Bottom half of laptop is dark with vertical lines
  • 3,940 Answers
Generally, what you describe is a failure of the LCD screen.
Things you can try:
1. Reseat the LCD video connection to the video card.
2. Connect an external monitor see if the issue occurs externally (If so the video card is failing)
If video works normally externally, then LCD replacement is warranted
If the system is in warranty, contact technical support from the manufacturer.
Posted on Feb 02, 2009
Screen particially blacking out with vertical lines at bottom of my DELL laptop. at the bottom of laptop screen there are vertical lines @ 2" they are blue, dark gray,white, purple, light green lines....
Tryconnecting an external monitor to the laptop. You may have to select the videooutput to display on the external monitor by holding down the blue key and pressing the blue CRT/LCD (located on one of the keys, likeF8,F9, etc..). If the problem occurs on the external monitor with the batteryor AC power, then you have a problem with either the video card or motherboardin the laptop. If the problem does not happen using the external monitor thenyou laptop's LCD display is going bad.
Jul 31, 2011 | Dell Inspiron 1525 Laptop
A line appeared in the middle of the screen and has expanded and now the botttom half of the screen has two horizontal bars of vertical lines instead of the bottom half ot the display. Recently had new...
Try to plugged in external monitor to your computer. If you did not experienced this problem using the external monitor then this is not a mainboard issue. This could be an LCD issue. You need to call the manufacturers tech support department and have your computer repaired. Same goes also if you experienced same problem using external monitor. You still need to call dell tech support department for mainboard replacement.
Jun 13, 2010 | Dell Inspiron 1525 Notebook
Bottom half of screen sometimes black or bad video
Probably you have to change your resolution settings and what type of operating system are you using?? or you have to get your computer checked out by a professional to be safe.
Apr 20, 2009 | Compaq Computers & Internet
L7680 all in one W/big & wide dark vertical line
Open the document feeder and clean the scanner glass.
Feb 16, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Vertical lines in my laptop screen
Hi mikenstacy
Try to connect a normal desktop monitor to the laptop (there will be one vga port where you can connect the monitor) and if you see those lines on external monitor as well then most probably video card has gone bad (you can try to reinstall video drivers in this case) if those lilnes are not there on external monitor then problem is with your LCD so if system is in warranty then get it replaced other wise get in touch with local compter shop and get it replaced.
let me know if this helped
Sep 19, 2008 | Dell Inspiron 1501 Notebook
Toshiba Television
If it has been happening slowly, it is likely from the decay of an electrolytic capacitor.
If it happened suddenly, something else in the vertical deflection section has gone bad.
This isn't going to be a DIY repair as it will require a bit of test equipment to find.
Aug 30, 2008 | Toshiba Satellite A135-S4527 Notebook
Problem with Toshiba 42HP83 Plasma TV
Just on a whim I'd say you have video out put circuits in distress.
can you say WARRENTY lol
Aug 24, 2008 | Toshiba 42HP83 42 in. HD-Ready Plasma...
LCD monitor problem
what is the solution for this? my husband just turned his pc on when we got home and there are line blue lines running up n down in the black
Oct 11, 2007 | Computers & Internet
Mitsu HD1080
There is a possibility that the problem lies on the "Doubler" circuit board with this set, especially if the darkness looks like a smear in the picture during bright scenes like a hockey game.
Mar 13, 2007 | Mitsubishi WS-55805 55" Rear Projection...
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
