Question about Stairmaster 4400 PT Stair Stepper
Stairmaster 4400pt loses all resistance after 15-20 minutes of us
Works fine for 15-20 minutes then loses all resistance in steps.
try it then next day and it does the same thing. changed the alternator brushes, resistor, and diode but still have same problem, after 15-20 minutes of use.
  • Stairmaster Master
  • 914 Answers
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
This sounds like an issue with the console. It is almost like a software glitch in the programming. Before focusing on the console as the culprit, you can check the wiring leading up to the console for good continuity just to make sure the wiring isn't the issue. I will attach a link to a video on using a multimeter to assist in checking the wiring.
Video about Multimeter Testing
Posted on Jan 29, 2016
SOURCE: Stairmaster 4400cl has two problems
you need a plug to charge it. it does have a battery
Posted on Jan 27, 2009
  • 49 Answers
SOURCE: STAIRMASTER 4600CL RIGHT PEDAL LOSES RESISTANCE AND SLIPS
http://support.nautilus.com/support/stairmaster.jsp?lid=StairMaster you can download and view all manuals here. If by drive sprocket you mean the hub that both step chains go over.....replace the entire hub. faster easier and less hassle. cost difference is about 40 dollars.
Posted on Sep 01, 2009
maxtreadmill
  • 832 Answers
SOURCE: stairmaster 4000 crazy console
Check all connections from power source in inside the cover where alternator is to upper display then if the problem still continues I suspect your upper console is going south. Call National Gym Supply @ 1-800-496-7278 they can either repair it or may have a exchange board for you.
Posted on Mar 13, 2010
maxtreadmill
  • 832 Answers
SOURCE: I just changed the alternator and diode in my
If the upper display is not give any commands for weight ,desired program and time, if these are not inputed then the resistance is high
Posted on May 15, 2010
maxtreadmill
  • 832 Answers
SOURCE: stairmaster freeclimber 4400pt how to fix slipping
This could be the hub assembly slipping I would replace this assembly and the pedal chains call National Gym Supply @ 800-496-7278 and get pricing for the hub assembly and step chain ( L & R )
Posted on Jun 01, 2010
I have a 440pt and the left pedal is skipping down to the floor about every 5 seconds. If the issue is the hub assemble, do I have to change out everything or can I just replace the bearing, etc...?
Why does one pedal drop on my Stairmaster Stepper but the other pedal operates correctly? Stairmaster Steppers, How to Troubleshoot when one Pedal Drops (Loses Resistance) while the Other Pedal Operates Correctly
  • If one pedal drops while the other operates correctly on your Stairmaster stepper, this problem commonly occurs when the drive sprocket on one side or the other becomes defective
  • Usually, when one drive sprocket fails, the other isn't too far behind
  • The best approach to resolve this problem is to install a new hub assembly
Why does one Pedal Drop on my Stairmaster Stepper
Sep 05, 2013 | Stairmaster 4400PT FreeClimber
Need owners manual for 4400pt
Stairmaster Stepper 4400PT Parts Chain Pedal Arm Fastener SPORTSMITH net
Click on the manuals tab in the middle of the screen. You will have access to the owners and service manuals.
Jan 21, 2013 | Stairmaster 4400PT FreeClimber
Left pedal has no resistance right pedal is fine
Nov 11, 2010 | Stairmaster 4600PT Stepper
Stairmaster 4400pt seems to have a slipping chain.
You can take the covers off and see if it is indeed the chain that is slipping, but in most cases, the drive sprocket is actually what is failing. The following link will take you the item that should rectify your issue.
Drive Hub for Stairmaster Steppers 4000PT 4400CL 4600CL 4400PT 4600PT...
Nov 04, 2010 | Stairmaster 4400 PT Stair Stepper
Stairmaster freeclimber 4400pt how to fix slipping chain. When using the machine the chain slips intermittently on both sides. Problem was infrequent in the beginning but getting worse all the time with...
May 25, 2010 | Stairmaster Exercise & Fitness
Stairmaster 4400 PT Stair Stepper Logo
503 people viewed this question
Top Stairmaster Exercise & Fitness Experts
fordexpert
Craig Butler
Craig Butler
zr800o1le
zr800o1le
Level 1 Expert
Are you a Stairmaster Exercise and Fitnes Expert? Answer questions, earn points and help others
