Televison & Video Logo
A
Anonymous Posted on Feb 02, 2013
Malata 2818 reset to factory settings - Wanlida Group Malata 500 DVD Player
Muccolloch model 2818 weedeater
That is a good question.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
User manuals McCulloch Service
I trust this information proves beneficial.
3helpful
Malata rom update tool v1.2.2
i have both a new nextar Q4 not knowing nextar doesn't exist no more, where can i get Malata Rom Update Tool V1.2.2?
How come the disc for Malata MDVD 6628 cannot be played for a whole song. It can only be played for only about 30 sec, after that, it suddenly changed to random sound which is is not a song.
That would be typical of song "clips" that they give you to "preview" the song before you have to BUY the full version to be able to use it. Usually thosee run for 30 seconds and then fade out.
I have a Malata DVP 890. I pressed a button on the remote (it is in Chinese) and the crenn dissapeared. I can get sound from the DVD if I use the red/ whiit and yloow plug connections. Nothing with...
unplug the unit for about 20 minutes. This should allow the unit to go back to it's factory default settings.
Switch the TV to the HDMI input. Turn the TV off - hook the unit up with only the HDMI and turn on the TV.
If all goes well, the TV should signal the DVD player to turn on.
If not, wait about 10 minutes then manually turn on the DVD from the front panel (not the remote)
This will usually fix you right up.
Freezes
I worked for Malata Co in Seattle for two years. I repaired hundreds of MDVD-6838. I can fix it for you at $70.00 (Labor and Parts). You have to pay shipping. If you are interested. Contact me at: [email protected]
2helpful
Singer 2818 instruction manual in English
Just visit us at www.ifixmachines.com to avail an english manual
Lost remote for Malata ltd1710 TV/DVD
Greetings rundemand,
It may be difficult to find a replacement, but there should be third party companies who only provide replacement remotes that could find one for you. You should try entering "LTD1710 remote" in a search engine to find a specialty site.
Happy Hunting.
Jon
Go Ahead. Use Us.
1helpful
MALATA DVD PLAYER I HAVE A DVD PLAYER MODEL DVP-393A SETUP HELP
the code for malata dvd player is 0782 but when i tried it didnt work. i used the code search method and it worked for me. the only problem i have is that the buttons are mixed up for example, the "menu" button opens the disk tray. so far this is the only way i could get it to work with the rca remote.
Malata DVP 892 hookup problems
I had the similar problem at first. You need to use another disc before you can configure the video output. Make sure you enable the HDMI output.
2helpful
3answers
Top Wanlida Group Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Wanlida Group Televison and Video Expert? Answer questions, earn points and help others
