Question about Dell Inspiron 1150 Notebook
Seems like power source in back of 1150 inspiron is loose
The adapter needs to be moved ever little for it to stop charging. it won't charge the laptop and sometimes i get it positioned just right for it to charge but otherwise it's maddening because it won't show it charging... i don't know what to do.
    Genius:
  • Dell Master
  • 1,102 Answers
The internal become loose or broken after constant use
or you may need a new ac adapter
your best bet is to get it fixed before it worsens.
take it to a small pc repair store they won't charge as much as a major store.
the price is usually 60.00 and up
take ac adapter with you.
Please rate me
THANX
Posted on Feb 02, 2009
  • Dell Master
  • 629 Answers
Appears to be a loose connection between the AC adapter and the computer. Inspect the port on the computer where the AC is being connected for any damaged. If available, try using another known-good AC with your computer to isolate if the problem is specific to the AC adapter. If the same thing happens with another AC, the motherboard needs to be replaced. If the warranty of your computer is still active, contact dell and request a replacement for the motherboard
My Dell insperion won't power up at all. I bought a new battery and tested the charger and am getting the 19.5V that I am supposed to get. I don't know how to test the battery to see if it is...
If working should turn on with adapter plugged in, maybe the internal jack is broken, move adapter plug around slightly and see if it moves at all, should not. Does any lights com on or do you hear the fan ?
Nov 01, 2017 | Dell Inspiron 1150 Notebook
Please could you offer me free solution to my problem? my lap top inspiron 1150 won't power on , the battery is not being charged and the power icon doesn't show up at the task bar.
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Jul 16, 2011 | Dell Inspiron 1150 Notebook
My computer won't charge! The problem is that where i plug in the charging adapter that "little hole" is loose and won't keep the adapter in, ultimately not letting it charge
This is really a physical damage to the slot for the plug.
There are some tweaks that you might try to keep it there, like pushing it and holding it with something, or use scotch tape or something similar, but ultimately it might affect the life of your battery.
There's really nothing substantial you can do other than changing the power adapter.
May 21, 2011 | Sony VAIO VGN-FW250J/H 16.4-Inch Laptop
My AC adapter suddenly can't seems to be able to charge my battery. Please kindly advise
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced. Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
May 08, 2011 | Compaq Presario CQ40 Series Laptop Charger...
New power adapter and new battery, wont charge through power chord, dell inspiron 1150
If ac adapter and battery have been replaced (Dell Branded AC adapter is required) then the only thing left is motherboard.
Oct 28, 2009 | Dell Inspiron 1150 Notebook
Inspiron 1150 won't turn on. Noticed recently that battery life seemed shorter, plugging it in did not prevent it from shutting down after receiving the low battery warning, and it took a long time to re...
A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective.
Oct 18, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
My inspiron 1525 is not charging. Have replaced battery and charging lead and still does not charge.
Based on what you have stated, you replaced the battery and charging lead but the laptop still won't charge. What do you mean by charging lead?
Are you referring to the power adapter?
Since you already changed those two things, then the problem could be the power jack of the laptop and/or the connections inside the laptop.
Try to plug the power adapter slowly and try to wiggle it. It you feel that the power jack is wiggling, then the problem is a loose power jack that is why it won't charge. And you need to have a tech tighten that up for you.
Have a great day!
Oct 05, 2009 | Dell Inspiron 1525 Laptop Jet Black
My Dell Inspiron 1525 will not power up at all. The adapter works, however the battery is dead. The battery stopped charging about 6mos. after I purchased the unit. I did notice that where you plug the...
i had the same problem... there can be a few reasons why... the adapter i had was at first able to charge the battery... for some reason it stopped charging the battery but was still able to keep the power on... i had a friend who also had a dell laptop and for some reason his adapter was able to charge my battery so it wasnt the battery... i called dell and they sent me another adapter and that was able to charge it...
Jun 16, 2009 | Dell Inspiron 1525 Laptop
My iBook G4 Won't Charge
Sir, to help you solve your problem I need a few details. 1. What is the input source?--in my country power input is 240V AC at 50 Hz.
2. What is the adapter config? Tha t is the 'mA' and 'V' rating on the adapter.
3. If it is a loose connection on the adapter(as it seems to be in your case) you can slap it and get some results for sometime.It that stops working, you will either have to open the adapter and fix the loose connection. Or get a new adapter(recommended)
I think, this is a prob with the adapter. Even if it is not the adapter, using an adapter that works in fits and starts will damage the battery in a long run.
Please change the adapter.
Also please rate this if it was helpful.
May 06, 2009 | Apple iBook G4 Mac Notebook
Power Problem
Some thing shorted out that capacitor, you will have to find the source . It could be you adapter or it could be that the power connector is loose and the pins shorted. Really sounds like a new system board.
Sorry.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 11, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 1150 Notebook Logo
95 people viewed this question
Alun Cox
