Question about Mitsubishi WD-62528 62 in. LCD Television
Mitsubishi 65" DLP HDTV, Status light is red, no picture
I have a Mitsubishi 65" DLP HDTV, yesterday I turned the TV off by using the button on the panel, 5 mins later i went to turn it on and it did, but no picture. But yet there was audio, then the status LED light went red. How to fix it??????????
  • karenbingham Apr 19, 2009
    I have same TV w/ red status light and no [pic
    Sniper:
  • 53 Answers
Check your lamp; it may have blown. Sound, no picture and a red light are classis signs a lamp has failed.
Posted on Aug 01, 2009
  • coffeeadd181
    coffeeadd181 Jan 26, 2013
    This is NOT correct. I have a 63" DLP and it has two separate lights. One is for the lamp and the other is for the television itself. I just replaced the lamp in mine last year (260.00 from Mitsubishi). Prior to the lamp going out the picture became darker and darker over time...the lamp light was green, then as the lamp began failing it turned amber and then finally red once the lamp was out...after I replaced the lamp, everything worked fine.
  • Randy N RhondaCarol Malone
    I'm quite familiar with the lamp issue as I have replaced the light bulb 3 times. This has a new bulb and the light is red not amber. There is sound but no picture and the indicater light is red. Its never done that before.
Tv will power on not picture
I would have the power supply checked for the screen and then have the power button checked it may be faulty.
Sep 20, 2017 | Panasonic WD65638 Mitsubishi WD65638 65""...
Has solid red status button, no sound or picture
check cables in the back properly hooked - audio to audio and video to video. colour code may help.
Nov 06, 2013 | Mitsubishi WD-65638 65" DLP HDTV
TV turned off by itself one day. I pressed reset, timer light blinked green for a minute, then I pressed power and it sounded like it wanted to boot up, but nothing happened and the status light turn
Two thoughts:
First is this is a DLP set and the lamp may have failed
Second is it should have the self check which reads error codes---most of these sets that is the same:
" After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
(then release both)
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
This is for a earlier Mitsubishi DLP but should be the same as your set as Mitsubishi rarely changes things like this.
If you get the lamp abnormal it is likely your problem.
Dec 06, 2012 | Mitsubishi WD-Y65 65" HDTV
Our 65 inch mitsubishi tv will turn off on its own and the light flashes red. What does this mean?
You have a defective Main PC board. Part number is 934C328001. Out of warranty cost should be around $340
Mar 21, 2011 | Mitsubishi WD-65C9 65" DLP HDTV
No picture, siren type noise as restarting
My Toshiba dlp 62hm116 was used for 3 months then stored for 2 years, I turned it on yesterday and it makes a loud grinding noise which I think is probably from the exhaust fan area and the picture is black except white at both vertical sides. It worked fine the last time I used it 2 years ago. Any ideas?
Jan 13, 2010 | Toshiba 62HM95 62" DLP HDTV
Red lamp light on Mitsubishi DLP 65" WD-C657
Lamp is always First to go unless power surge gets it Call Mats for Lamp 1-800-628-1118 or Find one on E-Bay got mine there for 85.00 free shipping.
Sep 21, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Status light stays on
I have a 52inch mitsubishi dlp model ws-52725,I turn on the tv and the green light is plinking I have this befor and had to replace the module at a coat of 600.00 that was 2 years ago .I have done all the necessary steps,light still plinking.what do I have to do now ?My last mitsubishi I had for 15 years with no problem.Its mitsubishi going down hill. Thank you PS there any help any where ?
l#wd52725
Nov 22, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi WD-62528 62 in. LCD Television Logo
3,946 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
