Question about Dishwashers
Do you have schematics of kitchenaid dishwasher?
    Sniper:
  • 54 Answers
Everything you need to know about it
http://www.applianceblog.com/mainforums/archive/index.php/f-56.html
Posted on Feb 02, 2009
  • fgainer
    fgainer Feb 02, 2009
    Please don't forget to rate me.
    Thanks
KitchenAid fills and drains but won't wash
With a lot of such appliances, the pump motor runs one way to wash, reverse to pump out. Refusal to do this usually is a loose wire, poor connection in the timer, or a wire on wrong. Check the schematic carefully for that.
Nov 30, 2013 | KitchenAid 34 in. KUDP01FLSS Stainless...
How do you check a heater element in a dishwasher
Main breaker to unit off, need elec schematic, ohm meter check for low resistance not open circuit
Sep 15, 2012 | KitchenAid 24 in. KUDS25 Built-in...
1 yr old kitchenaid KUDE70FVSS2 dishwasher just started making grinding noises when the pump runs during the draining cycle and some water remains in the tub now. no issues with operation until now. i...
your better off just replacing the pump. you probably have broken glass or something else stuck inside the pump. to get to it you're going to have to remove the kick panel from the bottom of the machine. just follow the drain hose and you will see the pump.
Jul 16, 2011 | KitchenAid KUDE70FVSS Builtin Dishwasher
I have a kitchen aid KUDS24SE dishwasher that I believe has a piece of glass stuck in the chopper. How do I get to it? I have the impeller out is there a repair manual online somewhere?
there will be a screen inside pump where food chopper sit here is a link showing the full schematic for your dishwasher piece by piece taken apart just choose the section and examine the sump area and you will be able to see how to get to the chopper If you have any further questions message me back and please remember to rank this opinion as to how it helpedin your appliance situation Thanks again
Rick
heres the link
http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Dishwasher-Parts/Model-KUDS24SEWH5/0593/0130000?searchedModel=KUDS24SE&blt=
Dec 09, 2010 | KitchenAid KUDS24SE Built-in Dishwasher
Our Kitchenaid KUDS01FLSS6 dishwasher door string broke, but unsure what I need to pull apart out to replace?
The "STRING" is referred to as a LINK. The link has a plastic connector glued to each end. It is common for the plastic to get brittle with age (even less than 5 years) or the nylon cord to wear down and break. That is why you see the frayed cord. You have to pull the dishwasher out to fix the problem. I had to order my link online because parts store in my city didn't have it in stock. Go to the Kitchenaid website to and key in your model number to get the parts schematic for your dishwasher. Under Customer Care, go to Locate Manuals and Guides, key in your model # and click Go. At the bottom of the web page you'll see Parts List. Click on the link and this pdf pops up: http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208194009.pdf.) From the schematic you can find on page 7 "Link, Door Balance" which is #24 part 8535568. The spring hooks on to the back of the dishwasher frame and runs parallel to the floor. The Link end with the round hole attaches to the spring and the other end slips/hooks over the bracket arm that is attached to the door. Good Luck
Feb 27, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Need a circuit board schematic
Contact the manufacturer (KitchenAid is now owned and built by Whirlpool for at leas the past 10 years or so).
Jan 29, 2010 | KitchenAid KUDC24SE Built-in Dishwasher
Kitchenaid Hinge tensioner
It is aall exposed on the outside of the unit. Discconecct the water, remove the two set screws attaching the unit to the counter, slide it out and you will see the damage left or right. The white plastci piece slips off over the metal clip and you re-attach the string, apply pressure to the spring and slip the platci piece back over the metal and you are done. You will spend more time removing the unit than repairing it.
Dec 31, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
KitchenAid KUDP01DLWH6 dishwasher filter clog
Follow the main water supply line. It goes to a solenoid valve which is normally located front left side under the dishwasher.
1. Turn off the main circuit breaker for the dishwasher.
2. Turn off Water supply to the dishwasher.
3. Remove lower front panel.
4. Remove Water supply line from solenoid.
5. remover wire connections from solenoid.
6. Remove 2 mounting screws from solenoid.
7. Take solenoid valve out.
8. Look inside the valve where the water supply line was connect to, You will be able to see the filter. it is just a screen and you can easily clean it.
Good Luck
Jun 27, 2009 | KitchenAid 24 in. KUDP01DL Built-in...
Dishwashers Logo
108 people viewed this question
Top Dishwashers Experts
