Question about Hitachi UltraVision CineForm 55VG825 55" HDTV
Hitachi 50vs69a Rear projection TV. The t.v was on and suddenly the screen went black and the temprature and lamp red lights are flashing until i turn the t.v off. i tryed turning the t.v on and off but till the problom is not solved. If anyone can help leave a message.
  • 1 more comment
  • Anonymous Feb 05, 2009
    I have the same problem did u figure it out yet?
  • Anonymous Feb 17, 2009
    got the same problem! hmm...
  • just4play Mar 08, 2009
    Same problem but my bulb blew up when it happened. The inside of the bulb is full of pieces of glass.
Check your door that holds the lamp assembly. It will turn of the power to the bulb if ajar at all, the switch responsible for this function may be fried aswell.
Posted on Nov 08, 2010
Sony Wega 60" TV lamp light
Nope. It appears that you now have a main power supply issue since the set is dead.
Jun 23, 2017 | Sony Grand WEGA KDF-60XS955 60" Rear...
Hi, someone gave me a Hitachi 50VS69A TV and it doesn't turn on the lamp light flashes. But the power light doesn't even go on?
Have you since the lamp light is on even removed and inspected the lamp to see if shattered or not?
Apr 22, 2012 | Hitachi Televison & Video
Hitachi projection tv quit
Pls check that model number........the problem description does not match that of a 1999 crt proj tv.........I believe yours is a newer lcd projection around 4 or 5 yr old?? Lamp light flashing on any brand is indicative of the lamp not lighting . The lamp is the most likely cause,but the ballast board can cause this as well..................you should see an access door refer to owner book of the correct model and you can replace yourself...........it may cost around $200 and avaiolable at encompass parts .com Hitach distributor
Jun 06, 2010 | Hitachi 50UX57B 50" Rear Projection...
My hitachi 50vs69a tv wont turn on and after afew blinking red li
Have you replaced the lamp? Unplug the set remove the lamp and see if it's blown
Sep 20, 2009 | Hitachi 50VS69 50" Projection HDTV
50VS69A will not trun on, Lights just flash
its really hard to tell without being there to see what its actrually doing, Im asumed is out of warranty and few things you can do yourself. go ahead since its projection tv is to open the back up and check the fuses and the lamp, make sure is unplug and use a good lighting so you can truly see clear of the circuits board. some boad will have its own fuses and check them all make sure they are good. pull the lamp out and check it. projector tv are not hard to work on since is big and easy access behind the TV. to test the lamp you can take it to the local tv shop and have it tested for nothing. If all the lamp and fuses check out fine to fix your problems I would not think it will cost more than 150-200 to fix it. hope that help some ..Good luck
Jul 16, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi UltraVision CineForm 55VG825 55" HDTV Logo
286 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
