Question about Dell 1600n All-In-One Laser Printer
Dell 1600n Scanner bulb doesn't light up
I have a Dell 1600n - the scanner light bulb does not come on. The carriage moves like it is scanning something - but the paper comes out blank. Is there a way to fix this? I do not want to junk the scanner.
  • lctrojacek Feb 18, 2009
    1600n....prints ok, copies ok....won't scan. Goes thru the motion but bulb does not light and only shows that I scanned a blank page. I assume because the light does not come on it does not read the text.
    Problem Solver:
  • 6 Answers
Don't panicked about this issue because this is a minor fault. You can take complete solution to fix that issue by dial dell customer service number +1-855-676-2448 (USA, Canada). Expert will help you at the end so don't be late to contact dell technicians. For more info visit website: Dell Customer Service Number 1 855 676 2448
Posted on Jan 03, 2018
  • 49 Answers
Scanners, when broken, are irreparable. (or at least thats what I was told when I worked for Dell)
Posted on Feb 27, 2009
All functions work on my 1600n printer with the exception of the scanner. The workstation names that normally appear when a doc is scanned do not appear
The Dell 1600n requires that the Dell Network Scan Manager is running. Windows Vista and Windows 7 require user level authorization for this app to run properly and may be prompting you at start up. If you are telling it "no" when propmted then this is one thing that can be hanging you up. It is also possible the app is simply not running at all. Go to start>programs>Dell>Network Scan and see if it picks it up then. This app is how the dell printer itself gets the names to put in the list of available workstations to scan to.
Jul 26, 2011 | Dell 1600n All-In-One Laser Printer
I have a dell 1600n printer. Though it prints but the copier is not functioning. The copier light does not come up. It brings a command, "Unlock scanner, then press cancel"
1) Remove the label completely from the scanner module by gently pulling it. The scan unlock switch automatically moves FORWARD to the unlock position.
2) NOTE: When you are moving the multi-function printer or do not intend to use it for a long period of time, move the switch BACKWARD to the lock position. To scan or copy a document, the switch must be unlocked.
Please see page 4 of the owners manual for more details. Here's a link in case you've lost yours:
http://support.dell.com/support/edocs/systems/1600n/en/OM/OM_EN_V01.pdf
I hope this response helps you out.
I wish you the very best of luck!
I strive for '4 Thumbs Up'! If I've assisted you, I'd greatly appreciate you taking the time to provide me with a favorable rating. Thanks so much!
Jun 22, 2011 | Dell 1600n All-In-One Laser Printer
My Dell 1600n scanner function does not work properly. When the scan mechanism attemps to move there is a loud gear slipping / grinding sound. The scan mechanism moves only slightly. Is this something I...
sounds like your csanner is locked.up under where paper comes out look for a blue lever and pull towards you to unlock scanner.push in to lock scanner.check with printer off.
Mar 12, 2010 | Dell 1600n All-In-One Laser Printer
How to unlock the scanner on Dell 1600n printer
Read the instruction thouroghly, they will tell you in there.
Nov 13, 2009 | Dell 1600n All-In-One Laser Printer
We cannot get the scan to operate on the hp officejet 4315 all in one printer
When you lift lid to scanner pad, does bulb light up? It should also move slightly as if to prepare for a scan. If these things do not occur, something is definitely wrong with the scanner itself and will require a technician to service.
If bulb does light and carriage moves, then you should try using the buttons on printer control panel and try to use software on computer to try a scan.
If the control panel button works, then it's a software issue. You can try different software like HP Directory or any photo software with input from scanner feature.
If software works, but control panel doesn't, you'll need a technician to fix the panel.
If neither work, we are back to a problem with the physical scanner. That requires a technician to look at it.
Oct 05, 2009 | HP Officejet 4315v All-In-One InkJet...
Dell 1600N Displays Scanner Locked
If the lock mechanism is broken as you say it might be, then it will have to be disassembled to be removed. Unplug it, there is high voltage present to run the scan lamp. Be very careful and deliberate while disassembling, you will have to put it back together, or get someone experienced to do it.
Jun 24, 2009 | Dell 1600n All-In-One Laser Printer
Scanning Issues
There is a button right above the "Start Scan" button that says "Select Software". Use the arrow buttons (located over the Cancel button) to change how the documents are scanned.
Mar 04, 2008 | Dell 1600n All-In-One Laser Printer
Dell 1600n All-In-One Laser Printer Logo
271 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
