FixYa.com
Tags:
Nikon SB-28DX TTL Flash
Nikon SB28 and SB28DX Flash
By Mini Me - usenet poster
There is a new Nikon flash, the SB28DX. Nikon tells me the only
difference is the compatibility with the D-1 Digital camera.
Anyone know differently?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 01, 2007
Not Rated (0)
jessie25
jessie25 - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Depends on the camera. On the F3, for example, the flash connects
directly to the analog voltage terminals of the photocell at the bottom of
the F3's mirror box. In effect the flash unit takes over the metering
function. The flash unit decides when it has seen enough light and turns
itself off, without looking for a quench signal from the camera body. I
don't know if the modern Nikon TTL flash units are similar, but it seems
like Nikon offloads at least some of the 3D-Matrix processing to the flash
unit, especially in the area of the monitor preflashes (otherwise you'd be
able to use the most advanced metering modes with any Nikon flash like an
SB-22s, but we already know you can't).
In these cases the flash would need to know about the reflectivity of the
sensor.
Paul
P.S. The greenish tinge on the D1's CCD is likely due to the Bayer-pattern
filter mask over the chip, which is 50% green, 25% red, 25% blue, IIRC.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Kim1
Kim1 - usenet poster
Rating: 0%, 0 votes
The SB28 will not do ttl on the D1. Only the 28DX does ttl on the D1.
Solution #3
Not Rated (0)
Joey2
Joey2 - usenet poster
Rating: 0%, 0 votes
Wally, you need to shop around, especially with the mail order firms. I
paid around $90 less for my SB-28 through a New York mail order firm.
While Ritz is convenient - being a local store - their prices are normally
much higher than competing photo stores.
Bob
Solution #4
Not Rated (0)
Ross
Ross - usenet poster
Rating: 0%, 0 votes
Ans: 80 or so dollars
Solution #5
Not Rated (0)
Cornish
Cornish - usenet poster
Rating: 0%, 0 votes
I have a problem with your explanation.
As I understand TTL flash metering it is the camera and not the flash that is
doing the metering. The camera can then just compensate for the reflectivity
of the CCD. Further the SB-28DX can be used on all film based Nikon cameras
(with an ISO shue). It would have to know if the camera was film based or
digital.
As I see it the difference between the two the SB-28DX can sync at 1/500
(normal sync) where the SB-28 can only sync at 1/250.
Peter
Solution #6
Not Rated (0)
Grant
Grant - usenet poster
Rating: 0%, 0 votes
Very true. The only difference between the two flashes is the ability for the
28DX model to properly meter with the D1. Recall that a TTL flash (like the
SB-28) relies upon literally reading reflectivity off the film while it is
being exposed. While the BACKINGS of various films are quite unique, the
emulsion side is remarkedly quite similar. Thus, a normal TTL flash expects a
very predictible reflection off emulsion. The D1 camera, however, is quite
different,--no emulsion! When you put a D1 on Bulb and spend a little time
looking inside with the lens removed, you see a wholly different thing,--the
CCD imager. That imager has a blue-greenish tinge to it and is clearly
different than any film emulsion you've ever seen. Thus, a convensional SB-28
would misread that reflected imager,--usually toward overexposing. The SB-28DX
has been modeled to expect both film emulsion and/or a CCD imager reflectivity
and adjust accordingly.
hope that helps! I've had both models (currently have the DX) and you won't
essentially see any feature differences. The DX model does have a slightly
different display as i recall for that added capability with the D1.
Dan Lindsay
Can you Help with these Flashes problems?
Flashes
lights out
I was in my tanning bed and it... Answer This...
Shoe moung of sb 28
Hi How did you fix and where do... Answer This...
me wasantha
i have nikon d40 camera bat i... Answer This...
NIKON SB 28 FLASH
When batteries are inserted,... Answer This...
broken locking pin - SB28DX
The flash unit is jammed on my... Answer This...
Repair Service
Find Flashe Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
