Set temperature at 17 but is really only 12 - Heating & Cooling
  • 909 Answers
There are 2 possabilities, 1) either the temp probe is out of spec. causing the control to switch off at the incorrect temp. or 2) The electronic board is faulty.if the biasing changes on the board so will the temp reading .Max cooling should be 16deg. celcius on an aircon. I suspect probe. Typically it sits on front rhs of evap. Lift front panel, remove filter./s to see.probe
Posted on Feb 02, 2009
I have a wine enthusiast wine cooler model 272 03 27. Not cooling,compressor kicks on. The fans are running.The temperature never gets below 64.Is it the temp sensor or Control board? Thanks Randy
It sounds like it is in the correct temperature range. You may ned to adjust the temperature to a lower setting.
°C °F Wine Style 19 66 Armagnac, Brandy, Cognac 18 64 Full Bodied Red Wines, Shiraz 17 62 Tawny Port 15 59 Medium Bodied Red Wines 14 57 Amontillado Sherry 13 55 Light Bodied Red Wines 12 54 Full Bodied White Wines 11 52 Medium Bodied White Wines 10 50 Ros?, Light Bodied White Wines 9 48 Vintage Sparkling 8 46 Fino Sherry 7 45 Non-Vintage Sparkling
Dec 01, 2016 | Furniture
Preset heat stuck at 63. I want to lower the temperature for a vacation
[PDF]PAR-30MAA - Mitsubishi Electric Australia
https://www.mitsubishielectric.com.au/.../IB_PAR-30...
Mitsubishi Electricand Mitsubishi Mr. Slim Air Conditioners. MA Remote Controller ..... Heat. 17 ~ 28 ?C (63 ~ 83 ?F). Auto. 19 ~ 28 ?C (67 ~ 83 ?F). Fan/Ventilation. Not settable. 13 ...
[PDF]PAR-31MAA - Mitsubishi Electric Australia
www.mitsubishielectric.com.au/.../par-31maa_ib_en.p...
Mitsubishi Electricand Mitsubishi Mr. Slim Air Conditioners. MA Remote ..... Heat. 17 ~ 28 ?C (63 ~ 83 ?F) .... Preset cooling temperature is higher than preset heating temperature.
My air recycle button just blinks. Also when i turn on the - Fixya
www.fixya.com/support/t26081705-air_recycle_button_just_blinks_also
6 hours ago - Not sure the heat pump is producing enough heat. Nov 04 ... Preset heat stuck at 63. ... Feb 05, 2016 ' Mitsubishi Electric Mr Slim E12C26426.
[PDF]MA Remote Controller Mitsubishi Electric PAR-21MAA ...
planetaklimata.com.ua/.../Mitsubishi_Electric/Mitsubishi_Electric_PAR-2...
Easy Maintenance Function (Only for Mr. SLIM PUHZ series) . .... 4.4.3 Automatic Cooling/Heating Display Setting . ... Monitoring the Operation Data by the remote Controller (for Mr. SLIM) .......... ..............48 . How to .... 63. 4.2 How to set rotation function(back-up function, 2nd stage cut-in function) . ... Preset temperature (. °C. ).
Feb 05, 2016 | Mitsubishi Electric Mr Slim E12C26426...
Where is the knock sensor on a Kia Sedona 2.9 diesel, 2004 LA
Here is the location of the "Knock Sensor" you requested, I hope it helps you. It is Number 17. for future reference here is the list of the others
1 = Camshaft position sensor (CMP)
2 = Crankshaft position sensor (CKP)
3 = Engine Control relay (EC) -engine bay fusebox/relay plate 1
4 = Engine Coolant temperature sensor (ECT)
5 = Exhaust gas recirculation valve actuator (EGR)
6 = Fuel Filter
7 = Fuel Filter Heater - in fuel filter housing
8 = Fuel Flow control valve - on high pressure fuel pump
9 = Fuel Rail pressure sensor(FRP)
10 = Fuel Temperature sensor - on high pressure fuel pump
11 = Glow Plugs
12 = Glow Plug Relay 1 - engine bay fuse box/relay plate 2
13 = Glow Plug relay 2 - engine bay fuse box/relay plate 2
14 = High Pressure fuel pump
15 = Injectors
16 = Intake air temperature sensor (IAT) - in MAF sensor
17 = Knock Sensor (KS)
18 = Mass Air Flow sensor (MAF)
Feb 04, 2015 | 2004 Kia Sedona
What is the sum if the quotient of 2/3 and 7/12 is added to 17/14
Proceed step by step.
Quotient of (2/3) by (7/12) =(2/3)/(7/12)=(2/3)*(12/7)=8/7
Sum of 8/7 and 17/14 is 8/7+17/14=16/14+17/14=(33/14)
Sep 22, 2014 | Office Equipment & Supplies
What is normal oil pressure ?
Oil pressure at operating temperature for XL models would be 1000 rpm = 7-12 psi or 43.3-82.7 kPa and at 2500 rpm 10 - 17 psi or 68.9 to 117 kPa TAKEN or read at the oil pressure switch fitting.
