Question about RCA Scenium HD65W20 65" Rear Projection Television
Power surge, bad burning electrical smell
I took the back off of tv,found burn,t resistors. looks like c14126 and k14401. would like to know how to repair,get parts or send for repair.
  • 66 Answers
Remove the resistor properly from the board then after removing it you must buy the new one with the same number you have to replace the burn with the new one or just bring it to the electornic shop to replace it.
Posted on Feb 02, 2009
  • 4,806 Answers
Hi there
I recommend if you want to have the TV repaired properly by a RCA approved technician, go here:
http://tv.rca.com/en-us/servicelocator.html
Good luck and thanks for using Fixya!!!!
    Sergeant:
    Champion:
  • 346 Answers
These are not resistors
resistors have R infront of the numbers e.g r14126
  • 296 Answers
If there is burnt resisters then its best to take for repair to isolate the problem that caused it to burn up. If there is one then there could be more, but if you feel that that is the only one the you would have to take a soldering iron to take it out. To find right resister then there should be a number on it or color coded.
  • James Bradburn
    James Bradburn Feb 09, 2009
    Take the number and go to Radio Shack or a local electronics repair company. To replace them parts you will have to know how to solder. You must heat each contact and do it quick enough to get them all out. If you dont know how to do that you would need to take it for repair. If you do it yourself and mess up you run the risk of scortching the board.
Burning smell
Sounds like there is an electrical problem. Its probably in the ac / heat system. I would suspect the blower motor resistor or blower motor is going bad.
Mar 04, 2014 | Ford Cars & Trucks
Panasonic PT-53wx54j" Rear Projection Television blinking light 3 times, wont turn back on. Originally turned off by itself
sounds like a bad power supply my mother has one done the same thing we found out he power supply went bad $125 to fix so we junked it and she bought another TV
Jan 29, 2014 | Panasonic PT-47WX49 47" Rear Projection...
Convergence Resistors keep burning up
Some simple advice---if resistors are smoking one of the chips is shorted----The set has two voltages that go to them--one a positive voltage and one a negative voltage.
If either chip is shorted you can replace the resistors all year and not get anything. The resistors are protection in case one or both chips short----
Remove all old heat grease and install two new chips and replace the resistors at the same time.
Note that the set may have pico fuses on the power board also.
Jun 09, 2012 | Sony Televison & Video
When i turned on my Hc-p4241w i smelled a burning smell then the color started looking 3d, i took a flashlight & looked through the left side of the tv and saw a orange glowing inside and i shut the tv...
Your Convergence output is burnt.DONT turn that TV on until convergence IC's are replaced,orange glowing inside that you see it is resistors that overheating and burning.Unplug TV from outlet before more damage is done
Aug 23, 2011 | Samsung HC-P4241W 42" Rear Projection...
The tv smells like a burning wire
Can you describe where the odor is coming from. Is it coming out from the side panels on the tv set itself, or perhaps the plug, on end of the main power wire. Check around the electrical outlet. Make sure nothing else is plugged into the same outlet. It sounds as if some of the electrical components on the circuit board are burnt or burning out. Tv may have experienced a power surge, etc. Check also if the power plug is heating up. Be careful and smell around top side vents on tv. Be sure and unplug the set before leaving it unattended if you cannot locate the source of the "burning wire smell."
Jan 22, 2011 | Polaroid TDA-03211C 32 in. LCD HDTV
I turned on my tv this morning and it started smoking and of course smelling like something inside was burning. We took off the back and can see nothing that looks burnt or melted but the tv still wont...
hi,
may be ur tvs lamp side have some problem. may be the lamp over heated and burned. just open its lamp cover ann check it.
also check its power supply input point(near fuse) there is an MOV (used for voltage surge protection) is burned or not. if there is any voltage surge it will get shorted and the fuse will blow off, protect the power supply for any further damage. check the fuse also. if found open then check the MOV. insert fuse only after replacing the MOV.
ok
Dec 22, 2010 | Samsung HL-S5087W DLP TV
Burning and fan type sound
That is probably the power section about to fail. The burning smell is going to be from overheating components. You will have to take it into either an akai repair depot or a local tv repair and have it looked at. Get an estimate first. The repair cost on this could be cheap if itis obvious and the repair gys are on the ball or it can be pricey if they just replace major parts (typical). Also have a good idea of what replacement cost is so you know if it is worth fixing.
Jul 20, 2010 | Akai LCT42Z6TA 42 in. LCD Television
Panasonic PT-51DX80A
Look at the main circuit board do you see any burned resistors?
I had this same problem.
Sep 28, 2008 | Panasonic PT-51DX80 51" Rear Projection...
Apex GT2715 TV, burned resistor
Wire wound 190 ohm 10 watt should do the trick if that's all that's wrong with the set...accordianman
Feb 02, 2008 | Apex Digital GT2715DV 27 in. TV/DVD Combo
Jbl PB12 powered sub woofer
if your serial number starts with ha then it's probably a bad capacitor C72 . 6.8uf 100v np electrolytic. replace it with a higher voltage capacitor of the same value.
Mar 10, 2007 | JBL PB12 Subwoofer
RCA Scenium HD65W20 65" Rear Projection Television Logo
126 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
