Question about KitchenAid KSM103 Professional 5 Series Stand Mixer
Trying to revive a Model 4C Kitchenaid mixer by Hobart
I inherited a model 4C mixer and it stalls under low load. I would like to look inside, relubricate, and repalce any worn or broken gears and/or bearings. Could you please advise how to open the unit to get access to the gears and bearings? I can open the motor area and have replaced the brushes. I suspect this unit has dried grease and maybe worn bearings. I like to recycle appliances when possible and my wife would be thrilled if this mixer could be brought back to life. Thank you very much for your help!
Al
  • 11,896 Answers
Withthe front bearing being semi-sealed, a liquifying grease would not begood. Also, the upper vertical sleeve bearing is high above thegearing, much higher than the 6qt models. Even Benalene would have ahard time flowing upward to it. So, in both of these places I've packedhigh quality synthetic hi-temp wheel bearing grease. It stays put andwon't flow out. For lower gears and bearings, where they are coveredeven if it flows out and gravity takes over, I use the KA. I would nothave a problem with modern wheel bearing grease in the older units inall places. It will not come out unless grossly overfilled. Theyoriginally had a wheel bearing type grease.
Therear motor bearing takes a light motor oil in a felt washer. Check thebrushes too. There also seems to be a propensity for the governorcontacts to loosen and fall off with age and/or use. This is at theback of the motor. If it does, it will still run, but possibly roughly,but there are 2 pair. If you retrieve it when it does come off, it canbe soldered back in place. The original is just pressed in and thevibration loosens it (it vibrates fast in operation).
Before orafter you do anything, turn it on various speeds and turn it offquickly. If it tends to stop immediately, it could use lubrication. Awell lubed mixer, new or old, will continue to rotate and 'wind down'for several seconds after being turned off. That's the sign of a mixerin good shape.
Ido know that there are almost no resources on this site or the web thatgive detailed information about the internals. I don't think anyone haseven posted about how to take it apart, and I have never seen one ofthose exploded parts drawings around either.
the motor bearings and gears were not designed to be serviced
http://grandrapids.craigslist.org/hsh/945811969.html HERE IS ONE FOR FREE IF YOU NEED ANOTHER ONE FOR PARTS.
Posted on Feb 02, 2009
  • 4,806 Answers
Hi there
Buy a small tub (one pound, I think is the common size) of all-purpose
grease or wheel-bearing grease at a hardware store, Home Depot, Lowes, NAPA,
Car Quest, etc., store. This should cost you about $3.
Get two blade screwdrivers, one medium sized and one a little smaller.
UNPLUG THE MACHINE FROM THE WALL SOCKET. Put the plug in a small
baggie and put a rubber band around it so the baggie doesn't fall off.
Take a small screwdriver and remove the screws holding the name strip
around the machine and the rear cover. Carefully remove the name
strip and set it aside. Remove the rear cover and set it aside.
These are small Phillips screws, but if you don't have a small
Phillips screwdriver (#1), you can get at them with a small blade
screwdriver; since they aren't critical, it doesn't matter if they
aren't gut-busting tight when you reinstall them.
Take the larger blade screwdriver and use it to remove the chromed
ring around the nose of the gear area. Catch the blade on the top of
the ring and rap the screwdriver smartly. The ring will drop off.
Unless it's held by all sorts of food build-up. Then it will give way
grudgingly and reveal stuff you'd forgotten you made.
Flip the machine on its back or side. Look at the shaft that the dough hook and paddle attach to. Notice that there is a pin through the housing and the shaft. This pin attaches the housing to the shaft and prevents them from turning relative to each other. Take a very small steel or brass pin, something like a shish-kabob skewer or the awl on a Swiss Army Knife, hold it against one end of the pin, and rap the skewer or knife with something substantial.. Be very careful not to round over or mushroom the head of the pin. The pin should come free and begin to work its way out. Remove the pin completely.
Wiggle the lower housing a bit and see if it will pull free of the
main housing. Usually they don't. Look at the area where the small
screws are. Take a small screwdriver and pry the housing down from the screws. With a bit of cajoling and a few choice words, the piece will come off. You will be left looking at a set of eccentric gears in one hand and the gear ring still attached to the machine. There will be all sorts of nasty looking and nastier smelling stuff in the housing and on the gears.
