Question about Baumatic 24 in. BFD60SS Free-standing Dishwasher
Baumatic BHD5 works then buttons start flashing and it beeps and stops working
The dishwasher stop after about 5 minutes, it flashes saying control error or something, it beeps and wont continue to do anything. Apparently i might need a new pcb/control circuit board but buying one direct from baumatic costs £200 and what if this isnt the actual problem? do you have any advice? thanks
  • 183 Answers
From your description it appears to be detecting a no heat fault, check heater, however not filling to the correct level, overfilling or underfilling will give the same error code. Regards Advisor
Posted on Aug 31, 2007
  • 641 Answers
Before buying a new control unit, try to unplug the machine for few hours and plug it back in. It might reset the control panel and solve your problem. Good luck!
Posted on Aug 03, 2007
SOURCE:
Why does my Electrolux dishwasher keep beeping 20 continuously?
call electrolux i cant find anything that is free,they all want money
May 09, 2015 | Electrolux Dishwashers
Have a Miele G1220SC dishwasher. It recently developed a strange problem: when switching it on ALL program lights come on and the machine starts taking water. after a while it stops taking water and starts...
follow this steps and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 30, 2013 | Miele Dishwashers
My ADP 8342 continually sounds 10 beeps, stops the...
Refer the user guide for the error message meaning. Contact service provider.
Before that make sure that the water supply to the inlet is having free flow.
May 21, 2010 | Dishwashers
Buttons not working, beeping sound
HI. This is a control fault beep. Kindly unplug, or shut off the appropriate circuit breaker for five minutes. This will drain the main control, and reset the logic chip. Once the five minutes has passed, re-introduce power to the unit, and try to operate the dishwasher normally. If the error continues, replace the control sector asap.
Oct 11, 2009 | GE 24 in. Profile PDW7800 Built-in...
It wont drain,how to reset dishwasher.
If your dishwasher has a Cancel/Drain button press and hold it for 5 seconds or until it beeps or a light flashes. The drain cycle may take several minutes and the control panel should reset.
Jul 08, 2009 | Dishwashers
Door locks and F9 fault codes
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 24, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Dishwasher problem
i had the same problem with a fisher paykel nemo dishwasher beeping at end of cycle, as im a mechanic i was curious to pull it apart and see how it works, i pulled the main control board out and unscrewed the three screws holding it all together and inspected the circuit board, and what did i see, a dry solder on the blue relay box or something, resoldered it, reassembled it and now works a treat, hope that helps
Feb 01, 2009 | Dishwashers
Maytag Performa Dishwasher draws water then stops
More than likely you need to replace the washer control panel.
Jul 19, 2017 | Maytag 24 in. MDB5600A Jetclean II...
Continuous beep after power went off and on
I'm the one who posted on May 23. I tried turning off the breakers and it was still beeped when powered back on. I ordered a new touchpad and control module. When I replaced the touchpad, the beeping was gone, but not all the buttons worked, so I changed out the control module, too, and it works:) I'm going to put clear caulk along the top to prevent spills from leaking through the front panel.
May 15, 2008 | GE 24 in. Profile PDW9880JSS Built-in...
Baumatic 24 in. BFD60SS Free-standing Dishwasher Logo
897 people viewed this question
Top Baumatic Dishwashers Experts
Pierre Laplante
Marvin
Marvin
Nicola Conroy
Are you a Baumatic Dishwasher Expert? Answer questions, earn points and help others
