Question about Xerox WorkCentre C2424DN All-In-One Laser Printer
System Error 07,007.40:36266
System is unresponsive and i have shutdown and turned power back on and still have this same problem. Tried searching the Xerox support and found no luck with error codes.
I stumbled upon this area and hopefully someone here can help me out
    President:
  • 2,072 Answers
That is an issue with what is called the process drive motor assembly.
That is located on the right side on the lower front of the machine.
It is a motor with a gear train attached. Some things that happen is the the gear racks become mis timed. You have 2 locating holes and an arrow that have to align for it to run properly. The motor itself may be bad.
That assembly is responsible for driving the maintenance kit up and down to clean and prepare the drum. So something in the maintenance kit may be binding and or the lift plate for the maintenance kit may be broken or off track. That plate is the black plastic assembly that lifts the maintenance kit.
Posted on Feb 02, 2009
How do I turn off my computer
If all else fails, press and hold the power button til the computer turns off
May 05, 2016 | Computers & Internet
How do i get a warranty replacement phone from lg?
o to there service centre and tell them problem
Jan 12, 2016 | LG Cell Phones
Laptop gos into screen saver mode then screen turns black and you have to shutoff with the power button and turn it back on to use it again tried turn off screen saver with no luck after about 3 min. the...
Unless you have already done so, check the power saver options in the control panel. You may have to tweek the timings to make sure power save options are not cutting in too early.
I don't know which windows operating system you are using but generally you will find the details in the Control Panel.
May 13, 2011 | Computers & Internet
My laptop does not go to sleep when I close it.
Check your laptop's energy savings settings are on. It might be set to go into hybernation after a certain amount of time. Also, have you tried pushing and releasing the power button instead of holding it when it does this? By holding the power button down until it turns off, you are causing a "hard" shutdown, which means it is by-passing all of the normal shutdown operations and can cause an error message to pop up when you boot it back up. Let me know if this helps!
Apr 29, 2010 | Dell Latitude D600 Notebook
How can i reboot my acer laptop
Assuming the normal Start - > Shutdown/Reboot option isn't working...
In general, you can do what's called a "hard reboot" by holding down the power button for more than 6 seconds. This will force your machine to shutdown, and can result in lost data, and is generally something to avoid unless you have to do it because you have an unresponsive system.
Once it has powered down, just hit it one more time as you normally would.
Feb 22, 2010 | Acer Aspire 3100-1405 Notebook
System won't complete the RESTART process
Do a check disk (chkdsk) using either:
1) Go to My Computer > right click on the drive with windows that won't boot > click properties > go to tools tab > click error checking > tick both boxes and click check now > it will say windows needs to restart, allow it too.
OR
2) Boot up using the installation disk... I will need the OS version (XP, Vista etc.) to tell you how to do that.
May 08, 2009 | Soltek SL-K8M800I-RL Motherboard
Read disk error occured during rebooting
The acer recovery software sometimes has it's glitches. The CD might be fine, its just the data that wa written to the disk @ time of recovery creation was corrupt at some point.
If your machine shuts down randomly there can be only 3 possible solutions to this one:
  1. Your battery from your laptop has an issue. Try letting the laptop run on AC power ONLY.
  2. Your CPU is overheating, caused by a broken or unresponsive CPU heat sink fan, which causes your pc to shutdown (will always auto- shutdown at a certain temperature to prevent damage to the CPU. Check if you can feel "air" coming out of your laptop, suppose to be a hatched outlet at the side or at the back or on the top cover.
  3. You have a Virus that is shutting down the pc when it wants to. NO Operating system issue can cause your PC to shutdowb; only a virus can do that.
Summary, check your battery, check if your CPU fan is running, and make a virus scan (if the pc doesnt shut down). Remember to make a backup of your DATA, cause Acer (i dont think they will) don't do backups. Waranty on Acers is usually 3 years, depending on the country. So they should replace and repair, everything.
Apr 17, 2008 | Computers & Internet
Display doesn't turn on, emits short beeps and blinks lights
Sounds like a low power problem, Check the power supply with a good ohm meter set to DC voltage if voltage is less than 14 v. Replace the supply. DWW
Sep 20, 2007 | Samsung SyncMaster 240 T (Silver) 24" LCD...
Xerox WorkCentre C2424DN All-In-One Laser Printer Logo
293 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
