Question about Dryers
Maytag gas dryer
The light in my Maytag LDG9334AAE dryer went out and we replaced the bulb. Did not fix the problem. What else could be wrong and is there something we can replace on our own?
  • 640 Answers
Check door switch
Posted on Feb 12, 2009
I have a maytag gas dryer mgdx500xw, with door open and light on, circuit breaker blows, with door closed it does not, if I remove the bulb, it won't blow either way. Weird?
the return neutral wire from the bulb has to have a bare spot on it touching the metallic case somewhere in the dryer,when you remove the bulb you just isolate the bare spot on the neutral wire from the hot wire
Sep 07, 2012 | Maytag Dryers
Maytag dryer mug15pdaww won't light, the ignitor
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 16, 2011 | Maytag Dryers
My Maytag gas dryer won't heat. I have replaced the gas solenoids, If I tap the gas valve it lights. Old solenoids check out with correct ohms.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 11, 2010 | Maytag MDG2600BWW Gas Dryer
How to light gas dryer maytag neptune
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 11, 2010 | Maytag Neptune MDG5500AW Gas Dryer
I have gas dryer, model SDG4606, and the light inside drum does not work. How do I replace it?
When you open the door on your dryer your light bulb is located at the top of the opening. There will be a clear plastic cover over it that is held in place by one screw. Remove the screw and allow the cover to hinge away from the opening. The bulb is Maytag part number 67001316.
Sep 17, 2010 | Maytag SDG4606A Gas Dryer
Maytag LDG9334AAE Gas dryer making popping noise from vent
clean clean clean everything, dont let it go to much longer or you will have a fire, and dont ignore this or you regret it... then tell me if it makes the noise
May 07, 2009 | Maytag Dryers
Maytag dg482 gas dryer won't heat
pilot safety most likely. most of these older units had a mercury bulb safety simular looking to a thermocouple.
Jan 25, 2009 | Dryers
Gas dryer Maytag model # LDG410
You don't light the pilot. Gas dryers have a glow bar type ignitor. These get very fragile with age and will burn out like a light bulb. The other thing that will wipe out the glowbar is moving the machine if it gets handled roughly.
Jan 02, 2009 | Maytag MDG7600AW Gas Dryer
Dryers Logo
101 people viewed this question
Top Dryers Experts
