Need to scrub hard drive
I have an older HP pentium 2 computer, it runs on windows 98. it has an aftermarket western digital hard drive. when i got this computer it wouldn't boot up and still won't. i got a little more info on this computer and in the past it has had some viruses and in my mind the best way to deal with this situation is to scrub the drive and re-install windows 98 to start from scratch. but my problem is that it won't boot up so i have no way to scrub the drive. what should i do?
  • Mr-Sticky
    Mr-Sticky May 11, 2010
    if you could somehow "scrub" the HD, how were you planning on installing windows on a dead machine?
  • 3,940 Answers
Download CDENAB.exe from support.dell.com (it creates a bootable floppy diskette) then boot to the floppy, and run the debug script listed here:
From the A:\> prompt, type the following commands and press the <Enter> key after each command:
NOTICE: Performing the following will remove all data from your hard disk drive.
NOTE: Type the bolded text only (the debug prompt is a dash). You will receive an error if you type anything other than the bold text. The non-bolded text represents the system response that will appear after typing each command and press the <Enter> key.
debug
-F 200 L1000 0
-A CS:100
xxxx:0100 MOV AX,301
xxxx:0103 MOV BX,200
xxxx:0106 MOV CX,1
xxxx:0109 MOV DX,80
NOTE: Type 80 for the Main hard drive - HD 0, or type 81 for the Second hard drive - HD 1.
xxxx:010C INT 13
xxxx:010E INT 20
xxxx:0110 (Leave this line blank and press the <Enter> key)
-G
The message, Program terminated normally, appears. Turn off the computer by pressing the power button.
On the next startup the hard drive must be partitioned and formatted.
Posted on Feb 02, 2009
Windows sueface rt pro, does not support the wd unlocking tool
Supported Operating Systems
  • Windows 98 SE
  • Windows ME
  • Windows 2000
  • Windows XP
  • Mac OS X
ONLY Windows Operating systems supported by Western Digital software. You could attempt running the setup.exe in "compatibility mode" this may resolve the issue. You could also go back to a older computer, remove the lock, and use a different software to encrypt the device. Such as "TrueCrypt"
how to encrypt a drive once you have it installed: http://www.truecrypt.org/docs/tutorial
Or buy a NEW Western Digitial Drive that DOES support Windows 8.
Benefits to new drive:
Faster transfer speeds up to 15xCompatibilty with new devices.New FeaturesLarger capacity.
Oct 21, 2013 | Western Digital My Book Essential Edition...
Dear Sirs, I need the Windows 98 Driver for Western Digital USB External HardDisk 320 GB ? I use COMPAQ Presario with Windows XP to hook up the External Harddisk right know. The External...
Sory to report - from Western Digital support site
Uses SES Drivers
7, Vista, XP
Not Supported
Server 2008, Server 2003, 2000 Server, 2000, ME, 98SE, 98, 95
Win 98 is not a supported OS, for that drive.
Jan 27, 2011 | Western Digital My Passport Essential...
Computer won't recognize external hard drive anymore
Have you tried changing the USB cable or connecting it to a different USB port on the computer?
Nov 14, 2017 | Western Digital 320GB MyBook External USB...
Western Digital 1 TB External Hard Drive and BSOD
perhaps the new hard drive is bad western digital software is junk take it back and get seagate external w/freeagent on it
Dec 31, 2009 | Western Digital My Book Essential Edition...
My Western digital divice is mulfunctined as displayed on screen
do you use windows 98? because win 98 cannot support wd 160.
2) the mother board bios may not support this drive, or the interphase of the ext usb drive is faulty. lastly try to remove the raw drive from the casing and use it directly with the pc . i feel it will start working well
Sep 18, 2009 | Western Digital Passport WDXML800UE...
The external is on but my computer say unknown device so cant use it and most of my data are in there. Even if i keep it cd to install does nothing but give instruction which doesnt help me at all.
What Operating System is on your computer? Windows 98 and Windows 2000 sometimes will need the drivers for the external USB drive. Check with the drive's manufacturer to see if drivers are available for your Operating System. I know the Western Digital Passport will not work with Windows 98 and Western Digital has no intentions of writing drivers for the Operating System.
Jul 28, 2009 | Computers & Internet
I have a emachines and i want to install a new hard
windows 98 uses the FAT 32 file system and will only read up to 127GB. You could format the drive and divide it into smaller sections and windows should be able to read it fine. Either 2 sections of 80GB each, or multiple smaller sections.
-Download and use the updated FDISK.EXE utility program from Microsoft.
-Keep your partiton size for the Primary partiton that is to be used for drive C: to 127GB or less.
-Use the Windows 98 FORMAT.COM utility program. Note that while the prgram is running it will display an incorrect size for your partition. After it has finished, the summary screen will show the correct size that was formatted.
Formatting large hard drives is extremely slow. If you have a disk setup utility that came with your new hard drive, use it instead of FORMAT.COM. This can save you HOURS of waiting.
Dec 31, 2008 | Western Digital WD1600AB 160 GB EIDE Hard...
HP Computers using XP will not show drive to which Western Digital 320GB external harddrive is connected
Your usb device could be finished or your USB ports may not be strong enough/ enough power to run the device.
Jan 13, 2008 | Western Digital 320GB MyBook External USB...
Win98se i did it ... HERE'S HOW
OK, I bought this Western Digital MyBook 500 GB Essential Edition too, and could not get it to work with Windows 98 SE.
I followed the above instructions, but my version of windows was missing even the drivers suggested above! UGH!
HOWEVER, I found ANOTHER SOLUTION. I installed USB 2.0 drivers for mass storage and the the MY BOOK icon popped up on my Windows 98 SE machine. Hurray! Hurray! Hurray!
Here are the drivers from this british webpage:
http://www.technical-assistance.co.uk/kb/win98se-usb-mass-storage-drivers.php
Good luck to all you frustrated folks scooping your info off Windows 98 machines!
Dec 29, 2007 | Western Digital My Book Essential Edition...
Computers & Internet Logo
278 people viewed this question
David Payne
David Payne
