Smell of gas with new boiler when on?
I have just had a boiler fitted & now when i turn it on i can smell unburnt gas coming from the boiler, can you please tell me what the problem can be?
  • Ken Bledsoe May 11, 2010
    It isn't good get the person back out and tell him right away. Sounds like a leak or faulty valve.
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 16 Answers
That's a little scary to have a new boiler emitting the smell of gas. It might be good to call a professional even if you are aware of the cause. When things are working as they should, I imagine that it's better to be safe than sorry. http://www.schweitzerbros.com/contact
Posted on Aug 25, 2017
  • 56 Answers
If you had it professionally installed i would call the company who installed it to come bac and fix problem...If you installed then i would check all the gas connections for tightness
Posted on Feb 13, 2009
Rough idle bad gas mi & fumes
Sounds like fuel mixture and possible need new plugs
Jul 11, 2014 | 1996 Buick Riviera
I have a Protherm 80e boiler which keeps going to the F1 mode
google your boiler it comes up with a manual go to page 26 it gives you 5 reasons why it goes to f1
Aug 16, 2017 | Water Heaters
Dryer works fine but i smell gas when it first comes on then goes away and the smell is only outside
Any gas operated divice will have some gas odor when it ignits, because not all gas is vaporized during the initial combustion. BUT check to make sure that your exhaust hose is clear, so that unburnt gas goes outside your living area instead of inside!
Jan 02, 2012 | Whirlpool R 850 RT Dryers
Basement flooded boiler won't
TURN WATER OFF TO UNIT AND ALL POWER AND GAS. EXTRACT ALL WATER AND REPAIR PLUMBING TO THE BOILER. IF WATER
IS COMING OUT FROM THE BOTTOM, REPLACE BOILER...
IF PLUMBING WAS REPAIRED SUFFICIENTLY AND NO WATER IS PRESENT...TURN ON WATER AND CHECK FOR LEAKS THEN TURN ON ALL POWER AND GAS TO THE UNIT AND RELIGHT
PILOT....BE SURE THERE IS NO SMELL OF GAS PRESENT WHEN YOU LTE THE PILOT..IF IT DOESN'T LITE YOU MAY HAVE TO REPLACE THERMOCOUPLE OR CLEAN BURNER.
Apr 02, 2010 | Heating & Cooling
Service Engine Soon light keeps coming on, and will go out by itself at random. You often smell gas in the back seat area when the car turns off. The OD=II lists a p0440 code. It recently had a catalytic...
Sounds like the new catalytic might of been a high flow or a universal. So your likely smelling unburnt gas. Now your aux o2 sensor located in your exhaust might be registering it more because it is usually right before or right after the catalytic.
Mar 25, 2010 | 1999 Chevrolet Blazer
My ariston boiler is not working it just shows A 01 have reset but still nothing any ideas?
Basic checks:-
water pressure in boiler
gas supply on
Turn boiler on then:-
does the fan come on - u can hear this at the top of boiler
does the gas valve click on
has there been a burning smell near the lower front [check the pcb]
check the co-axial flue is ok with no gaps between inner & outer [rare but not unknown]
If it's a condensating boiler check the condensate outlet tube for ice blockage especially in current weather
Dec 27, 2009 | Water Heaters
Fixed ac problem now smell gas inside vehicle
burnt or unburnt gas? if burnt gas smell look for bad manifold or manifold to pipe (donut) gasket.
if unburnt smell look for gas line leaks
Jul 28, 2009 | 1998 Ford Windstar
Smells like gas and when i press on the gas it putters. white smoke coming out of exhaust
White smoke is usually a sign of head gasket problems.Gas smell could be the unburnt fuel from the cylinder head which is the source of the problem.
Jul 14, 2009 | 1986 Ford Bronco
My 2005 sonata starts after trying several times. It just turns over like a car out of gas, then usually on the third time it will start.
Sounds like its either fuel or ignition. Have someone turn the car over while you sniff the exhaust.
If it smells of raw unburnt gas , fuel is not the issue , your problem is most likely ingition. Car might run rough at first when it does start , due to being slightly flooded.
If no gas smell probably a fuel problem. Possible low fuel pressure , or no fuel injection.
May 08, 2009 | 2005 Hyundai Sonata
Sime 80E friendly format boiler
Sounds like a control board or wiring to the unit has shorted out.
Apr 08, 2009 | Water Heaters
Heating & Cooling Logo
196 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
