Question about Denon DN-V1700
Connecting tv/to a receiver and a dvd
Connecting tv/dvd to a reciever. Sony TV on cable, I have a red, white and yellow wires.
  • unitas78 Feb 02, 2009
    thanks. the tv is not connecting into the receiver
  • 56 Answers
Yellow is Video
Red is Right audio
White is Left audio
Posted on Feb 02, 2009
  • shockman1157 Feb 02, 2009
    Did you hook up RCAs red and white to the receiever to TV, check settings on receiver make sure you are wired in Video input on receiver and audio output on TV, check for menu settings on tv check and turn on audio output settings if available, Hard to diagnois with out knowing model/brands
Have Sony KDL-40EX400 LCD TV, Sony STR-DH510 AV reciever, Sony DVP-NS57P dvd player. When connected to reciever using component connections the TV does not show a picture. I have seen this problem in a...
  • If I understand your question correctly you want to watch your DVD on your TV thru your receiver,
  • you need to connect either composite connections "Audio/Video Output " red/white/yellow RCA jacks or "Optic cable output" of your receiver
  • ( pls note that component to composite conversion is not possible on receiver ..use one type connection thru all the way )
  • to "Audio/Video input " red/white/yellow RCA jacks or "Optic Cable input" of your TV
  • than just switch to DVD mode on corresponding your RCA or Optic connection...
There you go..Your DVD sound and video both are on the TV..
  • Hope this helps!
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
Feb 06, 2011 | Sony DVP-NS57P
I own a rca tru flat model 27F520T and the tv signal is via a starchoice statelite reciever. I recently purchased a Toshiba DVD SD7200. I am trying to view dvd's with the hook up to the statelite...
Try this steps
On the backside of your satellite receiver, you will notice a bunch of connections. If you already have your coaxial satellite cable connected to the INPUT on the receiver, leave it connected. Disconnect and remove the cable connecting the receiver to the television.
Grab your A/V composite wires and insert them into the Audio/Video OUTPUTS on the back of the satellite receiver. These are color-coded connections--red to red, white to white and yellow to yellow. The red and white connections are your audio feeds and the yellow is for your video.
Look on the backside of your DVD/VCR dual recorder. You will see similar connections. Connect the other end of the composite wires to the Audio/Video INPUTS on the DVD/VCR dual recorder.
With a second set of A/V composite wires, connect one end to the DVD/VCR dual recorder's A/V OUTPUT and the other end to the television's A/V INPUT. Again, be sure to follow the color code. Also, if your television has more than one available input, be sure to know to which one you made the connections (A/V 1, A/V 2, etc.)
Next, tune your television to the proper input channel. Look on the television's remote control for a button that is labeled "Inputs" or "A/V." Press it until you see the correct A/V channel appear on the screen. If you made your connections in A/V 1, then the TV should display "A/V 1" in the corner
Now, just turn your equipment on and settle back to watch your favorite show or DVD
Jan 10, 2011 | RCA TruFlat 27F520T 27" TV
How do I connect a sony cd/dvd player to a onkyo receiver model Tx-SR600 to a Mitsubishi big screen TV model no. WS-65411 . I cannot get a picture for the dvd when I turn on the player I have sound coming...
If your using compsite cables, Yellow , Red and White cables the red and white is sound you connect to reciever, then yellow to the coposite in on the Tv Screen. If it is a HDMI cable connect to Tv Screen not Reciever. What cables are you using?
Nov 08, 2009 | Sony Televison & Video
We have a cable box, rca reciever, a dvd and a non digital tv. Does the reciever need input from cable box, dvd and tv?? is red, yellow and white audio/video enough to connect or is a S-cable or optical...
From your cable box, send "optical" to the receiver. From the DVD send "coaxial digital" (looks like one rca cable" if your receiver has it, if not, optical is fine as well. There is no reason to send audio from the TV to the receiver unless you are using an "off-air antenna". If you want to have audio from the cable box to the TV for listening to TV speakers only, send an audio video cable (red/white/yellow) direct to TV. If you need more help just post a comment and I can help you some more.
Jul 07, 2009 | RCA RT2660R Receiver
My akai receiver to my vcr
hi my name is mark, if you have cables. first unplug the power cords to the vcr and the receiver. on the back of the vcr there will an input and an output audio and video connectors. if your vcr does not have them you will need a new vcr that does. if you just want sound, find the Output connectors. there will two. they will be idenified as Audio OUT. plug one end of the red plug into the one labeled Audio R OUT, then the white in the one labeled Audio L OUT. if you are connecting the video up connect the yellow plug to the connector labeled Video OUT. the other ends connect to the receiver, on the back of the reciever find connectors labeled vcr or dvd AUDIO IN. then connect the red plug to the connector labeled R IN and the white plug to the connector labeled L IN.if you are just hooking up sound you done. to hook up video find vcr dvd Video IN and connect the yellow plug to the Video IN. on reciever. if you want the reciever to switch the TV you also need to run a yellow video cable from Video Out from receiver to Video IN on back of TV. when finished plug in vcr and receiver. select dvd or vcr on receiver to listen ot vcr on the receiver i dont know what model you have or it features i hope this helps thanks for your question.
