Question about Uniden TRU8885 Digital Answering Machine
Not recording The machine comes on and says "no one is avilable to ansewer the phone" and hangs up... How do i get it to record messages? thank you
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 84 Answers
Record Time sets the duration for recording the incoming messages. You have three
record time options. The options "1 minute" or "4 minutes" set the duration for
recording the incoming messages. "Announce only" answers the call but prevents
the caller from leaving a message.
1) Enter the Answ. Setup menu, and then the Record
Time submenu (see "Entering the Menu" on page 16).
2) Press volume up/down to select Record Time
(1 Minute, 4 Minutes, or Announce Only)
3) Press the OK soft key. You will hear a confirmation tone.
Posted on Feb 27, 2009
Code to retrieve messages
Here are the instructions you need to follow:
If you want to be able to play your messages from a remote location, you need to enter a two-digit Personal Identification Number (PIN) code (01-99).
To select a PIN, perform the following steps:
1) With the phone in standby, press [menu/clock] twice.
The system announces "Security code," and the current PIN code is announced as it is displayed on the base.
Then the system announces the instructions for setting the PIN code.
2) Press [volume/select/ ] or [volume/select/ ] until the desired number appears.
3) Press [set] to select the PIN code. You hear a confirmation tone, then the announcement "Security code" followed by the new PIN code is announced. After a few seconds, the system announces "To set ring time, press menu again."
Note: The PIN code is set to "80" at the factory.
Remote Operation
When you are away from home, you can operate your answering machine with any touch-tone telephone. Use this function to check for recorded messages, to play or delete messages, even record a new greeting message.
1) Call your telephone number.
2) During the greeting message, press [0] and enter your PIN code
3) The answering machine announces the current time and the number of messages stored in memory. Then you hear "To play incoming message, press zero two. For help, press one zero."
4) You may continue to listen to the voice prompts, or you may select a command from the following chart:
Command Function Command Function
[0] then [1] Repeat a Message [0] then [6] Answering Machine On
[0] then [2] Play Incoming Messages [0] then [7] Memo Record/Stop*
[0] then [3] Skip a Message [0] then [8] Greeting Message Record/Stop*
[0] then [4] Delete a Message [0] then [9] Answering Machine Off
[0] then [5] Stop Operation [1] then [0] Voice Prompts
* For Memo Record and Greeting Message Record functions, the first time you enter the corresponding command, it
starts the Recording function. If you want to stop the recording, enter the command again.
Note: Once you enter the remote access menu, you must enter a command within 15 seconds, or the
answering machine automatically hangs up and returns to standby.
5) After all of the voice prompts have been played, you hear intermittent beeps indicating that the system is in the
command waiting mode. You may enter another command at this time from the chart.
6) When you are finished, hang up to exit the system. The answering machine automatically returns to standby.
Turn on the Answering Machine Remotely
If you have forgotten to turn on your answering machine, you can turn it on remotely from any touch-tone telephone.
2) Wait ten rings until the system answers. You hear intermittent beeps.
3) Press [0] and then enter your PIN code. The answering machine announces the number of messages stored in memory. You hear "To play incoming message, press zero two. For help, press one zero."
4) Press [0] then [6] to turn the answering machine On. You hear the outgoing message and a confirmation tone.
5) Hang up the phone; subsequent calls will be answered by the system.
Feb 28, 2010 | Uniden EXAI5680 Cordless Phone
Can't get the ansewering machine to work? we were gone for 3 days. When we got home the ansewering machine was not blinking, I thouht no loved me! No messages. then relatives called saying they had tried...
You might try unplugging the AC power to the unit, let it sit for 5 minutes, and reconnect the power. That sometimes resets the unit to the factory default. You can then reprogram.
Aug 23, 2009 | Panasonic KX-TG1033S Cordless Phone
How do you remove a recorded answering machine message
Settings:
In Settings dialog you can set the following options for Best Answering Machine:
* Greetings - allows setting up the greetings played on pick-up;
* Active in profiles - defines in which profiles the application will pick-up the phone and record messages;
* Storage - allows selecting on which disk the records will be saved;
* Pick up after - sets the time after which the call will be answered;
* Record time - maximum amount of time the message is being recorded;
* Format - message file format (amr,wav);
* Icon - configures the visibility of the icon displaying application activity and presence of new messages; depending on this parameter, can be shown in standby screen only (Phone application) or in any application;
* Play volume - play volume for the greeting;
* Records lifetime - automatically removes old messages;
In this view you can listen to new and old messages, delete unnecessary messages, send the recorded messages and call the person directly from this view.
During the call:
When Answering Machine is processing an incoming call, you will see a dialog showing the application's progress with the ability to stop it:
* Answer - when this command is chosen during a call, it stops greeting playback or message record and you can continue talking to the caller;
* Hang up - stops greeting playback or message recording and terminates the call; hope this will be helpful...