Notice that there are two sets of screws exposed.
1. Four larger slot head screws toward the read of the machine and
2. Six smaller slot head screws around the gear area.
Remove all these screws and set them aside.
Being very gentle, break the machine apart so that the lower and upper parts of the body come apart. Be very careful of the gasket that seals the gear head surfaces. Be very careful not to put any strain on the wires that connect the upper and lower portions of the machine body. You now have a look at the inside of the gear works.
On the main body of the machine you will see a large beveled gear set.
This is the main gear. Sticking up from the same area is a smaller
round gear set. This small round gear is the fail-safe that will
strip from time to time. To replace this gear, you need to remove the pin that holds it, remove the old gear, put in the new gear and
replace the pin. I usually replace the pin at the same time, since
the pin can become bent or mushroomed over.
Think of grease as being composed of two components: oil and soap.
The oil is the lubricant and the soap is the carrier. The hard stuff
is the old soap that has been left behind when the oil took a walk.
Clean out all the old grease. As you clean it out, look for pieces of
metal that may have flaked off of gears. If you find any, try to
figure out where they came from. Don't even think of using the
new, "green" brake cleaners; they have water in them and don't work at all. When you get the old grease off and everything is clean and neat, take a close look at the small gear.
It may be worn. If it is, make a note to order two and two pins to go
with them. Also make a note to order two of the gaskets that you were careful not to destroy. If you are feeling flush, order a spare pin for the attachment shaft. You never know.
When you have finished, slather a goodly amount
of grease on and into all gear teeth, on all exposed shafts and
anywhere else you think moving parts might wind up.
Working carefully, reverse the above disassembly procedure and put the machine back together. Wipe everything carefully.
Good luck and thanks for using Fixya!!!!
Posted on Feb 01, 2009
  • 716 Answers
On Each Slider Make Sure That The Clips Are Not Broken Or Put On The Wrong Sides They Have Built In Clips And If Not Locked The Side Will Continue To Fall. The Slide Rails I'm Referring To Are These
  • Michael Fisher
    Michael Fisher Feb 02, 2009
    I apologize This Was The Wrong Post
I have a kitchenaid epicurian 475 w mixer and it stalled while kneading 5 lbs of flour. I saw some smoke coming out of the motor area. I let it cool down and thought it would restart but no luck. I
Maybe Maybe not. There is a computer style speed control board inside the mixer that can get real hot when the mixer is over loaded and the circuit can burn out, $30.-$35.00 dollar part easy fix, or the motor at $90.00 to $100.00 to replace. You can do either fix yourself with the new design. I have only replaced one motor in the Kitchen Aid mixers in all the years I have been fixing them. Only replaced one full motor. Go to kitchenaid,com and download a parts list for your model from the support tab and it will guide you to the part number and the path to follow to fix it. of course if it is under warranty KA will fix. If you are near an authorized repair center you could take it to them the part and labor to fix $165.00 if motor, $80.00 if they have to replace the board. If you are adveterous you can DIY.
Sep 14, 2012 | KitchenAid Food Mixers
Which is the better mixer of these old models: K5A K5-A or K45 SS and what is the difference? KITCHENAID HOBART K5A K5-A 300 WATT MIXER and the KitchenAid Hobart Vintage K45 250 WATT. Thank you
Hello ajlina,
All of these are great home use units, all the attachments are interchangeable between these. The difference between these mixers is the K5 is a 5 quart mixer and the K45 is a 4.5 quart mixer. As I own both of them they are great in the kitchen and have the same durability.
Have any more questions please post to this thread and I will be happy to assist. Thank you for using FixYa.
Dec 09, 2010 | KitchenAid K45SS Classic Stand Mixer
I have a Hobart KitchenAid Mixer Model K45SS and it runs fast on low (Surges speeds up and down)what is causing this problem
Hello Mayfix,
The problem with your mixer is the speed control switch, this switch is located at the back of the unit. It is usually black and has all of the wires coming into it, the Item # 1394070 and cost $27.95 it can be located at RepairClinic.com he is a link
http://www.repairclinic.com/Kitchenaid-Switch-Parts?z=100&gclid=CKSD5NriuKcCFUVqKgodIE2b_g
You will have to adjust after you install you will adjust the two screws at the top of the switch while the machine is running inorder to make sure that you are getting all the speeds. Be careful as there is a possibility of electrical shock if you touch the wronge thing.
