Question about Samsung HLN617W 61" Rear Projection HDTV
SAMSUNG 61" DLP, HL S6187WX keeps shutting off
It seems to be an overheat problem because not only does it start shutting off on 'TEMP' after 3 hours but there are also fumes in the air that smell like 'burned electronic components'. They were so strong that a visiting friend had to go outside to breathe!
Weird thing is that the picture is beautiful.
  • 1 more comment
  • data2007 Feb 02, 2009
    Thanks, but there is lots of room around the TV, enough to walk behind it.
    The TV repairman mentioned that the unit might have a color board going bad... a $300+ cost and I know the lamp & ballast are do for replacement soon. I can't understand SAMSUNG selling a Hi Fef TV that is only good for 2-1/2 years and then you have to pay $900 for a repair to make it thru the next 2-1/2 years!
    This is definitely NOT what people expect when they pay $2800 for a high def TV,
  • data2007 Feb 03, 2009
    The TV repairman replaced the lamp and everything works fine!
    Apparently even though I had a good picture the lamp was wearing out and needed replacing. So, for all of you that are experiencing shut-down problems, if your TV is around 2-1/2 years old it's time to replace the lamp!
  • de_regan Feb 07, 2009
    My Samsung 61 DLP keeps turning itself off. It is very inconsistent, sometimes it turns off every five minutes, other times it may take an hour or two before it starts turning itselt off. We have put a pedestal fan on the back of the tv (next to the bulb cover) and this seemed to work for a while, but it now seems to make no difference...
    Damn annoying because the TV picture is sensational.
    Does anyone have any idea how to fix this problem (I have already changed the bulb - but no improvement)
  • 31 Answers
Make sure there is plenty of air flow around DLP, If nothing is restricting the air flow then the fan may have a problem.
Dont use your DLP until the problem is diagnosed by a tech.Not only will you shorten the lamp life you can do unrepairable damage to the TV.
Call Samsung to see if the TV is still under warranty.
Posted on Feb 02, 2009
2001 VW Passat is clogged with sludge
sounds like the radiator fluid is getting in the oil this is very bad news the motor is no good its cracked your going to need a new engine sorry.
Feb 16, 2013 | 2001 Volkswagen Passat
Car smells like gas and has trouble starting
This sounds like your evaporative emissions system acting up. Has the check engine light come on? There should be a charcoal cannister that filters the vented air/fumes from the fuel tank. If a vacuum or vapor line is broken, or removed.. or if the charcoal canister is depleted, you'll get the gas smell.
Sep 01, 2012 | 2000 Chrysler 300M
2003 envoy smells like fumes and idles rough
have you checked for a vacuum leak?pcv attached,no leaks around plenum,engine coolant temp sensor reading right.
May 31, 2012 | 2003 GMC Envoy Xl
The blades will not engage when the knob is pulled....toro 50
.... burning rubber smell? Sound like you have done a cutter belt.
May 27, 2012 | Toro Garden
No Heat, fan blows cold air, car dosn't overheat and no smell from coolant
If the engine temp gauge reads like normal, then you either have a bad heater core, or the valve that feeds the engine coolant to the heater core is stuck shut. If the temp gauge seems to be on the cold side, or fluctuates from normal to cooler than normal and back, it may be your thermostat is stuck open.
Oct 05, 2010 | 2001 Dodge Stratus
Anti freeze smell when car is shut down
do u smell coolant in the car when te doors are closed? if not it is not the heater core, have you had the system pressure tested at a shop? If I had to guess the 2 area's that would cause this are loose radiator hose clamps that just seep, not enough to get to the ground, but enough to smell the coolant, the other a slight leak at the water pump weep hole on the underside of the water pump, this can also be a seep and not reach the ground. Try adding a can of Alumiseal radiator and block sealer, comes in a little aluminum colored tube, about $3 US
Mar 05, 2009 | 2000 Buick LeSabre
1998 sebring convert,v6 2.5 auto
dont think it is a fuel issure sounds like a MASS AIR PROBLEM if a car is stalling while driving and will not starts but cranks its one of two things a fuel prob. or an air problem i would first check your idle air valve as well *** your tps sensor if this is happening while you drive the vehicle it sounds like at some point there is either too much air or fuel in chambes causeing missfire inturn shutting down the engine reason for not starting again is simple if its too much fiel its flooded and if it's not enough air your engine cant start if it starts after 3 hours sounds like enough time for all fumes to have subsided in chamber and again allowing for a clean start up check tps and idle air valve as well as mass air flow
Feb 10, 2009 | 1998 Chrysler Sebring
Smell of gas fumes underneath vehicle near fuel tank
this sounds like a gas pressure regulatur. a few minutes after starting,you start smelling fumes,and are getting bad gas mileage right?
Nov 16, 2008 | 2004 Volvo XC90
How do I check the pressure of my compressor?
no that our radiator in the dash (heater core ) thats leaking prestone the fume you got in the window is evaporating prestone you have to get the heater core replace because you gonna run out of prestone(coolantfor the engine) and the engine will overheat and with all the fume you wont see were our going pierre
Oct 04, 2008 | 2000 Ford Focus
Samsung HLN617W 61" Rear Projection HDTV Logo
401 people viewed this question
Jerry Greenberg
Jerry Greenberg
