Question about Fuji FinePix J10 Digital Camera
I do not known if it is my memory card or what.
When i turn my camera on it says on the screen protected card cant get it off the screen
  • 629 Answers
Remove the memory card from the camera, then check a notch or type of slide switch at its sides. adjust the swicth to make sure the memory card is not write protected. Insert it back to the camera and test it again
Posted on Feb 02, 2009
WHEN YOU TURN ON YOUR CAMERA AND LPPK AT THE CAMERA SCREEN IT SAYS 'MEMORY CARD IS WRITE PROTECTED'WITH THIS DISPLAYED YOU ARE UNABLE TO TAKE PICTURE,YOU CAN GO TO THE MENU BUT CANT OPEN UP ANY...
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Oct 12, 2011 | Nikon Coolpix S210 Digital Camera Plum ...
Sign comes up when screen turned on to say memory card is protected and wont go away. while this sign is on camera cant be used
Take a look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Aug 12, 2011 | Panasonic Lumix DMC-TZ1 Digital Camera
Screen reads memory card write protected cant get it off
SD type cards have a little switch on the card that can write protect or "lock" it. Take the card out of the camera and check this switch. To unlock it, it should be moved towards the edge of the card which has the electrical contacts.
Dec 16, 2010 | Nikon Coolpix S1 Digital Camera
I downloaded my pics off my memory card to my laptop now the memory card is reading when i turn on my camera memory card is write protected what does that mean? i have a nikon coolpix s60. when the memory...
Look at the memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Aug 22, 2010 | Nikon COOLPIX S60 Digital Camera
Memory card write protected
Check the side of the memory card. Some of them have a little switch that turns on/off write protection. If there is no switch, you can try to format it in the computer first, then put it in the camera and format it again.
Jul 11, 2009 | Nikon COOLPIX S51 Digital Camera
Cant record new video
check the memory card that you've inserted on your camcorder. tilt the protection tab of the memory card to unprotect it.
Jun 29, 2009 | Samsung SC-D372 Camcorder
Screen flashes protection; can't record
check the protection tab on the memory card of your camcorder. move the protection tab to no.
Jun 27, 2009 | Samsung SC-D103 Mini DV Digital Camcorder
Camera wont back up to memory card
Hi there.
Check to make sure the write protection is turned off on the memory card itself, the write protection tab is located on the left hand side of the card and is usually coloured white.
Good luck and thanks for using FixYa!!
May 15, 2009 | Olympus FE-20 Digital Camera
I turn my camera on and it says protected card across the screen. I cant take pictures but I can look at them. I take out the card and turn the camera on and it either says memory full or just completely...
SD cards have a little slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
May 10, 2009 | Sanyo VPC-S1080 Digital Camera
"Memory card is protected"
This error message indicates that the memory card is locked. The switch on the memory card is in the write-protect position. Reset the switch as shown on the camera screen.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Fuji FinePix J10 Digital Camera Logo
141 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