Jul 04, 2010 | KitchenAid K45SS Classic Stand Mixer
I recently acquired a KitchenAid/Hobart Model 4C stand mixer for free. It seems to work okay but I?m in need of a flat beater, dough hook and wire whip as it came with only the juicer attachment. Do you...
A number of attachments were available for the 4C, such as a juicer, a meat grinder, etc., all of which ran off the PTO on the front of the housing.  The only beater, however, was the wire one.  No dough hook was ever made.  I have been told that the motor didn't have the necessary power to run a dough hook.
Jul 25, 2009 | KitchenAid Food Mixers
Are attachments for a KitchenAid K5 compatible with the K55?
That would be incorrect. If the attachment is for a hobart kitchenaid mixer then it will fit all models of kitchenaid mixers including the brand new pro series because the attachment port and drive gear has not been changes since 1925 or 6 when it was first introduce by the Hobart company.
Apr 01, 2009 | KitchenAid K5SS Heavy Duty Commercial...
More info re: n50 hobart mixer
Judy. Hobart was sold to Illinois Tool Works (ITW) several years ago. The Kitchenaid product line was sold to Whirlpool Corp. several years ago too.
The new N-50 mixers have a motor that is designed by Hobart, but no longer built by Hobart. Last year Hobart began out-sourcing approx. 12-15% of their componnents to Asia. Their parts catalog does not show anything but metal gears. I suspect the new motors have been built in Asia. Wattage is not the output of the motor, but how much power it takes to run the motor and is no indication of how much power goes into your mixing bowl. The true measure of mixing power is horsepower. The N-50 motors are rated at 1/6 HP. Wattage claims by mixer manufacturers is a complete snowjob, and they all do it. Consumers have no protection as a result of this policy. It is a marketing ploy to make you believe that this indicates output power. Shame on all of them! Most componnents of the new N-50's are still manufactured in the USA.
I see that you've done some homework on Kitchenaid Mixers. I wish I had before I bought mine. Yes, they have a plastic transmission housing, and yes, they fail under strong loads demanded by bread dough and stiff cookie dough mixtures (my HD Professional 450 watts failed 5 months out of warranty, after only 30 uses making bread). Go to the www.consumeraffairs.com website and search for Kitchenaid mixer problems and reviews and brace yourself for a shock.
My mixer failed on Oct. 28th. and I had to fight tooth and nail with Kitchenaid to get them to re-imburse me for the cost of the parts that were destroyed by the housing failure. Here we are in 2009 and I'm still waiting for one more part. Kitchenaid parts take at least a month to arrive (in my experience).
I didn't do the research on mixers until mine failed. Since then I've purchased an older Hobart N-50 (with a motor BUILT by Hobart), and this is what I recommend you do, as it will save you much grief down the road. Mine was manufactured in 1990 and only needed. re-greasing to make it like new.
You can find them often on eBay but will have to buy without trying them. Try to find one that is newer rather than older, as a rebuild will get very expensive. I got mine from a Rest. Equip. Wholesaler and was able to try it out in all gears. The previous post (solution) was correct in saying that you should look for one that has a black knob on the shifter handle, this will be a newer one as opposed to an ancient one with an all metal shift lever and potentially worn out innards. If you find one, take it to Hobart, or a Hobart tech can come to you (check service rate) have the unit cleaned, inspected and re-greased. Sit back and take comfort in the fact that these mixers were built like a tank, and will probably outlast you.
Most of all. Good luck, and happy hunting. ricardok45
Dec 28, 2008 | Hobart N50 Stand Mixer
Hobart N50 / KitchenAid Model G: how do i remove planetary?
you need to remove all the back screws then if it doesnt come tap it with arubber mallet it may be seized on
Nov 19, 2008 | Hobart N50 Stand Mixer
Open Questions:
KitchenAid KSM103 Professional 5 Series Stand Mixer Logo
1,311 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
