Cars & Trucks Logo
Posted on Feb 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My driver side window is stuck in the down postion
Anonymous
Level 2:
  • Expert 61 Answers
  • Posted on Feb 02, 2009
Anonymous
Expert
Level 2:
Answers
61
Questions
Helped
20997
Points
145
Their could have been too much of a load on the motor and it seized or the fuse is blown. Check the fuses if not blown then run 12 volts to the motor its self. If no move ment the motor is seized. If you have move ment and the fuse is not blown then the switch is out.
Please contact me if your problem presists.
Thanks, Charlie
My window on my 03 Grand Cherokee driver side rear is stuck down and will not go up all the other windows work fine from driver side controlexcept the rear window on the driver side now it is stuck down...
You will have to remove the door panel
Most likely you have a broken window regulator
& are not going to get it up
If it is a switch problem,only,then you unplug the
motor & put battery voltage direct from the battery,
to get it up, until you have time to work on the problem
Drivers window stuck how do I get electric winder out so I can re postion window in its place
Take the door panel off and see if you can force the window up by hand. Or see if you can remove the motor itself then slide it up by hand the reinstall the motor until you get a new one.
3answers
Hyundai ix35 2012 window lock stuck. passenger window half down and cant get it to move up or down
Before you replace anything, inspect the connector pins in both the driver's door switch and the passenger door switch. If you don't find any problem with these connector pins, replace the driver's door control switch.
Driver side power window stuck in down position - Nissan Quest 2001
I HAD THE SAME PROBLEM DIAGNOSE MOTOR OR SWICH MOSTLY BAD SWICH ,BUY ON LINE EASY TO CHANGE
2helpful
Driver side window want roll down. I can see movement in it when i put the switch in the roll up postion.
You may have a problem with your window's motor. This needs to be fixed at a shop. Hope this helps! Please give 4 thumbs up!
1helpful
Driver's side power window motor stuck
This problem is going to be a bad motor or window regulator, you will need to remove the door panel and check the regulator, the regulator is the most common but the motor can also be bad, if the window goes or sits straight and is not loose in its track then i would say its the motor, a quick trick is to hold the window switch in up or down postion and bang on the inside of the door hard and see if the window starts to work if it does then its the motor,
Rear window stuck down and the wiper motor is froozen in the up postion. So my computer thinks that the wiper is in the way and wont let me roll my rear window up
If you can't the the master switch at the driver door or the switch at its door to move the window then you need a new window motor. Chances are both switches are not bad.
Does the wiper move at all ? IF not then its either the switch or the motor. If it operates and just parks in the up position then its the parker switch.
The window on the driver's side will not go up or down and will not stay up.
Need to check power to switch - then to window motor -- to do this you have to remove drivers door panel and use and test light with the ignition switch in the on postion. With test light connected to window motor, press switch up or down , if light comes on and motor does not - replace motor - if no power at motor replace switch..
Driver side window
This is caused by the window express down module, if you quickly push the window switch down a few times does this correct the issue? If not have the express down module replaced.
Drivers side power window dosen't work,is all the way down and won't come back up
BTW, the window seems to only get stuck down if it is taken all the way down - I've never gotten it stuck partway down. So in the summertime I try to remember not to take the driver's side window down completely, just keep it an inch or so up.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Chevrolet Expert? Answer questions, earn points and help others
