Question about Canon PowerShot A95 Digital Camera
Camera is frozen up
I took out my memory card without shutting off the camera and now the lens in open and the camera refuses to do anything.
  • Canon Master
  • 4,738 Answers
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try. Note in your case, the second listed fix might actually jog it back into operation:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 10, 2009
My son took the camera from my handbag and dont know what he did with it, when i start it first a foggy pic appears and then the screen turns blue showing D 5f08 and 5e02.and the lens also shuts in
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success
Jan 20, 2011 | Olympus Stylus 710 Digital Camera
I have a Panasonic DMC-FX12 digital camera. Before I left on vacation, I took all the pictures OFF of the camera and recharged the battery. I took only 4 pictures before the error message "Built in...
You copied all your pictures, but they still exist on the memory card. You need to go into the menu and erase the pictures. As far as the lens not coming out, there may be some dirt in the mechanism.
Oct 20, 2010 | Cameras
Camera shuts down when 'zoom lens' is used.
Jun 10, 2010 | Kodak EasyShare C913 Digital Camera
Lens cover does not open and camera shuts off it is a vivi 5385 vivitar digital
Jun 09, 2010 | Vivitar ViviCam 5385 Digital Camera
My camera worked very recently, as I took pictures on a camping trip. However, a few days later after getting back, I've found that it refuses to turn on. If I turn it to either Video or Photo, the light...
Here are the steps for the no power problem: 1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty)
Jan 07, 2010 | Kodak EasyShare CX6200 Digital Camera
Get ERR message when trying to take pictures/troubleshoot no help
Two possible things to check.
First, a bad memory card can easily cause this problem. Try replacing the card.
Secondly, could be a poor connection between camera and lens. Be sure contacts around the rim of lens and lens opening are clean and free of dirt, dust and debri. Do not get anything inside your camera when you remove the lens. Dust is a killer to the sensor in the camera.
Mar 22, 2009 | Nikon D50 Digital Camera
Not turning on and has strange smell
Powershot A640 Could Not Be Powered On, Burnt Smell
My Powershot A640 died during a picture shot, lens remaining open. I thought it may be due to the dead batteries. But after putting new batteries and pushing the on/off button, the on/off indicator blinked once then shut off by itself. After a while, a strange smell came from camera batteries area, and I could feel warm there too. Immediately I took out all the batteries from camera.
When checking the posts here the other day, I tried one solution and got the lens back to close: first took out the memory card from camera, then put the new batteries in; push the on/off button with no memory card. I found the lens retracted a little before camera shut off by itself. I pushed on/off button three times to get the lens fully close. However, the burnt smell came out again. I immediately took out the batteries.
Did I get a short circuit inside? Is there any ways to fix it?
Oct 31, 2008 | Cameras
Lens only open partially
Lens mechanism isn't good to work properly so camera shut down the power. Try to tap the lens/ camera while power up.
If you have a memory card in the camera, take it out before turning the camera on
Jun 24, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
'Lens Error' message, No activation of lens
i have had the same problem too, have you got ALL the equipment still in a box, because if so (if you have had the camera less than a year) u can report to the vivitar contact thing because that's what i had to do write back
Apr 12, 2007 | Vivitar ViviCam 4345 Digital Camera
My camera - frozen?
Charging the batteries was the first move. Charge for at least 14 hours, and never shoot on low batteries. If the battery gives out while you are recording to memory, it can corrupt the storage media. The lens should work normally with a fully charged battery.
Nov 23, 2006 | Nikon Coolpix 4600 Digital Camera
Canon PowerShot A95 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
