Question about Bissell Healthy Home HEPA Bagless Upright Vacuum - Metallic Blue
Bissell Healthy Home 5770 Fails to Turn On and Has No Suction!
I have to kick it or shake it a little bit to make it turn on. Then there is no suction. I cleaned the canister and filter, small black filter and unscrewed the hose and checked it for clogs. I don't know what else to do. Any suggestions?
Thank you!
I have the same problem sometimes...I noticed that the main body sometimes comes apart (the two sections under the turbo brush) and you just have to line them up again. If this is what's happening for you, try that. If they are still lined up, I'm not sure what's going on. Recently my brushes stopped spinning and eventually they just came back on...don't know why, but I'm guessing the contacts inside the vacuum are dirty or some things are coming loose.
Posted on Feb 07, 2009
Bissell 5770 Brush Issues
Hi their... By touching accidently the screw driver ok circuit board that may be caused of a short of any kind fues on the board or small resistant... Please contact to electronic technician to repair it rather than purchasing new board... Thank you
Oct 24, 2017 | Bissell 5770 Healthy Home Bagless Upright...
What kind of belt do I need to fix my vacuum?
Healthy Home Bagless upright vacuum cleaner replacement belt. Genuine Bissell part number 203-1329 or 2031329. Fits All Bissell Healthy Home, and Heavy Duty models including; 5770, 5770-5, 5770-8, 5770-P, 5990, 6100, 6405, 50C9. Belt contains the following code MS 3M-243-12 written on the outside.
Feb 16, 2011 | Bissell Upright Vacuum - The Pet Hair...
No suction
There is a jam in the dirt path. Remove the beater ... disconnect the hose ... push a broom stick through the hose ... try to draw suction both ways through the hose with a second vacuum until you dislodge the obstruction.
Jul 10, 2010 | Bissell 5770 Healthy Home Bagless Upright...
Brush won't turn.
Is the grey "brush" button on the handle depressed? Brush won't turn unless the button is down
Feb 03, 2010 | Bissell 5770 Healthy Home Bagless Upright...
The motor for brush won't turn on for the bissell healthy home vacum
Jan 01, 2010 | Bissell 5770 Healthy Home Bagless Upright...
How do you change the belt on a bissell 5770
The Bissell 5770/Healthy Home vacuum is actually fairly easy to change the belt on. The main thing you will need is a T20 screwdriver with at least a 4 inch shaft and a Phillips-head screwdriver. Four of the six T20 screws on the bottom plate are easy to locate, the last two are set deeper into the vacuum near the wheels. Once you have taken all six T20 screws out you will have to release the lock preventing the vacuum from tilting back so you can easily remove the top plate and gain access to the brush assembly. With the top plate off you will notice four Phillips-head screws holding a cover plate over the brush, simply remove them and you have full access to the belt.
Dec 07, 2009 | Bissell 5770 Healthy Home Bagless Upright...
Bissell Healthy Home Vacuum No Power - Reset Thermal Protector?
Try to re-install the handle. On occasion if the handle is not installed properly and secured tightly the unit may experience intermittent power.
Mar 29, 2009 | Bissell 5770 Healthy Home Bagless Upright...
Bissell Healthy Home HEPA Bagless Upright Vacuum - Metallic Blue Logo
218 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
