Question about KLH R3100 Receiver
Turns off when i turn it up
About voleme 28 it turns off is it the fuses?
  • Denomfug May 04, 2009
    mine has worked perfectly fine for years with the same speakers and same set up without changing anything and now all of a sudden when i turn the volume up it shuts off , then when i turn it back on the speakers are off and i have to push the button to turn them back on .
    Scholar:
  • 93 Answers
Does it power back up after it shuts down, if it does power back up it is unlikely it is an internal fuse, you would need to replace the fuse if that was the issue, could be an amplifier overload, check the demand your speakers require in watts, and be sure the right ohm speakers are being used, many receiver will display "overload protection"and shut down, and some just un-power to prevent a electical short from occuring.
Posted on Feb 02, 2009
1998 ford explorer radio does'nt work switch on sterrein wheel broke.how to fix it ?no power to the radio
You can't turn it on by the switch on the radio ? Nothing showing on the radio display ? If not check these fuses
Blown central junction box (CJB) Fuse 1 (7.5A), Fuse 20 (7.5A), Fuse 28 (7.5A), and Fuse 29 (25A) . The switch on the steering wheel should not stop the radio from being turned on at the radio !
    Even
Mar 20, 2015 | 1998 Ford Explorer
Where is the fuse for the turnsignal on a 2004 ford taurus
Looks like the 15amp fuse F2-28 is for the turn signals and F2-33 is for the hazard flasher. The fuses are in the box near the parking brake.
See your owners manual for details.
Jan 28, 2014 | 2004 Ford Taurus
Why does Fuse #28 keep blowing
Whatever the fuse is connected to is Hooked up wrong and it is creating a short which blows the fuse! Good luck
May 27, 2013 | 1999 Lincoln Continental
Fisher and paykel mw511 pride wont turn on
Your pump could have blown the in the 4 amp in the board
Check your pump should be 34 Ohms
or higher, but not less then 28 Ohms if so replace pump and the fuse
The 4A fuse is near the AC plug on the board.
Apr 18, 2013 | Fisher and Paykel Washing Machines
The a/c has no display on my 2003 trailblazer
under the hood your fuse box, turn key to on,get in fuse box pull the PCM-B number 10 20 amp and 28 PCM1 15 amp pull battery[red]off. let set for 5 mins ,turn key off,replace fuses put battery back .....should do the trick
Apr 16, 2013 | 2004 Chevrolet TrailBlazer
Fuel pump is not getting power
Check fuse #28 in your fuse panel at the end of the dash inside driver's door. Fuse #28 controls the fuel pump. Fuse #28 ins in the lower section of fuses, first column, 5th fuse down. There should be a fuse block diagram on the fuse panel door, and in Section 3.2 of your Owner's Manual.
Oct 27, 2010 | 2000 Volkswagen Beetle
One speckers is very low voleme
go on control pannel-sound and speaker-there you can seet the speaker volume according your requirement
Apr 09, 2010 | Bose Companion 3 Computer Speakers
Have brightlights but no low beam headlights....Changed bulbs but no change to problem
Try checking your fuses. I've seen them blow when the light bulb goes. Hope this helps.
Mar 08, 2010 | 2001 Ford F150 Styleside SuperCrew
When i call someone when call is connected, i can hear otherside, but when i speak, otherside can not hear me.
ear voleme down or reset your phone only setting only not all your phone book erassed carefuly code 0000or 000000
Jul 13, 2009 | Sony Ericsson K660i Cellular Phone
KLH R3100 Receiver Logo
184 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
