Question about Frigidaire 24 in. PLD3465REC Stainless Steel Built-in Dishwasher
Amps & Outlets
Want to purchase a Frigidaire FDBB4365FC dishwasher but have to have plumbing and electrical work first. Electrician wants to know if it runs on 110 or 220 and what the amps is?
  • 640 Answers
110,,15 amp breaker by it self...stainless braid fill quick connection,,try not to use copper...back legs down front up to counter...and your washing,,,dont foreget jet dry..and bleach unit out every three months..onthejob
Posted on Feb 02, 2009
The fuse trips when the iron is switched on
dead short internally or bad wiring in the cord
cord can be replaced by electrician but otherwise junk it and get a new one
Dec 09, 2016 | Irons
Hi i have purchased a milano 60cm fan forced wall oven. the electrician putting in a new circuit needs to know how many amps 15A or 20A.. Thanks Tony
Sorry but if he is an electrician he should know what to do! The new wall oven will have a sticker on it with the kilowatt rating. The kilowatt rating is used to calculate the current it will draw. This calculation is dependant on your voltage supply. Once this is worked out it will determine circuit size. If your electrician can't work this out you need to find a new electrician.
Mar 01, 2011 | Ovens
Purchased "Reliance Lowboy electric water heater"
The water heater has two 4500 watt elements.
However both elements are not turned-ON at same time
So the water heater is 4500 Watts
Volts x Amps = watts
Amps =watts divided by volts
Amps = 4500 Watts divided by 240 Volts
Amps= 18.75
So that says a 20 amp breaker ... except for the 80% rule
80% rules says for safety, your Amp rating should be multiplied by 80%
20 amp breaker X 80% = 16 amps
20 amp breaker is actually safe for just 16 amps, and your water heater draws 18.75 amps.
The calculation shows you need a 30 Amp breaker.
30 Amp breaker requires 10 gauge wire.
I just installed the dishwasher and do not turn on
On the LG LDF6810 model, you should be able to open the door and press the power button (right side of the top of the door.) It should wake up and you should see lights.
If that fails to happen, trace the power from under the dishwasher to where it is plugged in to the wall. If it is under the sink and you have a waste disposal, it is very possible that both outlets are switched on/off by the disposal switch. I would find a known-good table light or something similar and plug it in to the outlet and see if the light turns on when I switch it on. Electrician is needed to separate the top/bottom outlets so the dishwasher is always on and the disposal is properly switched.
If the dishwasher is not connected to an outlet, rather directly connected via electrical wire, have an electrician confirm the hot, neutral and ground wires are properly connected under the dishwasher and check the circuit breaker/fuse for that circuit.
Please report back what you find, OK?
May 20, 2010 | LG LDF6810ST Stainless Steel Built-in...
The electrical consumer unit trips when the dishwasher is on, swicthing all the sockets off in the house. An electrician has told me it could be a number of things, namely a problem with the neutral, some...
You might need to contact a different electrician. Also a different retailer of machines as this one is obviously trying to make a sale. The apparent problem is that the house is wired with all of the outlets in the house on one circuit breaker--a recipe for trouble. Any house with multiple outlets should be divided into zones so that the whole house doesn't shut down if one appliance trips the breaker. A heavy user of power like a dishwasher should have it's own breaker and wiring for that machine alone. The electrician should have load-checked the dishwasher to make sure it is not drawing more than rated power, then suggested that it be wired to it's own breaker and circuit. Any other high power appliances should also have separate circuits (washing machine, microwave, toaster, etc.). Hope this helps!
Mar 25, 2010 | Tecnik TKL9260 Front Load Washer
Squeaky noise when open door
petroleum jelly rubbed on the nylon cord and all parts that it does the trick
Jul 13, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
No water coming into dishwasher
My Frigidaire runs for 4 hours. It takes 4 hours to complete a cycle.model-FDB8345
Nov 03, 2007 | Frigidaire 24 in. FDB1050RE Built-in...
Bosch SHU3306UC dishwasher stopped
Make sure you visit the Bosch dishwasher recall website as this model is under the recall with a faulty controller which may cause a fire! Check your model under
then call 800.856.9226 to setup a recall repair appointment. We just found out about this recall and was never notified by Bosch even though we registered our unit after we purchased about poor customer service! Hope this helps!
Sep 04, 2007 | Bosch SHU3306UC Built-in Dishwasher
Frigidaire 24 in. PLD3465REC Stainless Steel Built-in Dishwasher Logo
105 people viewed this question
Top Frigidaire Dishwashers Experts
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
