Question about Parker Grill
Wont work in a any breeze- flame keeps going out.
This is mounted on a boat - therefore it is useless. Also the gas control valve is very finicky and is difficult to get in exactly teh right position to even get the flame started.
The grill is 6 months old and has never actually worked properly.
I suspect that the regulator is at too low a pressure for the large volume flame tube.
I am also thinking of blocking up some of the vent holes at the bottom of the grill.
I would be grateful for any advice.
I used my Parker for 7 years on a Hunter sailboat. Full time liveaboard, sailing from California to North Carolina via Panama. It works better than any thing from West Marine.
To check the gas flow, just pull it out of the box and listen for the hiss of gas. If it is not a strong flow stick a pin in the orifices. If the flame in the box is not hot make sure that the interior plates are placed correctly. The unit will get cherry red when all is working correctly.
Posted on Jul 31, 2010
Parker actually helped me solve the problem, but indirectly. Be certain that both plate holes are aligned. I had taken mine out to clean and was unaware that it mattered how reinserted. Give it a try.
Posted on Feb 26, 2009
Totai heater wont stay on after lit
Without a pilot flame sensor signal the pilot light will not stay on and the heater won't work. Try Replacing the pilot flame sensor, the pilot flame burns on to it and it connects to the valve. It looks like a wire.
Nov 26, 2017 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
I can"t keep my pilot light going.
I am assuming this is a patio heater. I have extensive experience with gas appliances. The most common problem with pilot light issues is the thermocouple it is a probe that is directly over the flame , it senses the flame and allows gas to flow, if it senses no flame the gas valve closes. Patio heaters are also quite finicky, sometimes a simple adjustment of the thermocouple will do the trick. Also thorough cleaning of the orifice is necessary at least 1 x a year.
Dec 12, 2011 | Pool & Spa
My White Rodgers Gas Valve 37C72U keeps going out. It burns well for ten to twenty minutes and then just shuts off. It lights first press but goes out again after the above time. All flames appear good....
have you replaced the thermocouple connected to the gas valve?if they get bad they will shut off gas flow,and no you cannot adjust the pilot flame size which is controlled by the valve also
Mar 27, 2011 | Water Heaters
Gas valve on dryer won't stay open
That is going to be them coils. The valve assembly has a glowbar, a flame sensor, and a set of coils.
The ignitor and flame sensor must drop out of the circuit in order for the coils to open. The control klixon mounted on the blower housing beside the duct fuse is what controls the heat in the drum. The warmed air passes over the bottom of the bi-metal control and is regulated by that control coming on and off all through the cycle. The flame sensing device has been known to stick and stay open for a long time OR die altogether. The ignitor is like a light bulb, it is either going to work or not )no in between), Yall need to swap out them coils.
More HERE
Mar 01, 2011 | Whirlpool WGD5900S Gas Dryer
My pilot light went out and when I try to relight it, the flame will light when I press down on the red button by the gas control valve. I hold it down for about a minute like the instructions say but when...
Hi you will need to replace the thermocouple. This is the copper tube that screws in to the gas valve and goes back and mounts along side of the pilot. Most will pull straight out. When they go out, the pilot will light when you hold the red button down, but as soon as you release it off it goes. You can but this thermocouple at any hardware store. They come in different lengths, But I would get a 36" one. They will coil up so they wont be in the way. Its better to have a longer one then one that's to short. Make sure the tip is in the flame, or it will do the same thing. It has to get very hot to keep and produce milivolts to keep it on.Please don't forget to rate me on this as I know you will be kind. This will solve your problem for sure.
Sincerely,
Shastalaker7
A/C, Heating Contractor
Sep 10, 2010 | Heating & Cooling
Exhaust fan turns on for a few min, then shuts down. No heat
There is a gas valve that controls the burner and has a flame sensor that keeps it from supplying gas when there's no flame. There's a chance that the unit overheated and caused a heat overload protector to fail, which was a safety feature to keep the unit from becoming dangerous. You may need to replace that overload protector. The pilot light may have just went out, and you'll need to light it again and make sure the gas valve is set to on. The flame sensor may be dirty and thinking the pilot is not on. The flame sensor will be a wire or probe mounted close to the pilot light. The gas valve may have failed and need to be replaced. You probably can't cause a lot of damage by just looking around in there and cleaning the flame sensor, but you're dealing with fire here, and you should leave anything like taking the gas line apart to a professional.
Oct 01, 2009 | Goodman GDS80703ANA Open Flame Mid-Size...
Belling G755 Cooker oven wont stay lit
I'll give this a go! With a cooker like this, you depress and then turn the control knob, press the ignition button and continue to depress the control knob for a few seconds. This is because a device called a thermocouple is heated by the flame and you have to continue to depress the control knob so that sufficient gas flows to heat up the thermocouple. If the thermocouple does not get hot or stay hot then the gas valve is automatically closed - stopping the gas. The thermocouple is a 'flame failure' safety device. If the gas gets cut off then the flame goes out and the thermocouple goes cold switching off the gas valve automatically. However, you are having to try and manually keep the gas going for a good five minutes. I would think that there is either a problem with the thermocouple or the gas control valve! Tony www.birminghamelectricsltd.com
Jun 18, 2009 | Belling Solitaire G755 Gas Kitchen Range
Kenmore gas dryer not heating up
ck/replace the 2 black coils on valve they will sometimes fail after 1st start up slight chance it may be flame sensor mounted on side of burner to ck remove the 2 wires and short together temporaily if flame stays on and reignites ckd vent system first bad flame may cause sensor to shut it off if flame/vent ok replace sensor
Nov 27, 2008 | Dryers
Gas fridge for boat
What you are referring to as the flame failure device and there is a spark? On gas refrigerators there is generally a thermocouple safety device. This thermocouple shuts off the gas if it does not receive heat from the flame to generate the millivolt current to hold the gas safety valve open. If this thermocouple is bad it will allow the flame to be lit but it will go out as soon as you manually release the depressor that opens the valve. Your supply pressure is in range. If you have to much primary air you will get a flame lift of from the burner. To little primary air and you will have a dirty and lazy flame.
Apr 29, 2008 | Refrigerators
Parker Grill Logo
291 people viewed this question
Top Parker Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Parker Grilling Expert? Answer questions, earn points and help others
