Question about Canon PIXMA MP160 All-In-One InkJet Printer
ERROR 300 my printer is on, and connected to the cpu, If i do the clean cartridge and all other maintenance applications the printer works fine, it won't print word files. and an error 300 pops up it says check cables make sure printer is on. All is properly installed.
My printer is ofline but every thing is connected to pc
Posted on Feb 04, 2009
My Printer prints a Colored Ink. But I type as a black Font Color.Then Black Ink Has full?? pls help me
Hi Carl Montero,
Your issue may be attributed to two possible points of failure. 1.) The Nozzle is clogged, 2.) the ink is already dry inside. You can try to clean the nozzle by doing the following steps. If it does not work, try to replace the cartridge with a new one.
FINE Cartridge Cleaning
1 Press [Menu] repeatedly until appears. 2 Use [ ] or [ ] to select . 3 Press [OK]. 1 Press [Maintenance] repeatedly until appears. 2 Press [Black] or [Color].
FINE Cartridge Deep Cleaning
Note If deep FINE Cartridge cleaning does not improve the print quality, contact a Canon service representative.
Jul 13, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Lexmark X1290. I have been using the black cartridge....its still got ink in it and I am getting a Cartridge Missing Error. I have cleaned the cartridge and still no luck. What else can I do to fix the...
Try to clean the cartridge nozzles using the Lexmark Solution Center on your computer. Launch the application from All Programs > Lexmark 1200 Series Printer > Tools > Lexmark Solution Center. From the Maintenance tab, select Clean to fix horizontal lines. Your printer will then print a page forcing ink through the cartridge nozzles and clean them. Once done, try to print again and check if black is printing properly now. If that doesn't help, try to insert a different known working black cartridge to determine if the other is fautly.
Jun 15, 2011 | Lexmark X5150 All-In-One InkJet Printer
I have the same problem but mine is with a canon mp190. also says E5 error on lcd and 2,114,0 eror when i try and scan. what can i do
According the Canon the error code means this:
E, 4/ E, 5 The FINE Cartridge cannot be recognized
The FINE Cartridge may not be installed properly, or the Cartridge may not be compatible with this machine. Open the Scanning Unit (Cover), and then make sure that the FINE Cartridges are installed properly and that the installed FINE cartridges are compatible with the machine.
If the error is not resolved, the Print Head may be damaged. Contact your Canon Service representative.
The "fine cartridge" means the black printing cartridge. The black should be installed on the left and the color on the right.
Double check to make sure your cartridges are installed on the correct sides.
After verifying that they are on the appropriate sides, then turn off your printer and unplug it from the power source.
Remove and reinstall the black cartridge.
Plug the printer back in and turn it on. If the error code is still there, press the menu button and scroll using the arrows until you see the "maintenance" area on your printers display. Then press enter or "ok". Continue scrolling until you find the "clean print heads" function and then again press enter or "ok" Follow the instructions and clean the print heads at least two times.
If the cartridge is full and installed correctly, the according to Canon the print heads have trapped old ink in them and this could be cloggin the ink flow. Cleaning the print heads should solve that problem. If you still get the error code after cleaning the print heads a couple times then I suggest contacting Canon for a possible warranty repair.
Nov 25, 2010 | Canon PIXMA MP190 All-In-One InkJet...
Cannot Solve My Ink Cartridge Error!
You should run a "clean printer cartridge". You should be able to access the clean cartridge feature by going to windows control panel...selecting printers...then right clicking on your printer. Select properties...then dig around until you find the maintenence or clean head option.
May 18, 2010 | HP PSC 1315 All-In-One InkJet Printer
Can you clean maintenance cartridge and resume printing on error
Yes you can clean the tray you may have to remove some items to be able to clean the whole tray but if you take rubbing alcohol and a eyeliner applicator you will be able to clean most of it. ok
best regards mike
Aug 03, 2009 | Canon imagePROGRAF W6400 InkJet Printer
I just put in a yellow cartridge. Previously the printer was working just fine. Now it is showing an error code: 10.92.00 So I put the old yellow cartridge back in. The same error code now appears? He
Hi ron0911170:
This is your problem.
alternates with
Open and close
front door.
The cartridges are not engaged,
poor primary transfer bias contacts,
defective high-voltage supply, or
control signal errors.
YY Description:
00 - Black print cartridge
01 - Cyan print cartridge
02 - Magenta print cartridge
03 - Yellow print cartridge
1. Open and close the front door to fully
engage the cartridges.
2. Reseat the print cartridges.
3. Check the printer primary transfer bias
contacts to the transfer unit. Clean if
dirty. If the contracts cannot be
cleaned or they are damaged, replace
the transfer unit.
4. Replace the high-voltage power supply
5. Replace the DC controller PCB.
Hope this helps
May 24, 2009 | HP LaserJet 3600n Printer
Cartridge error
when the printer shows cartridge error that means. 1)the cartridges r either faulty .it can be 1 out of 2 cartridges or may be both the cartridges faulty.if this is the case replace the cartridges. 2)it could also be the case that cartridge is not fitted properly if this the case remove the cartridge and reinsert them properly. 3)it could also happen if there is dirt on the printer and cartridge circuit.if this is the caee remove the cartridges and clean both the printer and cartridge circuit.and then reinsert and check.
Nov 30, 2008 | HP Officejet 5610 All-In-One InkJet...
Dell A960 printing blank pages
I just sprayed windex on bottom of cartridge several times and wiped with paper towel until dark streak of black appeared. Then I dried off cartridge and replaced. It works now. Must have been clogged.
Nov 18, 2008 | Dell A960 All-In-One InkJet Printer
Remove and check color cartridge
I cleaned mine with alcohol and Q-tip and then shook it 25 times to insure that the ink was penetrating the application lines. My hunch is it first got dirty, and then dried up on the exterior prevent additional ink from leaving the cartridge.
May 24, 2008 | HP PSC 1610 All-In-One InkJet Printer
My Lexmark cartridge, over half full and only 3-4 months old, has malfunctioned. The printer reported that the printhead was blocked. A new cartridge works fine, but I have wasted about $20 of cartridge. I...
Did you run the Maintenance feature that is part of the printer's program?
If not, open the Maintenance page and select Head Cleaning. This cleans the head by pushing through a lot of ink thereby dissolving any dried ink that is blocking the heads. Run a Print check to tell if the heads are properly cleaned (this cleaning may need to be repeated a few times before the heads are cleaned properly).
Good luck.
Apr 14, 2008 | Office Equipment & Supplies
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
118 people viewed this question
old marine
old marine
