Question about Car Audio & Video
How to unlock my car radio (Sunfire GT 1999) after battery failure ?
  • 27 Answers
Go to radiocodes.com kk
Posted on Feb 06, 2009
How do I fix the clock display on my 1999 Pontiac Sunfire?
It appears to be that the radio clock display has malfunctioned, and is due for a replacement radio, which could be an aftermarket or oem radio, maybe found at a junk yard.
Tools required for oem replacement radio, torx keys set.
Before working on the radio or other electronics, disconnect the battery cables with 8mm wrench.
Replacing the oem radio is much easier, if you obtain oem radio, compared to aftermarket radio, due to being direct fit.
The radio is same for 1995 to 1999 Pontiac Sunfire and the Chevy Cavalier, regardless of sub models, such as SE,GT, VL,VLX,Z24. etc.
Parts needed for the the aftermarket radio install :Stereo assembly, stereo wiring harness adapter, radio antenna adapter, and dash install kit.wiring diagram for the wire colors / functions, along with tools, such as torx key set, screwdrivers,wire crimper, wire stripper, double ended wiring connectors, hair dryer.
The oem stereo removal video is for the 2000 to 2005 Sunfire / Cavalier, but are the same or very similar procedures.
Link to oem stereo removal procedures.
Pontiac Sunfire Radio Repair and Removal 2000 2005
Link to aftermarket stereo install / connect procedures. ( Sunfire Video )
HOW TO INSTALL AFTERMARKET STEREO PONTIAC SUNFIRE
Link to aftermarket stereo install / connect procedures. ( General Video )
How To Install Car Stereo Single Double DIN Car Audio 101
Have a nice day.
May 12, 2015 | 1999 Pontiac Sunfire
My 1999 Pontiac Sunfire GT 2.4L Automatic Gear Selector is broken
you car likely thinks its stuck in reverse, which it may be... even if you can roll it. you'll need to find a way to either get it into park or neutral, normally this can be done by the actual linkages under the shift console or from underneath the car.
Apr 07, 2017 | 1999 Pontiac Sunfire
Code to unlock the radio in a 97 sunfire
The radio will have to be removed from the dashboard.
Then post the radio make+model plus all the letters+numbers on any labels,barcodes or engraved in the metal casing.
Jul 03, 2010 | 1997 Pontiac Sunfire
The battery went dead in my 2001 pontiac sunfire and now the radio is locked. how do i unlock the radio?
you need to go to a service station with a Tech 2 scanner that can be used to unlock the radio, they are the only ones that can do it
Jul 01, 2010 | 2001 Pontiac Sunfire
How do I unlock my stereo on my 1997 pontiac sunfire? I replaced the alternator and battery, now the stereo is locked.
Remove the radio from the dashboard
Then post the radio MAKE+MODEL plus ALL the LETTERS+NUMBERS on any LABELS, BARCODES or STAMPED IN THE METAL CASING
May 26, 2010 | 1997 Pontiac Sunfire
How do I unlock my radio for my 1999 Pontiac Grand Am?
May 21, 2010 | 1999 Pontiac Grand Am GT
How do i unlock my radio in my 1999 pontiac sunfire
Try asking here for free advice + code (if available)
www.ukbookshelf.co.uk
Apr 06, 2010 | 1999 Pontiac Firebird
Won't start
I would try the battery, it sounds like it has enough juice to power the lights, but not everything else. You can take the battery to a local parts store and they can test it at no charge.
Oct 04, 2009 | 1999 Pontiac Sunfire
1999 Pontiac Sunfire won't even turn over, but the
The radio will work even with a dying or discharged battery.
First, be sure to check all of your fuses in the engine compartment.
A full battery will keep the headlights bright with the engine off. With a dying or discharged battery, the headlights will be noticeably dim.
When you turn the key to crank the engine, does the starter try to turn or make a fast clicking? If so, the battery if low or dying. If it makes a slow click then stops, then it's REALLY dying.
If you don't have a battery charger, go to Walmart and get some jumper cables. Hook up a friend's car to yours. If it starts, then the battery was low, either from a bad battery or a bad alternator.
If it doesn't, you have electrical problems, possibly a bad starter or starter solenoid.
Jun 30, 2009 | 2005 Pontiac Sunfire
Car radio lock on 1999 pontiac sunfire
how do i get the lock code for my car stereo 1999 pontiac sunfire gt
Jan 01, 2009 | 1999 Pontiac Sunfire
Car Audio & Video Logo
61 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
