Question about Kenmore Elite 45986 Front Load Washer
Water leaks from bottom of machine
As soon as i turn the machine on water comes out the bottom in large amounys.
Check rubber boot around door mine came off and that is where the water was coming from. its not easy to get back on then u have to get the large hose clamp in place and tighten it up.
Posted on Feb 13, 2009
Is the gasket on the filter in one piece or has a line come off the pump? mine it was the output of the pump.
Posted on Feb 07, 2009
My GE topload washing machine is leaking
Check the hose that connects to the bottom of the tub to the drain hose. Make sure that hose is securely fastened.
May 29, 2012 | GE Washing Machines
WAter leaking out of the bottom only during a large load
Look under bottom may be a hose or pump leaking Look around the hot/cold water inlets hoses May be coming from them and not the machine and running under the machine unplug it be safe
Mar 18, 2011 | Washing Machines
Belling IDW604
I found the solution myself. Underneath the machine, there is a plate. On the plate, there is a float and a microswitch, when the water leaks onto the bottom plate it raises the float and activates the microswith which shuts down the machine and shows E4 on display. To get rid of the fault, you have to pull out the dishwasher, then tilt it, and drain the water from the bottom plate. Also make sure that there is no leak in the internal piping, if there is, the fault will come back as soon as the recess in the bottom panel fills with water.Hope it helps.
Jan 20, 2010 | Belling 24 in. IDW603 Built-in Dishwasher
Severe water leak at the bottom when turned on.
It sounds like the tubing that is suppose to be hooked to two spray nozzles has come loose. You will have to take that dirt tank off, then turn the machine upside down and take the two screws out that hold the hood on from the bottom by the brushes, and then turn the machine back upright and take the screw from the top out. You should be able now to take the hood off and see all the tubing exposed. There is only one tube that goes to the spaying part in the front and see if it needs to be pushed back onto its' barbed fitting. Put that back on and put the hood back together. That should get you going.
Dec 02, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Water leaking out the bottom
CHECK THE SEAL WATER TANK ON TOP
Aug 19, 2009 | Keurig B60 Coffee Maker
Leaking
Sheets Or Comforters? This Normally Occurs With An Overload Such As Pillows And Comforters Due To The Large Circumference. Which Simply Means That Anything That Has A Large Area Will Make The Water Come Over The Top Because When The Machine Is Running The Spin Cycle The Large Area Of Fabric Covers The Side Of The Machine. Actually Causing Water To Spin Off The Top Of The Fabric And Over The Sides Of The Washing Machine Bucket Thus Ending Up On The Floor Below.
Feb 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer leaks from bottom as soon as it starts filling with water
There are 2 green clips between the top of the unit and the front panel. (you can use a flash light to find them easier). Push on the with a putty knife or small flat head screw driver while lifting on the top. Once the top is open, you will find 2 5/16 screws that hold the front panel on at the top on the right and left hand sides. Once these are removed, you can tilt the front panel forward and see where the water is leaking from.
May 31, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Belling IDW604
I found the solution myself. On the bottom plate, there is a float and a microswitch, when the water leaks onto the bottom plate it raises the float and activates the microswith which shuts down the machine and shows E4 on display. To get rid of the fault, you have to tilt the machine and drain the water from the bottom plate. Also make sure that there is no leak in the internal piping, if there is, the fault will come back as soon as the recess in the bottom panel fills with water.
Jan 12, 2008 | Belling 24 in. IDW603 Built-in Dishwasher
Leaking
This machine has two removable front panels. At the bottom of the unit are two (2) 10mm bolts. Removing these bolts will give you access to the working parts since this is an inspection plate, The upper panel : There are two (2) 10mm bolts located at the bottom corners. Remove these bolts, pull the bottom of the panel toward you to release the top latches. This will give you full access to see where the water is coming from. I suspect a leaking pump but cannot rule out a bad tub seal.
Jan 08, 2008 | Maytag SAV515DE Top Load Washer
Washing machine leaks from bottom
Open up behind after pluging off the wall. Check the hose that comes from under the tub, likely it is damaged or slipped out. Refit or change if damaged. You need a good pair of pliers; dont forget to insert the grip clips well.
Jan 01, 2008 | Washing Machines
Kenmore Elite 45986 Front Load Washer Logo
Sal De
fordexpert
 Brian Main
Brian Main
