Question about JVC AV-48WP74 48" Rear Projection HDTV-Ready Television
AV-56WP30 jvc replaced the convergence i.c. on this tv.. Time to align convergence but when i go into convergence on the menu, it wont give me the convergence crosses to line up. it just goes back like i exited out of the menu. Here is my steps..i hit menu, scroll to convergence, the press volume up button to activate convergence. as soon as i do this it just goes back to regular tv. is there another way?
  • Anonymous Feb 26, 2009
    thanks shuttle. thats a ton more help than i got paying $20 to the experts on this site. I appreciate it and will try it and post my results.
    sincerely,
    tony
    Genius:
  • 1,139 Answers
Hello tonyotteson,
I posted this in an eariler solution and there are numerous references to this type of problem on fixya.com, however it fits in this case, so here it is:
This denotes a convergence problem. Believe it or not it would be cheaper for you to replace the two convergence amplifiers and the biasing resistors. You would not actually be replacing the convergence board since these devices are usually located on the deflection board in most cases. However in answer to your question, the boards are easily removed, depending on your level of patience (lots of cables to move around), I would also advise you to either mark down all of the connection you will remove, or take pictures of the board and its connectors. If you choose to just replace the Amplifiers and the biasing resistors there is a lot of information on this site on how to do so: This will get you started:
1) Unplug the TV and then get a schematic of the TV I use http://www.servicemanuals.net or http://www.manualsparadise.com
2) On the schematic locate the STK392-xxx series IC packs (usually attached to a large heat sink)
3) determine if the STK392s are 110, 120 or 150.
4) if the STK392-xxx's are 110s replace with 110s (forget that upgrade stuff it is a hit or miss game that I don't believe you want to get into), if they are 120s replace with 120s and so on.
5)Now to replace the STKs: remove the module from the TV and unsolder theold STKs along with the bias resistors, and replace them with the newones (be sure to apply heat sink paste to the STKs when attaching them to the heatsink)
6) make sure there are no short circuits form your soldering job.
7) Reinstall the module and then turn on the TV.
8) do manual adjustment and the auto-convergence test and then things should be back to normal.
I hope this helps
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Feb 26, 2009
  • Henry McKelvey
    Henry McKelvey Feb 26, 2009
    Hello tonyotteson,
    Being as such you have replaced the two ICs what you can use is a crosshatch generator, or a dot pattern generator to create the patterns you will need to adjust the convergence on your TV.
    Just connect the generator to the RF (F connector) on your TV turn to channel 3 and select the cross hatch pattern and begin adjusting the convergence that way, and then do a auto adjust to lock it in to the processor.
    The external test set just generates a similar pattern to the internal test device only you are injecting the signal rather then using the internal test signal.
    I hope this helps,
    Thank You,
    Shuttle83
Hi i have a jvc tv model av-56wp30 it has a red line in the corner of the tv what seem to be the problem and will it cost me alot of money to fix?
Ur tv have a problems known as a convergence problems,it dead.The tv have colors lines R,B,G mis alignments,have colors shadows pictures or 3D picture look alike?The tv convergence board it is dead.The tv convergence board,must require repalcing 2 STK convergence ICS and some or all of it resistors too.The tv convergence board is fix,will solved ur tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 04, 2010 | JVC AV-56WP30 56" Rear Projection...
AV-56WP30 Convergence Repair
I got the correct answer from another free service, I can't afford your paid service and listed below is the only answer that I received from you for free:
fxnlogo_s.png Technical Support, Instructions & Repair Service
Dear lmoore44052,
A new solution has been posted for your JVC AV-56WP30 56 in. Rear Projection Television problem on FixYa.com.
Click here to read the solution:
http://www.fixya.com/ThreadView.aspx?thid=3140051&prdid=186352
Regards,
The FixYa Team
Oct 08, 2009 | JVC AV-56WP30 56" Rear Projection...
JVC AV-56WP30 has red onlines in picture (maybe red bulb ?)
This is a 2002 model----if picture looks 3d it has a convergence problem---if you go into the customer menu with the original remote select convergence and see if it will adjust----IF the answer is no, let me know and I can tell you what is involved to repair this problem.
SD TECH
Sep 30, 2009 | JVC AV-56WP30 56" Rear Projection...
I have jvc-56wp30 the color convergience is way off like a 3d picture. it will not converge.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 24, 2009 | JVC AV-56WP30 56" Rear Projection...
JVC AV-56WP30 Convergence Problem
Hi
You have defective convergence correction amplifier IC replace the STK IC...
Thanks!
Jun 12, 2009 | JVC AV-56WP30 56" Rear Projection...
AV-56WP30 not allowing me to access convergence menu
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 02, 2009 | JVC AV-56WP30 56" Rear Projection...
Convergence on jvc av-56wp30
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Jan 27, 2009 | JVC AV-56WP30 56" Rear Projection...
Definitely worth it! Should go another five years!
The STK convergence IC's need replacement. I can guide you---
Let me know.....T.
Oct 06, 2007 | JVC AV-56WP30 56" Rear Projection...
Tv screen waves and is double
No. You have bad convergence output ic;s and probably at least 1 burnt resistor. This liely will have to be reconvergec in the servcie menu after the aprts are changed.
Jul 12, 2007 | JVC AV-56WP30 56" Rear Projection...
JVC AV-48WP74 48" Rear Projection HDTV-Ready Television Logo
169 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
