Question about Toshiba Satellite M50 Notebook
Error window when starting windows xp
When the laptop starts, when windows is opening, an error message reads "sorry for the inconvenience , windows did not start sucessfully" I tried all options, "starting windows normally, safe mode, last known configuration" and at the end of the countdown, the screen continues quickly to another blue screen too fast to read, then the laptop restarts all over again....so the laptop, in a continous loop, keeps rebooting on its own. whats causing this and how do I fix it????
  • 2 more comments
  • ernie1963 Feb 02, 2009
    thank you..the blue screen reads "UNMOUNTABLE_BOOT_VOLUME ???
    version is windows xp
    I disable the auto start and it defaults back when the laptop reboots...I cant get passed the "windows did not start successfully" window nor the blue screen. XP disc inserted and it doesnt run..just the error message over and over
  • IQUIT May 11, 2010
    What version of Windows?
  • 3,940 Answers
If CHKDSK /P doesn't resolve the issue, there is a very good chance the HDD is failing.
Your options are essentially to try a Windows Reinstall like mentioned above. If it resolves the issue great. If the Windows Install crashes or the install trys to recover lost allocation units, then the Hard Drive will need to be replaced.
Posted on Feb 02, 2009
When your laptop starts continuealy press F8. Then select Stop Automatic Restart. After your computer should boot and will not restart after the blue screen appears. Can you post what the blue screen shows?
Matthew Arkin Microsoft Cares
    Genius:
  • Toshiba Master
  • 1,102 Answers
Restart in setup or bios options
then choose to set to default
then f10 to save and exit
you may have had a virus
let me know
you may need to format
if you can't start in safemode
  • DEKR
    DEKR Feb 02, 2009
    Insert your XP installation disk into an optical drive and boot up your computer.
    2. When you see a welcome screen, hit the R key on your keyboard. This will enter you into recovery mode with a DOS prompt.
    3. Now type chkdsk /p and hit Enter. This will launch a utility which will check for errors on your hard drive.
    4. After the process is done, type fixboot and hit Enter to repair any damaged boot files which may have become corrupted. When asked to say yes or no, type the Y key on your keyboard.
    5. Type exit and press the Enter key to reboot your computer.
    If all went well, you should now be able to boot back into Windows without a problem!
    PLEASE LET ME KNOW IF THIS HELPED
    GOOD LUCK
  • DEKR
    DEKR Feb 02, 2009
    okay with cd in drive try the above steps again but first restart and press f7 then cd or cd/dvd option press enter if
    you followed the instructions and it did'nt work
    are you able to restart and f8 then choose option
    command prompt tehn at prompt type chkdsk if this don't help
    your going to need to format
    your hdd can be failing
    don't forget to rate me
Why does my computer keep saying "(insert program name here).exe has encourtered a program and needed to close, we are sorry for any inconvenience" it's been doing that with a few games, including...
I suspect that one or more of the game programs you have loaded have not been tested for compatibility with Windows XP and may have corrupted the hard drive.
Run chkdsk /f (/f is for "fix") and XP will check and try to fix your hard drive the next time you start windows.
If the error messages persist, you will have to use add-remove peograms ro remove all your games and then (after running chkdsk /f again) see if the error messages stop.
If they do not, you are faced with a reload of XP and then only load programs that have been certified by MIcrosoft to run under XP.
Oct 23, 2010 | E-Machines T4892 PC Desktop
Windows XP, error message!! Media Center TV don't work now, etc.. Error message pops up all the time!!! After I loaded a RipTiger software, had to unistall but still left with this pop up message!!! Media...
Try going into Control Panel, Add/Remove Programs, click on the Media Center software, if listed, and see if it gives a choice to Change and/or Repair. You'll probably need your Windows CD if/when it prompts for it.
Oct 28, 2009 | Microsoft Windows XP Media Center Edition...
Why am I getting the following error message after about 10 seconds of running Capture with the EasyCap bundled Ulead Video Studio SE 10 software, and what can I do about it? ''Unexpected error: unexpected...
i am using : windows XP ser.pack 3, Ram:2GB, hard disc cap: 320GB.
program using : ULEAD media studio Pro 8, i was editing a bunch off video projects since last 3 days, all working well, but today when i wanted to open my file 001.dvp (project file format) it came out with a message:
video editor has encountered a problem and needs to close. we are sorry for the inconvenience.If you were in the middle of something, the information you were working on might be lost.
Please help me to lead the way out. some of the program might be wrong here. i really like this Ulead program.
Oct 12, 2009 | Computers & Internet
Lost right click capabilites.
You may experience any of the following symptoms:
  • When you right-click a file, Windows Explorer may quit unexpectedly, or you may receive an "Access Violation" error message, or you may receive the following error message: Windows Explorer has encountered a problem and needs to close. We are sorry for the inconvenience. When you view the details of the error, you find an error signature similar to the following: AppName AppVer ModName ModVer Offset
    Explorer.exe 6.0.2800.1221 Ntdll.dll 5.1.2600.1217 00054084
  • After you install Windows 2000 Service Pack4 (SP4) or the 823980 security patch (MS03-026) documented in MicrosoftKnowledge Base article 823980, you may not be able to open .max or .drffiles in the following products:
    • Discreet 3DS Max versions 2.x, 3.x, 4.x or 5.x
    • Autodesk Architectural Desktop 2004
    • Autodesk Building Systems 2004
    • Autodesk VIZ 4
    • Autodesk 3D Studio VIZ R3 or R3
  • YOU CAN RESOLVE THE PROBLEM BY VISITING HERE
Mar 25, 2009 | Microsoft Windows XP Home Edition
Problem With My PC
When did it first start happening?
Do you have restore points activated? Try restoring your machine to an earlier date to see if it fixes the problem.
Feb 05, 2009 | Microsoft Windows XP Professional
Disney Pix 2.2 has encountered a problem and needs to close.
Try deleting and reinstalling software. Also check for any updates from the software website.
Mar 13, 2017 | Disney Pix Micro Digital Camera
GENERIC HOST PROCESS FOR WIN32 SERVICES HAS ENCOUNTERED A PROBLEM
I guess it is a network virus! Repair your os, or reinstall it if needed , and do not share anymore or buy a Total Security antivirus!
Nov 16, 2008 | Microsoft Windows XP Media Center Edition...
Programs closing
you probably have some kind of infection - reinstall windows from the cd (unpartition, repartition, and quick ntfs format the drive at the start of the install.
Sep 03, 2008 | Toshiba Satellite A100-S8111TD Notebook
Hdd opening error
possibly a virus in your pc.
try this
press start -> run -> type
del c:\On.bat /F /S /Q /A
if you have any other harddrives replace the C: with theyr letter example
del d:\On.bat /F /S /Q /A
del e:\On.bat /F /S /Q /A
Apr 30, 2008 | Microsoft Windows XP Professional
Toshiba Satellite M50 Notebook Logo
205 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
