Question about Logitech Harmony 890 LCD Remote Control
Hi! My problem is the display is lit with no information. I can no longer control the TV or DVD player.
  • 4 Answers
You need to reset the remote. take the battery out for 60 seconds and put it back in. If it doesn't come back on when you replace the battery you have a processor error in the remote and hopefully you're still under warranty.
Posted on Feb 03, 2009
My dvd is connected and shows the green light. I can open & close the disc door but nothing happens when I push th input button.
I'm sorry that the DVD player is displaying green light and nothing is displaying input button. Please follow the below general tips and check if that helps.
  1. Please make sure that the connections are secure and proper.
  2. Try inserting another disc and check the operation.
  3. Unplug the DVD player from wall outlet and connect it back after 1 minute to perform a power reset and check the operation.
  4. Check whether you're able to see the DVD player logo on the TV screen.
  5. If not, keep pressing the INPUT button until it makes any changes on the TV screen for a minute.
I hope the information helpful. If the issue persists, please get back to me with more details about the issue so that I can more look in to this. Please include the following information in your reply.
  • When did the issue started occurring?
  • Have you made any changes since it's last normal working?
  • What is the connection between the TV and the DVD player? Also inform if you're using a standalone DVD player.
  • Provide me the model # of the DVD player and TV/display device.
Jan 10, 2012 | Cyberhome Televison & Video
Onboard LCD display
did you try to insert a different cd? see the settings like OSD button on the remote control or display to view the tracks.
CHARCOIS
Sep 13, 2008 | Toshiba SD-4900 DVD Player
How do you use the VHS function on the Toshiba DVR670 player?
Because this product is a combination of a VCR and a DVD recorder, you must select first which component you wish to operate with VCR/DVD DVD mode Press DVD on the remote control. Verify that the DVD indicator is lit VCR mode Press VCR on the remote control.(Verify that the VCR indicator is lit OR I set up this pdf link...click on it and it will show you all necessary steps http://www.helpowl.com/manuals/toshiba-dvr670-owners-manual-english-70453af.pdf
Oct 20, 2011 | Toshiba DVR670 Player
MY TV/DVD PLAYER will not turn on. The ready
that might not be totally dead if you will have the power supply checked by a qualified technician
Aug 16, 2009 | Televison & Video
Dvd player wont play
I found this on the PROSCAN website under customer support manuals.The website is www.oncorpus.com.I hope this information helps you with your problem. IMPORTANT THE LABEL SIDE OF THE DVD MUST FACE THE BACK SIDE OF THE TELEVISION 1. Press the ‘INPUT’ button to select ‘DVD’ mode, if no disc is inserted yet, the display shows ‘No Disc’.
2.Insert a DVD with the printed side facing towards the rear of the TV/DVD Player (see below)
3.The TV will first display ‘Loading’, then change to ‘DVD-video’. Most DVDs will show some preliminary
information then stop at a main menu screen.
4. Press PLAY/PAUSE to play it directly. Or press the DVD-MENU button to access the disc menu during
playback.
5.Use the direction button on the remote control to select the desired option. Press ENTER to select the
option or press the ► button. Playback will now commence.
6.After playback, press the EJECT button on remote control or EJECT button on TV/DVD to remove the
disc.
Note: No function‘’ will sometimes appear on the screen after a button is pressed. This indicates that the
function is not supported at the current time.
Feb 14, 2009 | Proscan 32LA30Q Television
Hi hope you are able to help. Although there is power to my panasonic SC-MT1 DVD player as indicated on the sub woofer and the DVD player I can not operate it. When it is first switched on at the mains...
Many thanks for your email and yes I have solved the problem. Unfortunately, the TV ariel that went in to the back of the freeview box was internally collecting water when it rained. The ariel runs down the roof and then down the outside of the house and some how water gets into and travels down the inside of the cable. The freeview box sat on top of the DVD player and the water ran through the vents in the freeview and dripped into the vents of the DVD player and that is why it no longer works.
Kind regards
Rachel
May 25, 2008 | Panasonic Televison & Video
How can I reset a whafdale dvrhd400
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit http://tvretune.co.uk/productmanuals/
Apr 16, 2008 | Wharfedale DVD-M3 DVD Player
Sony SLV-D350P DVD/Video cassette Player
I have the manual. Are you trying to record something live? if so:
1) Turn on both the DVD/VCR and your TV.
2) Switch the input selector on your TV so that the signal from the player appears on the TV screen (this is usually something like 'input 1' or 'line 1' and so forth)
3) On your remote, set TV/DVD-VIDEO to DVD-Video, then press SELECT VIDEO to control the VCR. These buttons are at the upper left hand corner of the remote controller.
4) To record from a cable box, turn it on.
5) make sure the tape is longer than the total recording time.
6) insert a tape into the VCR.
7) press CH +/- on the remote to select the channel or line input video source to record.
8) select the tape speed SP/EP (SP provides better quality, EP provides three times the recording time as SP)
9) Press the record button to start recording. The VCR display will display the message REC.
Nov 25, 2007 | Sony SLV-D350P DVD Player/VCR
Logitech Harmony 890 LCD Remote Control Logo
154 people viewed this question
Top Logitech Televison & Video Experts
Jerry Umali
cwradio73
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
