few days. Or you can look online at places like outdoordistributors.
No matter where you get the part from you will need a complete model and spec and maybe a serial number ( off of the motor itself). Also be aware that since Tecumseh went out of business a few years ago that certain parts are becoming increasingly hard to find.
Posted on Jan 02, 2010
  • 12 Answers
SOURCE: i have a 5 hp tecumseh snow blower, it won't stay
pull the jets out,use a tiny wire to clen out the hole and blow clean with air. should fix it good luck
Posted on Feb 09, 2010
  • 822 Answers
SOURCE: I installed new carb. on my tecumseh 5hp. snow king and it wont start. I have spark and gas is flowing out of carb.
This can be very frustrating and tough on the back and arm.
Always confirm the the fuel tank valve is open and the stop/run switch is in run position
It takes three things to run:
  1. Compression. This is the resistance that you feel as you crank the engine. Some engines have compression release to assist getting the rotation started. You should be able to feel the compression stroke as you rotate, Remove the plug and you can easily tell the deference. If it had, last time used, been running and starting with no problem I would assume that the compression is OK. Gauges are available to check. at lease 120 PSI
  2. Spark. It is near impossible to lose the spark timing on these. It can only be magnitude and presence. If in doubt about the condition of spark plug replace. I usually lay the plug on top of the head with wire attached and observe for the spark. No spark no start.
  3. Confirm that the throttle is in the wide open position. It is possible during the repair the spring or rod has closed the throttle air valve. Air/fuel mixture is always hard to trouble shoot. I use open choke and starter fluid to conform that compression and spark are working. After that I will choke on a cold motor and pull listening for the first fire. At the first fire I would usually half choke and pull to first run. Full choke for many pulls will only flood engine!! If no joy then I would allow engine to vent and go back to start fluid. If it will run on start fluid than either carburetor is messed up or quality of fuel is bad.
If after several tries and fuel is certain to be good remove plug and check for gas. It is possible that the new carb float valve or mixture adjustment screws are messed up.
Posted on Jan 10, 2016
What should the psi be on a compression test for a 5 HP Tecumseh engine??
Anything lower than 90 psi should be a concern. 110 or so should be good
Jan 17, 2016 | Tecumseh 5hp Engine Snow King Mtd Blowers...
Replacing a connecting rod on snowblower engine
That project requires a complete engine disassembly, but it's very probably not worth doing - the broken rod probably did so much damage to the crankcase and crankshaft and piston and cylinder that it'd be far far cheaper just to replace the engine.
Dec 25, 2014 | Tecumseh Snowblower Snow Blower Starter...
5 hp tecumseh no power
you need to remove carb for cleaning... if it has an adjustment on the bottom of carb try turning it SLOWLY in and out... also possibly a screw on the side under a black cap... might try it as well engine model number would help here
Dec 11, 2013 | Tecumseh 5hp Engine Snow King Mtd Blowers...
Craftsman 32" 10 hp
3600+/- 20rpm. That's the top end, I'd say idle should be between 1200 and 1500, but I don't know what model motor it is. I'm assuming its a Tecumseh snow king engine
Nov 22, 2013 | Craftsman Arnold Mtd Snow Thrower Blower...
5 hp tecumseh, late 70's, replacement of points & Condenser
these were cheap at one time but here is the item you need click here one listed on ebay, but i would call your local mower shop first, there easy to install.. hope this helps if so give me a reply.. jay the pool pump guy in longwood fl
Feb 04, 2012 | Tecumseh 5hp Engine Snow King Mtd Blowers...
8 hp tecumsch engine for snow blower oil comes out the side vent tube when running
replace the oil breather filter and make shore you did not over fill the moter with oil
Jan 16, 2011 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
How do you replace the pull start cord on a 5 hp tecumseh snow king engine, I can't find my manual. Pull start cord broke last snow we had.
I recommend contacting your nearest authorized service center, or you can download operators and service manuals typically online by performing a simple Google search using your make, model number and part needed.
I trust this information proves beneficial.
Dec 28, 2009 | Agri-Fab Agri - Fab Snow Blower - 42"
Broken piston connecting rod
The rod is cheap. If you're an experienced handymand/mechanic, it's a medium difficult job. But if the rod damaged the engine when it cam loose, the engine will have to be replaced. Need to tear it down to investigate.
Charlie
Aug 25, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Tecumseh Horizontal Tiller Engine 8 Hp, 1" X 2 57/64" Shaft, Modelno. Hm80 - 155656x Logo
369 people viewed this question
Top Tecumseh Tools & Hardware - Others Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ArcFlash
Level 1 Expert
JonSnell Electronic
JonSnell Electronic
Are you a Tecumseh Tool and Hardware - Other Expert? Answer questions, earn points and help others