Mar 17, 2009 | Akai 42 in. LCD TV
First are they two seperate units, ie. a TV and a DVD unit, if so you are connecting the dvd to the TV and the TV audio to the receiver, anyway the yellow connector is composite video, you can run this from your tv to the reciever video INPUTS, the RED and WHITE connectors are for AUDIO ONLY, hence WHITE LEFT CHANNEL and RED RIGHT CHANNEL, what to keep in mind is AUDIO OUT OF TV into AUDIO IN on the receiver, same on a DVD unit AUDIO OUT of the DVD unit into an AUDIO INPUT on the receiver, but take the DVD VIDEO OUT to the TV VIDEO INPUT, other routes are possible but just keep the in and out in mind when connecting.
Feb 02, 2009 | Pioneer VSX-406 Receiver
How to connect new HD cable box to receiver
HI:
You are using a new HD Cable box, that are using componet video cables for HD, Unfortunetly this receiver does not have componet inputs, so you will just have to run the audio from the televison directly to the receiver by connecting the video out and audio out from the television to the receiver's video Input one. This will require a normal RCA composite cables yellow,red,white. Connect one end of each of the cables to televisions output terminals, and the other to the input one on the receiver. Note: Your TV might have a seperate term called Monitor out, Connect the yellow here, and the red and white to audio out. You can do the same for the DVD but you have to use the same cables,Also the television will not display HD picture this way as this is not a HDTV Receiver. If you just want TV sound to the receiver then do not use the video(Yellow) cable just use the audio out terminals from the tv and connect to Input one on the receiver. you can do this with the cable box also but you have to use RCA type cables . If you want the full HD experience then a new up todate receiver is necessary.
Dec 06, 2008 | Sony HT-DDW740 System
Connect dvd home theatre system to bravia lcd digical tv
Amongst 3 audio and 3 video options on DVD, use only one for displaying picture on TV and one for getting sound.
Yellow Wire is for picture.
Red Wire is for sound.
White Wire is for sound.
Connect Yellow from TV to yellow at DVD
Red from TV to Red at DVD
White from TV to White at DVD
Hope this help.....
hometheaterstore.com
Nov 18, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Trying to connect sony dvd player to hdtv
You will need some cables first. It's really not that difficult once you know what each cable does.
Since you're only connecting from the DVD player to a receiver, this should be simple.
There are 4 solutions depending on what cables you have.
Composite - Yellow, Red, and White ended connectors.
S-Video - Black 4-pin connectors.
Component - Green, Blue, Red and sometimes extra Red, White for audio.
HDMI - heavy cable with a wide/flat connector.
Composite connection - Connect the yellow end to the yellow Video Out of the DVD player and to the DVD Video In on the receiver. Connect the Red audio connector to the Red Audio out of the DVD player, the White connector to the White Audio out of the DVD player, and then connect those to the Red and White Ins for DVD Audio on the Receiver.
S-Video Connection - This is the same as the Composite video connection, but connect the black 4-pin cable into the S-Video out of the DVD player and into the In for DVD on the back of the receiver instead of using the yellow video cable. The S-Video cable is a video only cable and uses the same audio cables (the red and white ended cables) for audio.
Component Connection - On the back of the DVD player, connect the 3 video cables that are Red to Red, Blue to Blue, and Green to Green. These will be labeled Y for Green, Cb/Pb for Blue, and Cr/Pr for Red. Connect these video cables to the inputs of the receiver the same way Y for Green, Cb/Pb for Blue, and Cr/Pr for Red. The audio connection is the same as composite and there should be a place on the DVD player that will tell you what audio is for Component. This is also the same on the back of the receiver.
HDMI Connection - This one is the easiest to connect as your audio and video are in the same cable. Plug in your HDMI cable in the back of the DVD player (there should only be one) and then to the HDMI connection for DVD on the back of the receiver.
Now...once you have your connections made, turn on your DVD player, set your receiver to DVD, and enjoy.
If your receiver does not have video inputs, you will need to run the video lines directly to your TV while the audio lines go to your receiver. This will mean you will need to set the receiver to DVD as well as change the channel of the TV to the input you have the DVD player plugged into.
I hope this helps.
May 12, 2008 | Sony DVP-NS725P DVD Player
Connecting DVD Player to tv with RF Modulator
Well this could be a loaded question but what type of cables you using?? are there a red one a white one and a red one?? Ok then the yellow one goes to the video output on the DVD player and the other end goes to the video input of the tv. The red white cables are your right and left audio cables and red goes to red and white goes to white on the tv as well as on the DVD NOW make sure the cable on the dvd player are on the output!!!!!! Good Luck
May 05, 2006 | Cyberhome DVD Recorder - DVR1600
Denon DN-V1700 Logo
128 people viewed this question
Top Denon Televison & Video Experts
 Grubhead
Grubhead
Are you a Denon Televison and Video Expert? Answer questions, earn points and help others
