Question about GE Profile PSI23NCR Side by Side Refrigerator
Frig warming We keep setting it at 36, but it jumps up to 46, and now 47. We tried setting it on turbo-cool, but after 3 hours it was still on that, and not much cooler in there. Freezer has some icicles hanging from back of it's ceiling on the inside.
  • nate04 Apr 05, 2009
    my frige is stuck at 45 degrees. I keep resetting it to 37 but it never gets to that temp. It's been a week. the freezer seem normal just can't get it back to 37. any tips?
  • James Bradburn
    James Bradburn May 11, 2010
    Deforst first and try and let me know it that helped
  • 163 Answers
If you have ice cycles showing or frost built up then most likely your frezer gaket is not making a good enough seel.you could also have a defrost problem.
Posted on Mar 07, 2009
GARF19XXYK00, doesn't cool properly, 36 - 40 deg. F on coldest setting. A & E just replaced the bi-metal , defrost part, thinking the defrost keeps it too warm, but guess what, still the sam
There is a TSB on this (TSB) = Technical Service bulletin. You need a service company to order part number W10599551 and put it on. This will fix the problem.
Feb 01, 2013 | Whirlpool GARF19XXYK 19.0 cu. ft....
The freezer is working fine but the refrigerator part is warm on the coldest setting and the door has been shut for more than 8 hours.
Hi, I have seen this a lot in my 13 years in maintenance work, the most likely problem is ice build up in back of freezer behind the plastic liner.The drian tub freezes over and when the frig goes into defrost cycle the melted ice has know place to go and covers the air holes that blows into frig to keep it cool. You my have noticed water in the bottom of frig. You will have to either take freezer apart inside and remove ice and thaw out drain tube or unplug frig to thaw it out.
Mar 05, 2011 | Refrigerators
Hi I have a 2006 Whirlpool GC3SHEXNB03 side by side frig, the "gold" model. The freezer was not cooling well last night. I pulled the panel in the bottom front to access the coils. They had a lot of hair...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 10, 2010 | Whirlpool ED5VHGXM Side by Side...
New Frig Won't Cool
Good day,
If it's brand new, it's under warranty. Have them fix it or replace it. They have no choice.
Apr 28, 2010 | Samsung RFG299AARS Stainless Steel (285 cu...
Not cooling enough per the display
I have this same model which I think I bought in 1988. My frig was overheating also and the compressor was extremely hot. I too cleaned the condensor coils again and have been cleaning them at least annually for a decade and a half by putting an adapter on my small vacuum cleaner. This time I took my 6 hp shop vac and a long bottle brush and scrubbed the coils clean running the brush over the coils many times and using a trouble light to help identify where all the accummulated dust was. Frig is working perfect again. Exhaust temperature is substantially reduced. Hope this helps.
Apr 30, 2009 | Kenmore Refrigerators
Lg frig side is warm but freezer side is good
You are setting your fresh foods side to 34 but the display will go back to showing the actual temp. It is still set at 34. The refrig should be able to reach the 34 setting, so although 40 is an OK temp for a refrig, it is not what you set it to and you are definitely having a problem with the unit. Instead of starting to go through a long list of checks, I would advise you to call for warranty service, as the unit is only 3 months old.
Please don't bother rating this solution, as anything but a FixYa will lower my score. Thanks.
Nov 30, 2008 | LG LRSC26940ST 36" Side-by-Side...
Engine idle trouble
that is not a probelem it is the fuel system warming the engine and turbo
you should always warm up a turbo car before jumping in and taking off and cool the engine before shuting it off turbos are the most temprelental engine part there is. those steps will prolong the life of the turbo and engine. my starion with the g54b 2.6 does the same thing
Nov 23, 2008 | 1988 Mitsubishi Starion
Hi Guys, I have a GE Profile Frig: PSF26NGTDBB Serial # SL416129 This AM the softdrinks seemed a little warmer than usual. We checked the digital temperature inside the frig compartment and the freezer...
HI thanks for your question. the problem is either that the fan in the freezer is not working, or the fridge is frosting up, or the coils at the back of the fridge are dirty. first clean the coils .it could be you problem. thanks the appliance doc please rate my answer . thanks.
Oct 09, 2008 | GE Refrigerators
CLICKING SOUND-Crosley 19 cu ft Refrigerator
Your start system need to be replaced on the compresser go toy the parts house and ask them for a Supco RCO410 or a Supco PRO41 they come with instructions this is a common problem and will get you back in order faster than orering the factory oringinal
Feb 18, 2008 | Crosley CRS40 Manual Defrost Compact...
GE Profile PSI23NCR Side by Side Refrigerator Logo
218 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
