Printer connect i had my printer connected to my tower computer, it died tonight. i would like to connect my printer to my son's toshiba laptop computer. can you tell me what slot do i put the cord from the printer into the laptop. as you can tell i need help
  • 741 Answers
There are two types of slots USB and Parallel ports. You probably have a USB, it should be a small rectangular head, with no holes or pins. You will find a matching slot on the side of the laptop. But that's not the last step as you have to run the disc that came with the printer to install it on the laptop. You will not be able to use the printer until that is done, unless it was added at an earlier date. If you have any questions let me know.
Before logging out pleae rate this solution with 4 stars.
Posted on Feb 02, 2009
Dell HP Pavilion screen scrambled
Either your monitor died or your video card/chip died. Test your tower with a different monitor or test your monitor with a different tower.
Aug 25, 2012 | HEWLETT-PACKARD Hewlett Packard HP...
Im trying to set up wired computer desktop to share my new s605 to my sons laptop wireless...do i need to use the CD enclosed with the printer and put it in my sons laptop to install the printer on his...
Yes you need to setup the printer as a shared printer using the printer driver CD.
Your shared printer and computer would need to be on your LAN and connected to a wireless router. The laptop will connect to the shares printer via the wireless router and LAN cable to the computer with the shared printer.
Please click on this link and follow my instructions to setup the shared printer.
http://www.fixya.com/support/r3668797-setting_up_shared_network_printer
Jun 03, 2011 | Lexmark Interact S605 All-in-One Color...
Just installed a TP-Link TL-WR940N router. IBM and Dell laptops connect fine. My son's Toshiba Satillite will not?
check to see if you inserted router name and WEP password correctly in your son's computer. I'm thinking you were tired when you got to your son's puter.
regards,
Digital Denizen
rate us and ask another question if it doesn't work
Nov 27, 2010 | Toshiba Satellite A215-S4747 Notebook
I have a 2 1/2 yr. old Toshiba lap top with operating system: VISTA. It is connected to an HP C6280 all in one printer. I cannot get the printer to print and what I am seeing is that my printer is...
Hi Ed,
HP Printer/Vista conflicts are legendary. Epics will be written about them. :) It's highly likely that an HP Update fouled Vista, or a Vista Update fouled HP.
The surest way to get your printer back is:
1. Go to HP Support and download the Full Software for your model printer and save it to the desktop.
2. Uninstall every HP application in the Control Panel that came with the printer, starting with the main printer software itself.
3. Hold down the Wndows Logo button on your keyboard and press the R key. A command window will open. Type in %TEMP% and hit the enter key. Your Temp File folder will appear. Delete EVERYTHING in the Temp Folder that Vista will let you delete.
4. Reboot your computer.
5. Double click on the HP Software install .exe file you downloaded to your desktop. Install the printer again as if it was the first time.
You should be good to go.
Be well.
TheSelkie
Jul 18, 2010 | Toshiba Computers & Internet
How to connect my laptop toshiba l505 gs6000 to a
Look on the case for an ON/OFF switch, and be sure that it is ON.
Look for a special label on one of the Fnn keys;
it should look like a radio-tower.
Press the BLUE-coloured 'FN' key, and press that "radio-tower" key, to enable the wireless adapter.
Then, "View Available Networks".
Apr 18, 2010 | Toshiba Satellite Pro L300 Notebook
On trying to conect my son's tower to the internet, all I get is ''little or no connectivity'' what does this mean and how can I fix it?
This usually means you are to far away from your wireless router for the computers adapter to work. Things you can try:
reposition your router. Is there metal or concrete between it and the computer?
avoid having other 2.4 Ghz wireless items nearby. I have seen a X10 camera block a laptop from getting a connection.
replace the adapter on the tower with a usb type with a cord. This allows you to place the adapter in a better position to receive.
switch to a hardwired connection (cat5 cable) or change your wireless hardware to type N.
Nov 23, 2009 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Connecting 2nd computer to router via wireless
first, your router wont look for your laptop. your laptop has to find your router. make sure your wireless card is activated on your laptop. right click on the icon where it says network cable unplugged. it should then say "view available networks". click on that and look for your network. if you need further guidance, write me back and tell me what brand of laptop you have. also, for the second tower, if you are trying to go wireless with it, then you need a wireless adapter.
Oct 25, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Usb wireless adapter for Compaq Presario 5000
Most netgear adapters will work.
They're around £20 and will connect to pretty much everything =)
They work on windows, from 98 i think. So aslong as the old tower has a sort-of up to date OS then it'll connect for you :)
Hope it helps.
Ed
Mar 17, 2009 | Compaq Presario 5000 PC Desktop
Denoopynoo@yahoo.com.au
These are the available Vista Drivers from Lexmark
May 26, 2008 | Toshiba Computers & Internet
How can I set up wireless printer
To share the printer, I open the Printers and Faxes folder on the computer that was connected to my printer.
To open the Printers and Faxes folder
• Click Start and then click Control Panel.
• Click Printers and Other Hardware, and then click Printers and Faxes.
• In the Printers and Faxes folder. Click the printer's icon and, in the tasks pane, click Share This Printer.
• Open the printer's Properties dialog box, and click on the Sharing tab.
• Click Share Name, and then clicked OK.
That's it
Now you have a network printer, you are ready to connect to it and print from other computers on the network.
To connect to the printer
•O pen Control Panel, and click Printers and Other Hardware.
•C lick Add a Printer.
• Instead of adding a local printer, though, click Printer Connection and then browse the network for the printer.
Feb 29, 2008 | Computers & Internet
46 people viewed this question
jasbo
jasbo
