Question about Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV
Powers on about 50 green blinks then goes to dot then goes green
The tv powers up it is sony wega kdf-42we655 it take about 50 green flashes then it might come up with picture for five seconds with audio then picture goes out then the screen will like have a screen that is full of stars almost looking like space with stars then it will go red then to a red complete screen then blu screen then it will go dark with lines faint looking like football field then i might get oicture for about 5 seconds with intermiddent sound then shuts off leaving four flashing red blinks then sometimes five blinking red lights
  • 1 more comment
  • caegster734 Feb 02, 2009
    the tv started out with blue horizantal lines now if the bulb is going bad will the bulb give these same symptoms what would be common problem
    i just started tv again had sound tv went red orange then ble full screen then shut down red light blinke 3 times
    so this problem is definitly not bulb thats all i see change bulb for intermittend sound and shutting off the blinking lights keep changing number of blinks each time it cycles off and on stated out five then four then three
    Master:
  • 416 Answers
It souns like a complex problem. Five blinks according to self diagnostic - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video.Four-No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted.Three- B+ -over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit.
More info you can get here
http://www.ecoustics.com/tl/15444/
And this the repair manual for similar model
http://www.scribd.com/doc/7630475/Sony-Chassis-RA4-TV-Projection-Training-Manual
But most probably it is not the fix byyourself solution
You need to contact service center and expect to pay up to $500
Good Luck
Posted on Feb 02, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Your post describes multiple symptoms and several fault indicators. In cases such as this, foremost to check would be the power supply. Since at times the picture and sound works as expected albeit for a short duration, I am inclined to think that the fault is either a cold solder issue or a leaking capacitor (again both in the power supply).
Offhand, this would require opening the unit, performing voltage measurements and comparing with known standard values. A service manual or at the very least a schematic diagram is also needed. Further this requires familiarity with electronic components & circuitry, use of a DVM/VOM and a soldering iron as well as safe practices when working with live units & high voltage. Should you be uncomfortable performing a DIY (do-it-yourself), then perhaps your best bet is to seek the services of a qualified professional.
Good luck and thank you for using FixYa.
    Brigadier General:
  • 8,619 Answers
Hi
Its the problem of convergence circuit and you need to get the STK IC 392-xxx replaced by seeing the part no from the board of your tv. Also check for any leak capacitors on the convergence board.
Thanks
Rylee
  • Rylee Smith
    Rylee Smith Feb 02, 2009
    Looks like the lamp needs to be replaced. Has the lamp been replaced or would this be the first time. Usually what occurs for lamp replacement is the TV dies no video or sound after being turned on for 10 seconds to 2 minutes.
    I think replacing the lamp will fix this issue. Also, replacing the lamp is very easy to do. It should take the technician less then 15 minutes to do. I can changed my for the 50WE610 in about 10 minutes. The hard part is removing the tv casing. To replace the bulb is in the owner's manual.
    The lamp part number for KDF55XS955 is
    Manufacturer Part #:XL2200U or A1085447A or A1060818A .
    Thanks
    Rylee
  • Rylee Smith
    Also Before replacing the lamp, read the Operating Instructions supplied with the Sony "Grand WEGAâ„¢".
    Installation requires a 3mm Allen wrench (which is supplied)
    CAUTIONS
    Turn off and unplug the power cord. The surface of the lamp is extremely hot, wait for more than 30 minutes to allow the lamp to cool down
  • 3,037 Answers
Hi caegster
For this tv, 4 blinks, pause, 4 blinks, etc. means "Fan stopped" and the probable cause locations listed are as follows:
1. Fan 1-4 power is not supplied (ASU board).
2. Fan connector is not attached securely.
3. Fan caught wires or harnesses.
These are starting points for a qualified service technician.
bestdarngood
  • 296 Answers
Not so sure about the funky screen deal but the 3 blinks of the red light i believe i can help.
Your tv is shutting down and going in to a protection mode to protect itself from damage. The light blinking 3 times represents high voltage shutdown, usually occurring in the convergence IC's and support componets of the tv. It is known as a common problem. Sorry its not a consumer fix for its a major fault in the circuitry. But if you have knowlage it can be repaired. If you take it for repair it will usually run about $300 to $400.
  • James Bradburn
    James Bradburn Feb 02, 2009
    Ignore the comment here sorry i had multiple windows up and posted to the wrong one. Sorry.
  • 4,472 Answers
4 blinks means you have a vertical deflection problem. 5 blinks indicates a problem with video circuit. Which is definitely the problem your having.
http://eservice.sony.com/webrma/web/index.do?SR=nav:service_support:electronics:repair:esup&ref=http%3A//www.sony.com/index.php
follow this link to locate the nearest service center. If you need further assistance let me know. Also please take a moment to accept and rate my solution accordingly.
Thank you,
Lee
  • Lee A.
    Lee A. Feb 02, 2009
    Well i really hope you reconsider your rating and give it to the expert who deserves it. I properly diagnosed your problem and gave you the best course of action. I hope you will reconsider.
    Thanks,
    Lee
I have Sony TV model KDF-42WE655 which stopped working. No display and when powered on, the green light comes on and blinks approx 50 times and turn red (blinking red). How and what do I need to buy to fix...
Its not the green light that you should be count but the red. How many times is it blinking? Here is a quick update of the errors that are most common.
3x - Lamp switch not engaged
4x - Fans issue
5x - Lamp
6x - Thermal fuse
Dec 15, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony KDF-42WE655. Screen goes dark.
Replace your lamp if you had it more the 3 years.
Nov 08, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony Wega kdf 42we655 tv doesn't come on. Green light just blinks. Is it the lamp?
Does the light that blinking,the word in the frame said lamp on it?Than yes,no word in the frame said lamp on it.Than u have a power board prob.
Oct 31, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony KDF-42WE655
Bad lamp and/or lamp driver. Try replacing the lamp first.
Aug 20, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Bad picture
Sony wega blue dot or star pattern on screen
http://esupport.sony.com/perl/news-item.pl?news_id=206&mdl=KDF42WE655
Models: KDF-42WE655, KDF-50WE655, KDF-55WF655, KDF-60WF655, KDF-55XS955, KDF-60XS955, KF-42WE620, and KF-50WE620
Sony LCD Rear Projection TV - Optical Block Problems
http://splinke.googlepages.com/sonyrearprojectionlcdtv-opticalblock
Jan 19, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony TV Screen
Is you model listed below?
Jan 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV Logo
21 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