Jun 23, 2009 | Nokia Cell Phones
Will my answering machine work with my u-verse
Unfortunately it may or may not be fully compatible. First you will need to make sure that all call forwarding features are turned off for your voice service so that calls will not go to voice mail before your machine can pick up. Now is where the issue of compatibility comes in, most answering machines continue recording messages until a certain amount of silence is detected on the line and the recording then stops. With some machines the period of time before the recording stops is too long, when the other party hangs up the phone the systems puts out a busy dial tone signal which the machine may mistake as a continuous message and use up all the space for messages on a single call. This of course means no other messages can be recorded till the previous message has been deleted. So to see if your machine is fully compatible means you must simply try and see.
Feb 18, 2009 | 2wire (1000-100052-000) 802.11g/b Wireless...
I want to leave my own answering message on my voicemail, how do I do that?
Press Menu. Then the unit will say "record outgoing message" Press the REC/Memo button and the unit will say "recording" and beep. The display will start counting in seconds. Speak your message. Press the play/stop button to stop recording the message will be played back to you.
Sep 22, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
Problem with the answering machine
Those machines record the message on a chip. The chip may be bad.
Aug 25, 2008 | Uniden Cordless Phone
GE Cordless answering system-27995
hi all i want to have inst. manual in english which isnt with me can anyone tell me how to download from net. thanks.Pls. also email to peraanalagan@hotmail.com
May 29, 2008 | Uniden Cordless Phone
Phone rings many times with no answering message coming on and no messages recorded
I can't seem to get the security code entered.  It won't change.  None of the numbers will change when I try to set it up.
Jan 28, 2008 | GE 29878GE1 Digital Answering Machine
How do I record my own message for the answering machine?
1. Press and hold down the announce button.
2. You will hear record announcement after the tone.
3. Once you hear record announcement after the tone continue holding the relase button and record your message.
4. When you are done recording release the release button.
5. To hear your recorded message press and hold the release button and release after you have heard your message.
6. If you are not pleased with your recorded message, repeat the steps obove.
Nov 01, 2007 | Uniden DECT 6.0 Cordless Telephone...
SW Bell FA-980 Answering Machine
Here is a link to a similar model: http://www.swbfreedomphone.com/ib/ibansw/fa970.pdf Here is what it says: TONE REMOTE OPERATION Remote Security Code To access answering functions from an outside line, you will need to enter the three digit security code located on the bottom of your unit. Write this number on the Remote Access Card, which you can keep in your wallet. Remote Turn On If you forget to turn on your unit: 1. Call your unit from a touch-tone phone. 2. Wait 12-14 rings until the machine answers. 3. The FA970 will automatically answer by playing your greeting. You may hang up the phone, and subsequent calls will be answered. Remote Message Playback 1. Call your unit from a touch-tone telephone. 2. After your FA970 answers, it plays the outgoing greeting and beeps once. Dial your three digit security code within 20 seconds after the beep, pressing and holding each digit for 1-2 seconds. Allow a 2 seconds interval between each digit. 3. Your FA970 will sound one beep to indicate the code was entered correctly. (If there are no beeps, enter your code again.) 4. You can press the following buttons on your keypad: Option Press Playback Mailbox 1 Messages (1) Playback Mailbox 2 Messages (2) Record Memo Message (3) Record New Greeting (8) Turn Off Answer Mode (9) If you press ?1? or ?2? (to playback messages), you have the follow options: Option Press Erase Current Message (0) Repeat Current Message (4) Repeat Previous Message (4) repeatedly Stop Message Playback (5) Skip to Next Message (6) To SAVE messages, hang up the telephone. Note: Your FA970 will sound a series of beeps if there are no messages. Remote Record New Greeting If you press 8 (to record new greeting): 1. When you hear a beep, begin recording your new greeting (up to 30 seconds). 2. When you have finished recording your new greeting, press (5). The unit will beep, and the new greeting will playback to you. 3. Hang up the telephone. Remote Record Memo If you press 3 (to record memo message): 1. Within three seconds of pressing ?3?, press ?1? or ?2? to select Mailbox 1 or Mailbox 2. Otherwise, the memo will be recorded in Mailbox 1. 2. When you hear a beep, begin recording your memo (up to 60 seconds). 3. When you have finished recording your memo message, press (5). 4. The corresponding Mailbox message count will be increased by one. To Retrieve Messages when Recording Memory is Full 1. When the message capacity is full, the unit will sound 3 beeps after answering the phone. 2. Within 20 seconds after the 3 beeps, dial your 3 digit security code. 3. Your FA970 will sound one beep to indicate the code was entered correctly.
Mar 22, 2007 | Southwestern Bell FA970SN Digital...
Uniden TRU8885 Digital Answering Machine Logo
303 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
