My laptop has wirels ess card but in device manager says no wireless adapter what to do
    Genius:
  • 1,102 Answers
In device manager do you see the driver
if you do click and update
or control panel add new
click next then yes for already installed
then automatically detect
if that does'nt detect then go back and choose option select from list
or you can go to recovery and reinstall your drivers and applications
let me know how you do
and don't forget to rate me
Posted on Feb 01, 2009
Compaq presario v2000 wireless card not showing up in device manager
In Device Manager click the tiny arrow beside Network Adapters. This where the wireless card should be listed.
Next, locate the row of small icons just below the View tab at the top of Device Manager window.. Click the icon on the right "Scan for Hardware Changes".
Check again under Network Adapters to see if the wireless card is listed.
Or, check for any yellow exclamation marks in Device Manager list. An item might be named Unknown Device. Double-click it and select Update Driver.
Jul 01, 2014 | Compaq Presario 700 470024-192 Notebook
The wireles is not workink i have to use the wire
Check whether the wireless router is ON or OFF. Check whether the drivers of wireless is installed or not by right click on my computer, go to properties, select hardware tab, select device manager, got to network adapters & check any entry of wireless. If it is installed, then check whether the wireless is turned ON or not in the Laptop. If it is OK, then there may be problem in the signal To confirm, put the cable to LAN port of the Laptop & check.
Jan 14, 2011 | Acer eMachines eM2501162 Netbook
Wireless adapter is off. How do i switch it on again
to turn on the wireless go to device manager from Computer and go to hardware nad you would find it, try uninstall/install for your wireless adaptor and then try going to network places on left you have my network places then for your wireless network icon make right click and disable/enable.
If this also does not work try installing the driver for the wireles connection again.
Dec 29, 2010 | ASUS Computers & Internet
My wireless adapter was not connecting to a WPA network so I downloaded and installed a new driver (from HP's website). Now my broadcom adapter is not functioning and the device manager says it "has a...
Is it an HP laptop? If so that have a known hardware problem that makes this a real pain....give Hp a call and give them an ear full. I had the same problem.
May 05, 2010 | Broadcom 441530-002 - HP Compaq 2500,...
Wireless card reading networks, strong signal, will not connect and I cant figure out why
hello you need to refresh the network card.. this its a programming issue.. I hope you understand me.. 1. Go to my computer and right click. 2. Properties 3. Hardware. 4. Device manager 5. Find network adapters in the list. ( Click the + to see varius) 6. You need to uninstall the wireless card. ( be sure to identify the correct) and finaly 7. go to Action tab in the up and press scan for hardware change. and the wireles come again.. its suppose resolve the problem .. this its the refresh... pls click its my solution was helpful
Dec 31, 2009 | Acer TravelMate 2480 PC Notebook
HOW TO RESET WIRELESS LAN ON GATEWAY 450ROG
if u want to to reset the wireless LAN on your computer i believing ur talking about refreshing the drivers,,{for windows xp}click on start and then right click on my computer,u will see properties,,click on hardware and then device manager..check network adapter and under tat u will c the name of the wireless card,,right click on that name and click uninstall.after tat click on action and then scan for hardware changes,,u will find ur wireles card is back,,tats reset wireless lan on computer,,
best of luck,,keep me posted and giva good rating
May 19, 2009 | Gateway 450ROG Notebook
Cant connect to wireles network . will not find network. not sure if equipprd with wireless adaptor
I don't think it has a wireless adapter as standard, you can check by doing this:
Right click on My Computer and chose Properties.
Click on Hardware and then Device Manager. This lists all the Hardware in your PC.
Next double click on Network Adapters.
If there is a wireless card listed here then you will be be able to connect to a wireless network. If not then you'll have to purchase one from a PC shop.
May 17, 2009 | HP Pavillion s7420n PC Desktop
Has An Acer Travelmate 243LC laptop got a build-in Wireless?
The link below will take you to a page on the Acer Web site that shows the specs for this laptop. According to the specs, this laptop does not come with onboard wireless (if this feature were part of the system, it would be listed in the specs). Also, you can check Device Manager to see if you have a Wireless Adapter listed under Network Adapters. If you don't see any type of Wireless adapter listed then you'll definitely know that your laptop doesn't have it built in.
To access Device Manager:
Right-click My Computer
Click Properties
Click Manage
In the left navigation pane, click Device Manager.
In the larger window, scroll down the list to Network Adapters.
Expand the Network Adapters tree to see the installed adapters.
http://www.acersupport.com/notebook/html/tm243lc_specs.html
However, the specs do show that this laptop has 2 PC Card slots. These slots give you at least a couple of options for connecting to the Internet. You can buy an Air Card that is installed in one of the PC Card slots when you want to use it to access the Internet. My company used to provide Air Cards for laptop users through AT&T. The advantage is that you have an uninterrupted connection to the Internet no matter your location.
You can also buy a WiFi card that fits into a PC Card slot. This card will be your Wireless NIC (adapter) providing you with the means to set up connections to wireless networks. Linksys is a pretty good brand and fairly easy to install and support. After installation and configuration, you can pop the card in your PC Card slot anytime you want to connect to a Wireless network then remove it when it's no longer needed.
I hope this helps you connect wirelessly using your laptop. Please rate this solution and thanks for using Fixya.
Mar 28, 2009 | Acer TravelMate 243LC Notebook
Trying to hook up internet
Hello
Please check whether the Wireles s button is on and there are any yellow marks in the device manager.
Click start and select Run. In the Run box type devgmgmt.msc and press enter. This will open device manager. Then click on + sign next to network adapters and check whether the wireless adapter listed and any yellow marks beside it.
If there is no yellow marks beside the wireless adapter and it is listed in the device manager. Then try to install Wireless drivers and reconfigure wireless network.
Thanks
Regards.
Jun 21, 2008 | HP Compaq Presario V2000 Notebook
How to repair the wireles switch from a hp pv 9000 notebook
Check to see if the wireless adapter has been disabled in the device manager. If it has been turned off there it will stay disabled no matter what you do with the switch.
Best way to get there is by:
  1. Right-click on my computer and select Manage
  2. Select Device Manager on the left hand panel
  3. Select the Network Adapters category on the right panel
  4. Look for your wireless adapter in the list. If it is disabled the right-click and enable.
    If you don't have a wireless card listed then you have a bigger issue and will need to get that repaired.
Feb 21, 2008 | HP Pavilion dv4000 Notebook
Computers & Internet Logo
75 people viewed this question
David Payne
David Payne
