Question about Car Audio & Video
I can here the engine noise in my radio
I have a 2002 vw jetta 1.8t with 69000 miles. when i accelerate i hear a buzz in the radio when i slow down it gets quieter. Any solutions?
  • m3odq May 11, 2010
    Do you have an upgraded audio system?
    The "buzz" is AC voltages from the alternator.
    If you have an amplifier, and its in the boot, you need to check a few things.
    Please clarify what your sound system is made up with.
    Problem Solver:
  • 25 Answers
Its real easy, i encountered this problem before check your ground wire make sure your amp is properly grounded. run a test ground from the battery terminal to see if you still get the zzzzzzz when you accelerate.
Posted on Aug 07, 2009
    Problem Solver:
  • 3 Answers
1st case scenario;you have your power-leads in-line with your speaker wires.A; speaker wires need to go up one side of the car and the power leads need to go up the other side of the car and your RCA leads will work better if they are running up the middle of your car
2nd case scenario; the fuse has blown in your noise suppressor that is primarily at the back of your head unit between your fire wall and the front of your dash it looks like a little black needs replacing you can get one from strathfield the instructions are simple . i made the mistake of removing mine when i updated my stereo in my car and i heard that zzzzzzzzzzz sound every time i accelerated luckily i hadn't thrown it away and i could install it back between the in coming power and my unit
Posted on Feb 02, 2009
Engine clicking noise
Noises are needed to be heard to diagnose. Have a shop listen to the noise.
Jul 14, 2016 | 2002 Volkswagen Cabrio
Vw jetta 2002 EPC light came on and acceleration just stopped
you need to have it scan to see what the light is coming on for it may be a problem with the acceleration that why the light come on and off
Jan 23, 2013 | 2002 Volkswagen Jetta TDI
I have a 2002 VW Jetta and the temperature gauge keeps going up and down... Is this something to worry about ?
Replace the Engine Coolant Temperature (ECT) sensor. ECT sensor is placed in the right back side of the cylinder head on 2002 VW Jetta 1.9 TDI. See picture below:
Please do rate my response. Thanks!
Feb 04, 2011 | 2002 Volkswagen Jetta TDI
Should a 2002 jetta tdi- automatic at 87,000 miles
That specific transmission is known for failure. Sometimes it's premature failure (in your case) and sometimes they have 150k miles, but that specific automatic transmission will always fail.
There are plenty of stories online about premature failure of the 01M VW transmission...
May 10, 2010 | 2002 Volkswagen Jetta TDI
VW shaking
sounds like the fuel pressure regulator but first try new fuel filter and maybe clean spark plugs and reset them
Sep 23, 2009 | 1995 Volkswagen Jetta
Whistling noise when accelerating
you most likely have an aftermarket radio installed
the noise you hear is engine noise, if yo turn your radio off it will go away
this can be fixed by either getting better wiring for your aftermarket radio or by installing a noise filter, you can purchase that at most big electronic stores
Jun 23, 2009 | 2002 Acura 3.2TL
I have a 2002 VW Jetta 1.8t and when I hit the gas to accelerate the car shakes. When I let off the gas it stops. Also if I sit with the car on it overheats rather quickly. I noticed neither of my fans are...
Your car overheating is either low coolant or its the thermostat. The thermostat is what tells the car to add coolant and turn on fans.
Your tranny slips could be because low transmission fluid, which was the cause with my VW. Or your tranny is bad, which is common with VW.
When your car shakes when you accelerate does it seem like its choking?
Feb 27, 2009 | 2002 Volkswagen Jetta TDI
2002 volkswagen jetta, I have a roaring sound when I accelerate
If you hear the noise while the car is moving and usually accelerating and there is no noise when it is not moving then it could be a problem with the transmission, CV Joints or wheel bearings. From the way you describe it sounds like the CV Joints. These are the ones that transfer power from the transmission to the wheel while they allow the suspension to move up and down. If they wear out or get dirty they will start making a grinding / buzzing sound. You will find them ( 2 on each side ) connecting the center of the wheel to the transmission. There are 2 rubber boots protecting them, one close to the transmission, one close to the wheel. The joints have to be kept lubricated and clean, if any of these rubber boots is broken there is a good possibility that the CV Joint is failing and making the noise. If this is the case it will need replacement.
Aug 21, 2008 | 2004 Volkswagen Jetta
Car Audio & Video Logo
192 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
