Question about Delphi Roady XT XM Radio Receiver
Connection how do i connect my very old xm roady delphi sa10035 to my car cd player?
  • james kappers
    james kappers May 11, 2010
    is the car cd player an aftermarket or factory
    New Friend:
  • 168 Answers
If it has a radio get a fm transmitter you just plug it into the roady headphone jack, You can find them about every where they make them for iPods but they work work these way too. there about 20 to 25 dollars on the net
Posted on Mar 06, 2009
How to repair antenna connection on delphi roady
Copper czge? You mean the plug that goes into the base unit? Or just the antenna connection on the roady?
May 17, 2014 | Delphi Roady XT XM Radio Receiver
No power transformer good
Your power connector has probably broken off the little plastic tip on the end, and it is stuck inside the power connection around the power pin. You will have to use a needle to try to poke and pull the plastic piece out and off of the power pin, then it will work - a common problem and it has happended to me twice already!
Jul 17, 2010 | Delphi Roady SA10035 XM Radio Receiver
What do I need to install my roady to a 12volt dc system?
Just a Delphi 12VDC cigarette lighter adapter plug that will plug into this unit. You will also need an XM mini car antenna plugged into it. This has a nice FM transmtter, so you can use that, or use the audio output plug to go to your car AUX input jack or use a cassette adapter. Okay? More questions, just ask.
Apr 18, 2010 | Delphi Roady SA10035 XM Radio Receiver
My xm roady will only turn to certain preset stations
Turn the unit off and on with the power button and you should be able to get channel 1. Can you get Channel 1? If so, then call XM and ask them to send you a 'refresh' signal to reactivate your subscription on the radio. okay?
Mar 14, 2009 | Delphi Roady SA10035 XM Radio Receiver
Cable for XM capable Stereo
Nope, you need to buy a "Passport" unit which is like a card, and then a Passport Base which is the card holder with a home antenna. You put the card into the base and plug the base into your Denon and the antenna into the Passport base. You should be able to get XM channel 1 and XM247 right away. If so, then you can call and get the unit activated under the 'family plan' which is cheaper since you already have one unit. Contact me if you need more help, okay?
Sep 14, 2008 | Delphi Roady SA10035 XM Radio Receiver
'Antenna' message on Roady
Hi there check the back of the docking staion. The connection is LOOSE or try to make sure that you have not keep it in the sun for to long just let it cool down
Rate FixYa Expert Kindofcheap
Aug 30, 2008 | Delphi Roady SA10035 XM Radio Receiver
Antenna connection
Check to see if the center pin in the antenna jack on the radio is bent or missing. I have a Roady II and that is the problem with mine. You may need a magnifing glass to see it.
Dec 06, 2006 | Delphi Roady SA10035 XM Radio Receiver
Delphi Roady XT Quit Working
Chances are it's not picking up the XM signal. First, contact XM to resend your setup. if that doesn't work check your antenna connections.
Oct 31, 2006 | Delphi Roady XT XM Radio Receiver
Cannot Get Antenna To Pick-Up Signal
If your roadyxt came in a red box then you need to hook up the XM SureConnect to your vehicles antenna. The instructions that come with it are simple and straight forward. Your FM transmitter will not work unless you hook up the sureconnect
Aug 25, 2006 | Delphi Roady XT XM Radio Receiver
Delphi Roady XT XM Radio Receiver Logo
121 people viewed this question
Top Delphi Audio Players & Recorders Experts
John
John
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
