Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Oven won't heat. No gas smell. Broiler and stove work.
3 year old GE trutemp. serial no 317B6641P001. Self cleaned fine three days ago. Baked yesterday fine. Today, no oven heat.
  • hishamzaki80 Feb 04, 2009
  • Anonymous Feb 04, 2009
    the oven won't work
    Genius:
  • 2,120 Answers
Bad oven control circuit board. Look up on eBay
Posted on Feb 21, 2009
Our new home has a GE XL44 gas stove the top works fine but when I use the oven it smokes and sets off the smoke alarms.The stove is over 3 years old Any ideas before I have to call the repairman in?
A gas stove shouldn't smoke. Is is clean? There is some grease that has eluded your cleaning efforts of interior surface?
Here are some tips that may help you resolve this problem:
Check the broiler flame. If the broiler flame is not adjusted properly, you could be creating soot from the burner flame.
Position the items that your are broiling lower so that they do not splatter grease up onto the broiler baffle.
Use a broiler pan that will drain grease and drippings down below the top surface.
Broiling many items will naturally produce some smoke. If you have the oven door closed when broiling then the only place that the smoke can go is up and out of the oven vent. If you partially open the oven door, some of the smoke will come out of the door opening.
You may have residue on the top walls of the inner oven cavity. Do you have self-clean feature on your range to clean the oven? Follow all of the procedures in your owner's manual to properly clean the oven using the self-clean cycle. This may clear out any undetected residue that could be causing excessive smoke during broiling.
Aug 26, 2015 | GE Kitchen Ranges
I have a GE Profile XL 44 gas range, Model #JGBP79BEA2BB, Serial #RV224810P. The Broiler works, the oven does not. I am fairly certain the problem is the round style oven Igniter. I am trying to verif
What have you got to lose , 25.00-65.00 I would see if the ignitor works . Have someone else turn it on while you watch underneath if it sparks the try to get it closer to burner .
Jan 20, 2015 | GE Kitchen Ranges
My GE xl44 gas range broiler won't work,
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jun 02, 2011 | GE Profile JGB900 Gas Kitchen Range
Hotpoint self cleaning oven won't heat
maybe a bad connection with the heating element. Check to make sure bottom element is pluged in all the way. May need to be replaced if anything looks strange (ie. burnt spot, hole, srrange color, or maybe no external sign)
Aug 15, 2009 | General Electric Stove/Oven/Range Chrome...
Bad smell coming from stove
Look In broiler compartment and check for signs of mice
Apr 06, 2009 | Frigidaire FGF378AC Gas Kitchen Range
GE Profile gas range - stove works, oven doesn't heat
Set the oven for bake. Wait a couple minutes and look in the oven. If you see a orange glow the ignitor is working, but, may need to be replaced.
If you see no orange glow the ignitor definitely needs to be replaced.
Feb 20, 2009 | Kitchen Ranges
GE XL44 oven does not heat
12 years old? If it is a gas rnge yo need to get a gas technician out to fix it. I would probably say it s time for a new one. Hers is a couple of things to think of when getting a new stove. 1) Everyone wants a self clean. But 90% never self clean. can save up to $200 w/o that option. 2) 80% off people buy a stovebased on looks. A stove may not be pretty but work just as good as one that is.
Feb 16, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven does not heat. Broiler and stove work. NO gas smell.
could be the oven thermostat, get a plumber/heating engineer out, but make sure you can trust him, cause he could try and say u need a new cooker when it MIGHT only be a new oven thermostat.
Feb 02, 2009 | GE Ovens
Frigidaire gas range oven won't come on
the oven ignitor needs replacing, this is the part that makes everything works, it's a glow coil in side the oven, nest to the burner, that is the electronic pilot, when it goes bad the safety valve, the one that sends gas to the oven will not open to light the oven burner.
Dec 07, 2008 | Kitchen Ranges
GE Profile Spectra Broiler not lighting
I'm not an expert, and I'm reading you're post while looking for a solution for our oven, so this is in no way should be taken as a suggested solution, it isn't!!!....here it is anyway: I think it might be a bad ignitor, I have replaced a couple on our stove and both times we had exactly the same symptoms you're experiencing, I think also we're in line for a third ignitor for this "less then 10 year old Magic Chef". Good luck
Jun 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
1,705 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
