Question about Canon PIXMA MP240 All-In-One InkJet Printer
The feeder i cant get my printer to print, it starts to take the paper then it gets all twisted and goes to printer eeror. this printer worked great for 3 weeks. what wrong with it.
  • 3 more comments
  • tranquilfien Feb 13, 2009
    I've tried that. Tried feeding one at a time, two at a time, small bundles, holding it gently; everything. Usually it doesn't even start feeding. The printer sounds like it's doing it's thing, but the paper doesn't go through
  • ML246 Feb 22, 2009
    I have same problem.
  • debbyjm Feb 25, 2009
    The paper pulls to the right and jams. I have unplugged it, switched it on and off, but I can't print. I sometimes get an error message to adjust the alignment of Print Head, but I don't know how to do this
  • sexyyyy Apr 01, 2009
    i have the same problem and have tried the solutions given but dont get how to do the 2nd solution
  • Printersblow Apr 17, 2009
    Mine also has the exact same problem after a month. Makes the initial grab of the paper and never feeds it through. Tells me its jammed. garbage printer
Hey guys i had the same problem!
There was a tiny piece of paper jammed in there somewhere, i solved the problem by cutting a cardboard divider down to a4 size and feeding it through (printing blank pages) until it dislodged the blockage.
Hope this helps
Posted on Mar 12, 2009
    Scholar:
  • 124 Answers
Most likely you are putting too much paper into the paper tray. Try putting in less sheets and try to print.
Thank you for using Fix Ya!
Good Luck!
Don't forget to rate the overall satisfaction of this solution.
Posted on Feb 02, 2009
It won't "catch" the paper to print. It goes through all of the normal sounds, but won't print.
Check that there are still two rubber bands around the two little rollers. One of mine fell off and got stuck inside.
May 28, 2014 | Dell 1720dn Laser Printer
Put new roll in printer and paper feeds through then goes back out again
The printer should accept print paper ready for feed commands when computer sends jobs with clicks. A paper feeder tray may be clogged, attempt to open compartments to ascertain for misaligned or adjusted entrapment areas. Paper feeder adjustments that are tightened least allows feeder processing while loosened paper feeder clips allows several print papers at a time. Select the appropriate adjustment for the papers. Second, printers that run out of ink display sensitive malfunctions either as inability to feed paper when available. Ascertain that printer ink is available.
Jan 28, 2011 | HP PhotoSmart 130 InkJet Printer
Load paper, push bottom to print but you can hear it start to print but paper starts to go down and twist and doesn't go the feeder
Hi, Look at the paper path for any obstruction or loose pickup roller. The paper might be old and have moisture replace with fresh paper and try again. Hope this helps.
Mar 13, 2010 | Lexmark X5470 All-In-One InkJet Printer
Printer paper feed
Hi there
This hapens a lot with different printers, best way is to gave your papers a good shake and keep in a worm place then it may work for you.
All The Best Pineworks
Mar 05, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
My Epson DX4000 Printer keeps getting paper jams and wont print
still printing but the paper goes no further?. It may be the paper is locked by paper feeder mecahnics, Open case, check it, and may be there is something "material" broke.
May 24, 2009 | Epson Stylus Pro 3800 InkJet Printer
IBM 1422 not feeding 8 1/2 x 11 paper through multipurpose feeder
Go into the paper menu and set the multipurpose feeder paper size to letter. It will work if the paper size is set correctly for the MPF.
Apr 30, 2009 | IBM Infoprint 1422 Laser Printer
Printing to memorex cd lable paper
the paper feeder cant grip the back side of the paper. It slip through the feeder and the positioning led control cant adjust the correct positioning for printing!
Try another brand of paper!
Jan 18, 2008 | Brother MultiFunction Center MFC-440CN...
Paper problems
I had same problem. first turn of the printer and unplug electrical supply. turn the printer upside down and make sure there is nothing stuck in paper feeder. the next step, take a paper sort of a greetings card and try to run it through the feeder gently. if you cant get it through then don't force it. but this will clear up any object stuck in to paper feeder. now plug in yor power cord and try a test page from your printers properties. hope this will work for you. good luck...........
Aug 16, 2006 | Dell 810 All-In-One InkJet Printer
Canon PIXMA MP240 All-In-One InkJet Printer Logo
340 people viewed this question
old marine
old marine
