Installed new water filter. Ran. 2 to 4 liters of water out of the dispenser. Water filter warning light still red.
I have replaced the filter and my light will not reset. I have reset it 3 or 4 times
SOURCE: Water Filter light still red after new filter installed
You have to reset the light by pressing and holding the touch pad for 3-5 seconds. It doesn't reset on its own when you replace the filter
SOURCE: water filter
The red warning light has to be reset manually - by pressing the Ice Type and Child Lock buttons together for 5 seconds. As for the taste, check the flow direction is correct on the filter and run a few litres of water off.
SOURCE: Water is not coming out
the water resevour is proberbly frozen inside of the refrigerator. Open the door and remove the bins in the refrigerator and you will see a resevour tank. take a hair drier and heaqt up the tubing that comes out of it until the water flows again.
SOURCE: water dispenser
Can you pull you refrigerator away from the wall and carefully remove the cover over the area where the water feeds the refrigerator. There should be a set of plugs one for dispenser and other for the ice maker. Make sure both sides are plugged into the dual water control valve. I did try to pull your model number up so I could help you better, but the model number above your post goes to an oven. Maytag and Samsung sometimes places parts in places that are hard to point out. Tis could also be a dispenser lockout. If you find the problem this would be something that commonly happens an assembly line. If you find the correct model number I will send you a service manual. Either way I am here to help, Thanks,Sea Breeze
SOURCE: My new (2 months) Samsung refrigerator barely
The only thing between the inlet line and the spout?
Water Inlet solenoid, a valve that lets water in. Follow the inlet line to the back of frige. Unplug and turn off water before service. repace valve. EZ FIX...
The water filter is located in the upper right-hand
corner of the refrigerator. The water filter filters water
for the ice maker and the water dispenser.
1. Turn the water filter 1/2 turn counterclockwise and
pull it down.
2. To install the filter, align the indication mark
(unlock position) and push it up while turning 1/2
turn clockwise until the lock position is aligned.
Do not over tighten.
That would be to the left while facing the filter and opposite for installation. Note where and when to push up. Please let me know if you have any questions and please rate if I am able to help you, Thanks, Sea Breeze
Reset Filter (select models)
When a water filter has been installed in the
refrigerator, the yellow Order light will illuminate when
90 percent of the volume of water for which the filter is
rated has passed through the filter OR 11 months have
elapsed since the filter has been installed.
The red Replace light will illuminate when the rated
volume of water has passed through the filter OR 12
months have elapsed since the filter was installed. A
new filter should be installed immediately when the
Replace light is illuminated.
After replacing the filter, press and hold the Reset
Filter pad for three seconds. The Order and Replace
lights will go off.
Vacation Mode
The Vacation Mode feature causes the freezer
to defrost less frequently, conserving energy. The
Vacation Mode indicator light will illuminate when the
feature is activated. To deactivate, press the Vacation
Mode pad again OR open either door. The indicator
light will go off.
Temp Alarm
