Question about GE Spacemaker JVM1640SJ Microwave Oven
Need directions on how to operate the space maker in our RV
I have lost the diections on how to operare the GE spaceoven in our RV. Need dirction replacements. thanks cd
  • GE Master
  • 9,098 Answers
You can download GE owner's manuals and installation instructions here.
Posted on Feb 03, 2009
I need a door handle for GE space maker microwave
You can usually find replacement parts by search the internet for:
Make Model replacement parts
Jan 07, 2017 | GE Microwave Ovens
Sharp Carousel Microwave Mdl 1875 for our RV is dead
>> We also tried plugging our toaster into the microwave plug outlet, and the toaster wouldn't work in that outlet, but worked just fine in a different outlet in the RV.
This means the outlet you plug your microwave into needs to be fixed in addition to fixing the oven. Breaker? Fuse?
>> I understand from another RV forum that microwave ovens for RVs have "special circuitry and cooling features" not found in regular countertop ovens for household use.
Not really in my experience. Any microwave supplied with clean AC power and proper venting space will be fine.
But I'd bet your microwave can be fixed affordably.
The main internal things which can result in this model being dead (no display, no light when you open the door, no beep when you press a pad on the keypad) would be the 20A fuse and the magnetron temperature fuse. There could also be bad connections on the noise filter board.
Also, sometimes a power surge can cause the power to be interrupted to the low voltage transformer on the board, and I regularly repair those boards. I can also write a technical statement to your insurance company or to an RV park as needed.
At my Web site, I have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
The relevant service manuals for this model are here and here.
You can order Sharp parts from Sears or Encompass.
Contact me directly if you need more help.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide "Recycling by repairing since 1982"
Mar 08, 2017 | Sharp R1875: Over the Range Convection...
Microwave manual lost 1987 spacesaver2 jem20g 001
GE has the manuals for most of their appliances on their support site: http://www.geappliances.com/service_and_support/literature/ . The direct link to the manual for the Space Saver JEM20G is http://www.geappliances.com/search/older-pdfs/49-4850.PDF . If you would prefer a printed copy of the manual, Sears Parts Direct has the manual for sale. See http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Microwave-Parts/Model-JEM20G01/0432/0123245/E2102468/00001?blt=06&prst=&shdMod= and scroll down to the various documents labeled as part 9999 to see the information to order the items.
I hope this helps.
(please note that you will need Adobe Reader or a similar program to read the manual)
Jan 02, 2012 | GE Microwave Ovens
Need manual
Hi
Thanks for using FixYa. Please see the link to download the manual for GE Space Maker JVM 1640SJ Microwave Oven---
GE JVM 1640SJ Microwave Oven Manual
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Ge profile space maker xl 1800 shut down during cooking
Unplug unit..reset circuit breakers..check agin and then see if it starts up. It may need drying out due to excess steam
Jun 16, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
How to remove inside door trim to replace handle on G.E. space maker mod#JVM1341BW002
Very carefully. You will need one to two flat head screwdrivers. There is a piece in the inner door that covers the screw holes. It snaps in. Once it is removed you should be able to see the screws to the back side of the handle. Just be careful removing inner trim because they are prone to break.
Nov 21, 2009 | GE Microwave Ovens
GE space maker JVM1640. Does not heat food.
with out a proper diagnosis, i would have to believe your magnetron is gone
Oct 03, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge Microwave space saver over range working but
It is a good possibility that the stirrer has failed. In the top of cabinet is a round cover,there is a small round plug in the edge of it,pry plug out and put it in safe place,rotate the cover < twist locks > gently let it down and stirrer will be either setting on cover or still attached. If you notice any damage< it is a round aluminum disc that is flat > then you need a new one. If you don't see any damage put it back in < put in hole and turn until you feel it line up with shaft and push into place,< gently >.Make note of position and put cover back on < stirrer does not lock on shaft so you have to hold it up until you get cover under it in most cases. Run a short cycle and remove cover to see if it turned at all. If not the motor is bad < turns stirrer during operation>. This is the first time that question has been asked of me and it is the only thing that I can think of if it heats glass and not food.
Apr 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
JNM1541 GE Space Maker
If it's less than one year old, it should be fully covered under warranty.
I'd suggest contacting the manufacturer to get it fixed free or better still, if you've had it less than 30 days, I'd have the dealer replace it.
GE Customer Service is here.
It sounds like the door or door switch mounts are misaligned. It may have been damaged in shipping.
Jan 07, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I HAVE A RV WITH A GE SPACEMAKER OVEN. THE RV IS A 2004 MODEL. I HAD TO MAKE AN EXTENTION CORD TO GET SERVICE TO THE RV. I SWAPPED TWO WIRES IN THE EXTENTION CORD AND THE OVEN WOULD NOT WORK. I HAVE...
Chances are the oven experienced a surge and damaged the control board.
We repair these for customers nationwide with our guaranteed $39.95 service.
Please feel free to contact me directly if you need more help. And please mention your model number when you write.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
prototech@usa.net
http://www.microwavedisplay.com
Jul 23, 2008 | GE Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
114 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
