Question about Konaki MP4-NS MP3 Player
I'd was playing around with setting and I'd move touch .
I'd was playing around with setting and I'd move something i"d can't control it no more.
    Problem Solver:
  • 13 Answers
Have you tried resetting it, there is usually a little pin you can push , if not fully drain the battery and turn it on
Posted on Feb 02, 2009
Static noise coming from headset. The headset has been making this noise for 3 or more days.
Most headphones (wireless) have a tuning wheel that allows you to find your headphone channel pair to base set. It sounds that while checking your foam ear piece you may have moved this dial / wheel. After locating (probably near volume) the control for tune, place headphones on and slowly move control for tuning. You should hear something move control to strongest signal.
your base also has settings switch for channel helpful if you have more then one pair in house, on different TV. Play with both to find best volume.
Sep 04, 2016 | Jabra GN9330 Wireless Headset
Touch screen issue
scan for any virus.
reconfigure the touch sensitivity in control panel.
above doesn't solve the problem, try reinstalling the operating system.
Apr 22, 2013 | Computers & Internet
2004 gmc 1500 sierra heater control stuck on
Defrost is the default position. Is the control a autyomatic temperture control unit? ( you set the temp and select automatic) if it is the system is completely electronic. You push the buttons and the control still says defrost or can you select something else and the control shows it but it just keeps coming out the defrost? If the control changes and the air comes out the defrost anyway and the cheack engine light isn't on, then the problem can be blown fuses or an air door actoater not working. Does the dash emit a clicking sound? if it does with the covers off the bottom of the dash reach around touching the different pieces till you touch the idem that is clicking. this is an acutor motor, or blend door motor. they have gears in them that wear out and break the motors aren't repairable and you just replace the ofending motor. the door that is moves can be stuck. and may have to be freed up with blaster, WD40, or other rust buster till it moves easy. maybe after getting the door to move smoothly you can get the old motor to move the door wiithout having to install a new one.
Jan 06, 2010 | 2000 GMC Sierra
Sounds like a fan hitting something on the freezer side
If it sounds like that then most likely the fan has shaft play or something is touching the fan that has moved around. I think we better locate that and repair. Losing a fan is not healthy for a refrigerator compressor. Let me know, Sea Breeze
Dec 17, 2009 | Roper RS25AEXLQ Side by Side Refrigerator
The cursor jumps around on my E-105-S1402, suddenly moving to an entirely different place on the screen or moving back in a typed line so what I'm typing suddenly is inserted in a previuosly typed...
Yes.
Most probably, you are involuntarily very lightly touching the surface of your touchpad with the base of your (usually right) thumb.
Some touchpad drivers have special settings to ignore very light strokes to avoid this effect - try your pointing device settings in the control panel.
If yours doesn't, you just have to remember to keep your hands at such an angle as to avoid contact with the touchpad. A soft wristrest may help, as it elevates your wrists a bit; gel-type wrist support is my favorite.
Good luck :)
Nov 04, 2009 | Toshiba Satellite A105 Notebook
Ipod touch
I'm not quite sure if the 2.1 firmware on the iPod touch has shake to shuffle if this setting is on every time the iPod moves it will shuffle to the next song I know for sure the 3.0 has this feature look through your setting see if thats the case
Mar 31, 2009 | Apple iPod touch
Konaki MP4-NS MP3 Player Logo
47 people viewed this question
Top Konaki Audio Players & Recorders Experts
Tre Elkins
Mohamed Ismail
Mohamed Ismail
jairo sanchez
Are you a Konaki Audio Player and Recorder Expert? Answer questions, earn points and help others
