Question about Apple iPod nano
Verticle lines on nano ipod
After charging my screen only shows verticle lines. I have tried simultaneously holding down the menu and center buttons to no avail as well as toggling the hold switch on and off
  • 20 Answers
Return it. The chip board under the display is crapped out. You got a lemon. I had this happen to me on a first generation ipod.
Posted on Feb 18, 2009
2 Suggested Answers
  • 92 Answers
SOURCE: ipod nano
Try this out
  1. Ensure that you have an active Internet connection as new versions of iTunes and iPod Software may need to be downloaded to your computer.
  2. Download and install the latest version of iTunes if you do not already have it installed.
  3. Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
  4. After a few moments, your iPod will appear in the Source panel in iTunes.
  5. Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
  6. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software. The 4 possible restore options are:
    • Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
    • Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
    • Restore Option 3: Use Newest Version - Restores with the latest iPod Software available.
    • Restore Option 4: Restore and Update - Restores with the latest iPod Software available.
  7. If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
  8. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
    • Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
    • Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
  9. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
  10. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Posted on Feb 06, 2009
When i plug ipod into computer to charge, nothing happens
I don't claim to be an expert of any sort, but I have owned one of these for a few years and the controls are fairly familiar. My advice is to first hard reboot the iPod by simultaneously holding down the menu and center buttons. This merely restarts the iPod, you will still have your music. If it still doesn't want to charge, try to access the. Diagnostics mode. First you must reboot (using the above method) and as soon as the screen goes black begin to simultaneously hold down the previous Track and the middle buttons. There should show a dos-like diagnostics menu. Navigate with the next and previous track buttons. Select with the middle button, go back with the menu button. You will se a menu with power, audio, LCD, etc. Select power and run some tests. If one gives you an error, hen you have found your problem. If you can't do any of these, then it is possible your battery is just plain shot. They don't last forever, sadly, you can either go to a licensed apple service shop near you, ( aka, apple store) or you can contact apple support. Hope this helps!!
Nov 09, 2010 | Apple iPod nano
I tried to do my ipod nano screen lock but it wont work. i also i rote the code down. i did put the code in a number of times
restart the ipod...maybe this works...
n some cases, your iPod nano may simply need to be reset. Follow the steps below to reset your iPod nano:
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again).
  2. Press and hold the Menu and Center (Select) buttons simultaneously for about 6 to 10 seconds until the Apple logo appears. You may need to repeat this step.
Oct 11, 2009 | Apple iPod nano
Screen is frozen
How to reset iPod Nano if it is not responding or frozen.
Hold down the Center and Menu buttons simultaneously. The screen will start to melt away. Then you will see the Apple appear on the screen.
The iPod has been reset sucessfully.
Music files should still be saved, but some customized settings may be lost.
If that doesn’t fix your problem, try a hard reset by holding down Menu and Play/Pause simultaneously for about 10 seconds. A hard reset will clean all data off the unit.
Jul 25, 2009 | Apple iPod nano MP3 Player
16 gig ipod nano screen has frozen screen
Try doing this: Toggle the hold switch and put it back in the off position. Then press and hold the center button and the menu button simultaneously for ten seconds and the apple symbol should come up on the screen. Then it should work like normal. Hope this helps!
Jul 08, 2009 | Apple iPod nano MP3 Player
The unit will not turn on nor charge.
Apr 20, 2009 | Apple iPod nano
Ipod not responding
You may be doing the reset wrong. Try doing this: Toggle the hold switch and put it back in the off position. Then press and hold the center button and the menu button simultaneously for ten seconds and the apple symbol should come up on the screen. Then it should work like normal. Hope this helps you!
Apr 18, 2009 | Apple iPod nano
Nano Ipod stuck in disk mode:
Simply reset the iPod
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
Jan 31, 2009 | Apple iPod nano
The screen is on, but there is nothing on it
have you tried resetting it?
if not press the center button and the menu button and hold for a couple seconds
And also Make sure you press Center FIRST (hold this down) then press and hold the menu button while keeping the center button held
Nov 21, 2008 | Apple iPod nano
IPOD Nano 4GB
First, toggle the hold switch. Then press and hold the center button and the menu button until the apple logo appears on the screen.
Oct 22, 2008 | Apple iPod touch
IPod Nano Problem!!!
I dont need help anymore I read someone elses problem and the coment to that.
May 23, 2008 | Apple iPod nano
Apple iPod nano Logo
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
