Question about HP Officejet J5780 All-In-One InkJet Printer
Align The Print Cartidges
I cant not align the print cartridges
    Sergeant:
  • 320 Answers
Scanner failure align the cartridge
To Align the new ink cartridge
The HP All-in-One prompts for an alignment of the cartridges every time a print cartridge is installed or replaced. Follow these steps to align the print cartridges from the control panel.
  1. Load unused, plain, white letter, A4, or legal paper into the input tray. note.png
    NOTE:If colored paper is loaded in the input tray when the print cartridges are aligned, the alignment will fail. Load unused, plain, white paper into the input tray, and then try the alignment again.
  2. Press Setup.
  3. Press 6 to select Tools.
  4. Press 2 to select Align Print Cartridge.
    The unit prints a print cartridge alignment sheet.
  5. Load the alignment sheet print-side down and top first in the center of the document feeder tray, and then press OK.
Dec 07, 2014 | HP Officejet 4355 All-In-One InkJet...
Will not copy
This means one of the cartridges is defective, they cant align if they cant print. What i did to fix this problem is insert 2 working cartridges and get it to align properly, even if they are low on ink, then lift the cover and the cartridges will move to the center. When this happens pull the power cable out, then insert the full non functioning cartridge. Plug the power cable back in. I tried this with a color cartridge, the color cartridge was non functioning but i was able to print in black. Basically you align the cartridges and then swap them so the printer thinks they are still aligned. The color still doesnt work and it is probably a defective color cartridge.
Apr 20, 2013 | HP Officejet 7210 All-In-One InkJet...
Vertical lines are not smooth, they are jagged. The lines are straight for about an inch, then they are offset to the left. Some words are broken in half horiziontally with the lower half offset to the...
You can align the print cartridges at any time from the control panel or by using the HP Image Zone software on your computer. Aligning the print cartridges ensures high-quality output.
Note: If you remove and reinstall the same print cartridge, the HP all-in-one will not prompt you to align the print cartridges. The HP all-in-one remembers the alignment values for that print cartridge, so you do not need to realign the print cartridges.
To align the cartridges from the control panel:
  1. Load letter or A4 unused plain white paper into the input tray.
  2. Press Setup.
  3. Press 6, then press 2.
  4. This displays the Tools menu and then selects Align Print Cartridge.
  5. The HP all-in-one prints a print cartridge alignment sheet and aligns the print cartridges.
Feb 16, 2011 | HP OfficeJet 7410 All-In-One InkJet...
How to remove this message "If you have just installed a new print cartridge it is recommended that you align it. Click on "Align" to align your new print cartridge."
it cant be removed unless and untill you complete the preocess just print align test page and put the page in scanner glass and press the scan button to complete.
Have a nice day and do not forget to rate please...!
Jan 29, 2010 | HP OfficeJet 4255 All-In-One InkJet...
Refilled 926 black cartridge but pc does not recognize as full
The electronics on print cartidges are only good for a limited number of refills if any, they then will sometimes not be recognised or report the incorrect amounts, or not properly align....and this goes for aftermarket discount cartidges as well.
Oct 07, 2009 | Office Equipment & Supplies
Have just unpacked new HP Photosmart C4200 All-in-One Cannot get machine to accept cartidges which werre supplied with the printer
NOTE: The product must be on before you can insert the print cartridges.
  1. Open the print cartridge door. Figure 7: Opening the print cartridge door c00880893.jpg
  2. Make sure the print carriage moves to the right. If it does not move to the right, turn the device off, then turn it back on again.
  3. Open the packaging and remove the tape from both cartridges. Figure 8: Removing the tape c00880894.jpg CAUTION: Do not touch the copper-colored contacts or re-tape the cartridges.
  4. Hold the cartridges with the HP logo on top.
  5. Insert tri-color cartridge in the left cartridge slot and the black cartridge in the right cartridge slot . Figure 9: Inserting the print cartridges c00880895.jpgc00880896.jpg
  6. Push the cartridge firmly into the slot until it snaps into place.
  7. Close the print cartridge door.
Step eight: Align the print cartridges When a new print cartridge is installed, the product aligns the cartridge. Align the print cartridges at any other time by using the software installed with the product. Aligning the print cartridges ensures high-quality output. NOTE: If a print cartridge is removed and reinserted, the product will not prompt for an alignment. The product memory retains the alignment values for that print cartridge. Follow these steps to align newly installed print cartridges.
  1. When prompted, make sure that plain, white letter or A4 paper is loaded in the input tray, and then press the button next to OK . The alignment page prints.
  2. Lift the lid. Place the top of the alignment page face-down on the front, right corner of the scanner glass. Figure 10: Placing the alignment page c00880898.jpg
  3. Close the lid.
  4. Press the button next to OK . When the On button stops flashing, the alignment is complete and the page can be removed.
Nov 18, 2008 | HP Computers & Internet
Align cartridges error
Sep 04, 2008 | HP OfficeJet K80 All-In-One InkJet Printer
Printer problems
Re-install your HP driver software
Down load and run HP's Software Cleanup Utility.
Please read the instructions first.
Download here:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00036626&cc=us&lc=en&dlc=en&product=79499&dlc=en&lang=en
Nov 19, 2007 | HP PSC 2210 All-In-One InkJet Printer
HP Officejet J5780 All-In-One InkJet Printer Logo
113 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
