Aculaser CX11F won't connect to wireless ADSL Gateway
Was working on Friday now Monday Doesn't.
LynkSys WAG54G ADSL Gateway
    Sergeant:
  • 366 Answers
Use this tip for a fast check list.
Connect to gateway using a Lan cable and be sure you can browse Internet.
Then create a specific SSID and check if you see it on WLan adapter
Then remove security from router and check if you connect,
let me know if you need more help
Posted on Feb 03, 2009
Can I set this up this wireless router if I have cable internet and not DSL?
You CAN do this if you have access to the firmware of the ADSL gateway.
Connect cat5 cable from ethernet port on cable modem to ethernet port 1 on ADSL Gateway. (Must be port 1)
-Connect cat5 cable from computer NIC to other port on ADSL Gateway.
-(You may need to) Start->Run->cmd
ipconfig -release all
ipconfig -renew
Here's the trick...
-Open web browser, go to ADSL Gateway homepage (likely 192.168.0.1)
-Configuration tab, Advanced WAN->WAN
-Change WAN PORT drop down from DSL ATM PORT to ETHERNET PORT 1
-Click Edit button. Change Protocol from PPPoE to ROUTED.
-Radio button for DHCP Client to Enable.
-Click Set button.
-(You may need to) Power cycle both Cable Modem and ADSL Gateway device
Now this was done on a Westell ADSL gateway from verizon, yours may differ and you may need to look up the instructions for your specific gateway.
Aug 08, 2011 | 2wire Wireless-G 802.11g ADSL Gateway
Iam running internet cafe i have a adsl internet connection, I have bought one WAG54G wireless adsl router and 8 port Netgear switch, i have establish 7 connection through the switch connected with router...
The internet is disconnecting that means the problem is with the router. you also said that the router is getting hot.
I think probably you can try to upgrade the firmware of the router.
Or if it is a new router then try to get it replaced from the store.
Click Here for more info about the networking
Oct 07, 2009 | Linksys WAG54G-UK Router
I ve adsl device for wireless sometime it works n sometime i ve to plug in cable because wireless function not works
well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center,click on view status,goto propertiesand double click on internet protocol(tcp/ip) or IPv4.type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jul 10, 2009 | Dell (430-3572) Wireless Adapter
Wireless phone connects and then drops.
I switched to a qwest modem and a lynksys router. Works flawlessly now.
Feb 04, 2009 | Zoom X6 Adsl Wireless Gateway Rohs Router
Dear i can not input my vpi vci 0 / 35 can you help me please
If you have a WRT54G router then there is no option on the setup page where you can configure virtual circuits(VPI/VCI). What you need is a WAG54G(wireless G ADSL gateway) which is a A/DSL modem and router bulit in to one device, there you have an option to setup your virtual circuits manually. Now if your A/DSL modem functions as a gateway, just configure you the settings on the modem instead on the router then just set your Linksys router's internet connection type to Automatic Configuration DHCP and it should be up and running.
Dec 03, 2008 | Linksys Wireless-G WRT54G Router
I am a very untechnical person and I bought a wireless G Router thinking I could connect it very simply and make my wired broadband wireless. Unfortunately the modem I have, which was sent to me by Virgin...
I'm thinking you have the ADSL modem supplied by Virgin with only the telephone line port and an USB port on the back that goes to the computer.
In the case above. You need to buy a wireless router with a USB port connection. Or something like a Linksys WAG54G which is an ADSL and wireless router all-in-one.
Aug 16, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Connecting wireless router to laptop computer
Please confirm that this model is indeed a wirlles Modem/ ADSL Router and not just a Wireless Router without the ADSL/ Modem capability??
Apr 20, 2008 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
David Payne
David Payne
