Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
The freezer on the inside bottom gets glowing red, hot, adn water drips on it and it sizzles. Is this dangerous? Is it fixable?
  • James Bradburn
    James Bradburn May 11, 2010
    what is gettin red hot? is it a part or wires?
  • 410 Answers
This is the defrost cycle and is nothing ot worry about. the unit has a heater that comes on about every 8-12 hours to melt accumulated frost from the evap coils. this heater is alot like the coils on yous stove. it should stop heating within 30 mins and resume cooling shortly afte that. thx peyton
Posted on Feb 02, 2009
  • peyton thompson
    peyton thompson Feb 08, 2009
    sorry it took so long to get back to you. what you are seeing is the heating element for the defroster. its alot like the bake element in your stove. this is tatally normal ocurence and it will happen sometimes twice a day. another thing that you will notice is what soounds like water running when its in defrost as well. thanks again peyton
Freezer leaks water out the bottom
sounds like your defrost drain line is clogged or unhooked, you will have to remove everything from the freezer and take the inside back cover off to check the problem.
Mar 22, 2014 | GE Refrigerators
Freezer working fine. Have water dripping into fridge and can't get temperature below 50 degrees.
Sounds like you have a defrost problem since the freezer side is working okay . It probably is not blowing cold air into the refrigerator side , so to check the defrost circuit , unplug the refrigerator and inside the refrigerator section at the top about 2" in from each side in the back , there are "D" slots to put a finger in , and pull downward and forward , to remove the control panel cover . Once removed , there is a 1/4" screw on each side holding the adjustment indicator panel on , 1 phillips screw behind both light bulbs , and 1 screw holding the complete panel to the rear wall . After removing these 5 screws , at the top right corner , with about 6-8 wires going to it , is the adaptive defrost board . Sometimes you can see the electronic board and on newer refrigerator's , a white box will be seen. Inside this box , is the adaptive defrost control . Disconnect the plug going to the board and on the right side of the PLUG , the far right wire is yellow , then another color , then white . Using a small insulated wire with both ends stripped , insert one end into the yellow wire hole and the other into the white wire hole . This will bypass the adaptive board and send power directly through the defrost bimetal ( thermostat ) AND heater to check if they are good .Plug the refrigerator back in . Now , wait about 3-5 min and look for a red glow at the bottom of the inside freezer panel , which will be the defrost heater or listen for sizzling which will be the frost melting and dripping onto the heater .If NO red glow , watch for a spark while removing the jumper wire you installed , from the plug . If a spark IS seen , then the heater was on and the heater AND bimetal are good . If you see the red glow , hear the sizzling , or see the spark , then the adaptive defrost board should be replaced . If no glow , sizzling or spark , then unplug the refrigerator and reinstall the refrigerator control section .
Remove the food in the freezer section enough so that the 2 screws holding the lower freezer panel on and the freezer panel , can be removed . Remove the panel . If the heater (black element at the bottom of the coils ) wires are visible , trace then to the top of the coils and disconnect . Use an ohm meter to determine if the element is good . If the element IS good , at the top of the coils , is a 1" cylinder with 2 wires , clipped onto the coils . This is the defrost thermostat ( bimetal ) . Replace this part if the element shows good . If the element shows bad , replace the element . NOTE 1 : sometimes the element and the bimetal come wired together and the replacement part comes with a new heater and bimetal already wired together . This would be the adviseable replacement part . However , each part can still be replaced individually . NOTE 2 : If looking at the bimetal and the top plastic " cap " looks cockeyed , replace the bimetal as moisture has gotten inside and disturbed its designed function .
Hoping this will help in solving the problem....
Jul 03, 2011 | GE Profile Stainless Bottom-Freezer...
There is a red glow from coil at bottom back of freezer that I can see through slats from inside. There is a sizzling water drip happening.
there is an element in there for self-defrosting, if you have a self-defrosting model. It heats up like an oven element ( not nearly as hot) to get rid of frost build up.
Nov 09, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
This is a new fridge and the element located in the lower freezer behind the pull out drawer is red hot with water dripping on it? we had the same problem with our old fridge and this is why we replaced...
the element you see in the back of the freezer compartment is the defrost heater. your frig will defrost 2-3 times every 24 hours for 15-30 minutes. when its in a defrost cycle the element will get hot and melt the frost that has built up on the cooling coils from normal operation. the melted frost will then drip down ..some will hit the heater and sizzle,most will drip onto a tray and go down a small drain into a pan under the frig and then evaporate out.. Also ,it doesnt defrost at the same time each day., it is based on how much the frig runs and the electronic control will figure out when it it time to initiate a defrost..the red glow and the sizzling is normal and only lasts a short time....
Mar 25, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer malfunction
Drain hole is clogged behind the panel that covers the coils. I found a peice of solder blocking mine. Water was freezing on the bottom of the freezer and leaking out to the floor.
Aug 04, 2009 | Maytag MSD2756G Side by Side Refrigerator
Freezer compartment gets hot
that is very much normal that is the defrost heater glowwing it is ok please rate!
Jan 07, 2009 | Refrigerators
Sound of water dripping on something hot
don't worry about it. there is a defrost heater to melt ice off the evaporator when in defrost mode. happens about every eight hours. the sizzling noise is water dripping on the heater
Sep 25, 2008 | Whirlpool GS6NBEXR Side by Side...
Red glow (from defrost heater?) at bottom of rear panel in freezer
This is from the GE Appliance "Knowledge Database" Web site:
Refrigerator - Explanation Of Red Glow
In a no frost refrigerator, the defrost timer activates defrost heaters in the evaporator section (rear of freezer) which heat up and melt the frost off the evaporator coils. This process lasts for approximately 25-45 minutes and usually happens up to twice a day.
During this time, there will be no running sounds, no fan noise, and you may hear water dripping or sizzling as it hits the heaters. On side by side models, you may even be able to see an orange glow at the bottom of the freezer.
This is normal.
Aug 06, 2008 | GE GSS20IEP Side by Side Refrigerator
Not Freezing/Cooling - A Red Glow...
  • the defrost timer and bimetal thermostat have apparently both malfunctioned. (rare)
  • if someone has worked on it in the past they may have bypassed the  bimetal thermostat.
  •  the bimetal thermostat turns off the heater if it gets too hot (above 45 in the freezer)
  • and the defrost timer is only supposed to stay in defrost for 8 minutes or so.
  • so considering the heater was on and it was hot in the freezer is evidence of these two components not doing their job.
Jul 07, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
90 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