Jul 02, 2014 | Harley Davidson XLH Sportster 883...
2006 grand prix heater only blows cold air. both heater hoses are hot blower motor works fine.
Sounds like the temperature blend door actuator may be bad or the vacuum hose to it is disconnected.
Poor Heater System Performance CAUTION
Check all fluid levels and adjust as needed, before operating vehicle for extended periods at idle.
  1. Start the engine.
  2. Idle the engine until the thermostat opens (upper radiator hose will be hot) Is the engine at normal operating temperature (approx. 200° F)? If yes, go to the next step. If no, go to step 16.
  3. Set the mode selector to FLOOR mode.
  4. Set the heater control selector to the warmest temperature setting.
  5. Set the blower speed the lowest setting.
  6. Carefully feel the inlet and outlet heater hoses at the heater core. Is the inlet heater hose significantly hotter than the outlet heater hose? If yes, go to step 14. If no, go to the next step.
  7. Set the mode selector to PANEL mode.
  8. Select the maximum blower speed.
  9. Select the warmest temperature setting.
  10. Place a thermometer into the center I/P PANEL air outlet and affix a second thermometer to the heater core outlet heater hose.
  11. Record the temperature at the center I/P PANEL air outlet and at the heater core outlet heater hose. Are the two temperature readings about equal? If yes, go to the next step. If no, go to step 13.
  12. Inspect and repair the cowl, cowl area, recirculation door, and the HVAC evaporator/heater core case for cold air leaks. Repair any problems found, go to step 17.
  13. Inspect the temperature door operation. Repair any problems found, go to step 17.
  14. Turn OFF the engine. Back-flush the heater core. Start the engine. Select the FLOOR mode and the lowest blower speed. Select the warmest temperature setting. Feel the temperature of the inlet and outlet heater hoses at the heater core. Is the inlet heater hose feel significantly hotter than the outlet heater hose? If yes, go to the next step. If no, go to step 17.
  15. Replace the heater core. When the repair is completed, go to step 17.
  16. Check for low engine temperature problems, Repair or replace as needed, go to step 17.
  17. Operate the system in order to verify the repair. If the system operates properly, the repair is complete. If the heater still does not work properly, repeat the entire procedure.
Nov 19, 2010 | 2006 Pontiac Grand Prix
Have samsung american fridge freezer with ice dispenser i bought it second hand the problem is the digital display says the freezer is 20 degrees but its freezing inside also every minute or so we hear a...
If it's American, the temperature probably reads as fahrenheit. If so, 20 degrees F is 12 degrees F below freezing which converts to only -6.67 degrees Celsius.
Domestic freezers should be set to -17 degrees Celsius (= 0 degrees F), so the beeper is warning you that the freezer compartment is far too warm. If it's working correctly and has the temperature control set correctly, then it should achieve the correct temperature if you leave it for 24 hours and do not open the door nor try to use the ice dispenser. If the freezer is full of unfrozen items and so has to cool those down as well, then it may take even longer to reach the correct operating temperature.
Te operating manual for your appliance will tell you how to set the temperature correctly and whether it's possible to select between fahrenheit and Celsius scales. Most models allow you to set an override on the beep alarm as well. I cannot guide you on this without knowing the exact Samsung model.
Please take a moment to rate my reply.
Sep 22, 2010 | Microwave Ovens
Batteries die fast on my mobility scooter.
Hi. What size batteries you buy will be limited to the amount of room you have in the machine.
17 amp hour batteries are really a bit small for any mobility equipement. A lot of power chairs have 35 or 40 amp/hour batteries.
Buy the biggest that will fit into the available space.
Batteries are designed to perform a certain number of "charge cycles". If you run your batteries down by 75%, you will only get a small number of "charge cycles". If you only use 25% of the batteries capacity, you will get 100's of "charge cycles".
The best I have seen is 7 years out of a set of batteries. Short trips and recharging after each trip is the reason.
Good luck. Neil.
Jun 03, 2010 | Electric Mobility Pacesaver Electric...
Sanyo Frost Free Fridge (Model SR 1031) very slow to cycle through freeze to defrost back to freeze cycle. The temp in Freezer compartment goes from -17 degrees to -1 degree then back to -17 as it takes in...
DO NOT TRY TO MODIFY TIMING CYCLE.you would need to completely modify printed circuit board and inbuilt computer......some freezers cycle around 6 to 8 hours.the temperature can only be checked say every 12 hours to get an average reading
Feb 10, 2010 | Freezers
What component failed in my 17"CRT 753s model samsung moniter?
Your vertical deflector circuit is going out. This is really not economical to repair, the chip alone is $12-15 plus if you have any other parts in the circuit going out plus labor. You can pickup 17" CRT monitors for less than $15 from goodwill or craigslist.
Sorry to say but I think its time to retire your 753s
Buddy
Corporate Computer
Jul 14, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Heating & Cooling Logo
85 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
