Question about Frigidaire GLEQ2152ES Electric Dryer
Wire Scraping sound and sparks inside rear dryer drum area.
I purchased a Frigidaire Gallery Series electric Washer/Dryer Combo 4 months ago. The dryer model # is GLEQ2152ES1. When I turn the dryer on, I hear a wire scraping sound coming from the drum. When I look through the glass fron loading door, I can see electrical sparks in the back of the drum. Could this be the electrical heater coil broken or what?
  • Frigidaire Master
  • 8,220 Answers
Probably the rear bearing has failed and caused the drum to rub against the heating element. Hey, is this the guy that said he heard a noise last month? LOL
Posted on Feb 04, 2009
Makes a ticking or clicking noise when dryer is on. How can I fix it? The heat and tumbler still works though.
Hi Lisa, thank you for your post!
Based on the above-listed model number, FEX831CS it shows you have a Frigidaire laundry center. However, you mentioned that it is a gallery series. So do you have a laundry center or a Frigidaire gallery dryer? In order to better address the issue, what is your model number? You can typically locate the serial tag, which lists your model number, on the right or left edge on the inside of the door. How often do you hear the ticking or clicking noise? With this information I can better assist you. Thank you!
Dec 12, 2013 | Frigidaire FEX831CS Top Load Stacked...
I have a frigidaire gleq2152es1 that keeps blowing heating elements, what is the cause?
Are you re-stringing the element? if so you need to make sure you have no gaps in the element.
Jan 02, 2013 | Frigidaire GLEQ2152ES Electric Dryer
I have a Frigidaire Gallery Dryer # GLEQ2152ES1. Bought it used. No probles for several months. Moved to a different location. Dryer works but not heat and shuts off frequently. I replaced the control...
Hello - Since you have previously replaced the control board and confirmed that the high temp sensor is working fine, unit may possibly have a defective sensor, heating element, power supply or a communication problem with the control board. I suggest contacting a professional to move forward accurately. The technician usually warranties their labor just in case something else may turn out to be the root cause of your initial problem.
Oct 20, 2012 | Frigidaire GLEQ2152ES Electric Dryer
Hello, I have just purchased a frigidaire gallery series stackable combo 2004 model glet1142cso after hooking it up i am having problems. It won't fill unless dryer door is open..won't spin out...
Probably an auto tec installed the recepticle on the wall or in the electric pannel. in home electric the black wire and the red wires are hot. In automobiles the black is ground. You should have 240 volts between the two flat connectors on the plug when its pluged into the recepticle.
Dec 20, 2017 | Frigidaire FEX831F Top Load Stacked Washer...
Have a Frigidaire Gallery Series Model GLEQ2152ES1 dryer. It is approximately 2 years old. It has started beeping constantly and the lights on the right are constantly blinking. The only way to get it...
Something might be stuck in the bottom of draining pipe. Must take bottom panel off remove clamps to platic hose . Then stick your fingers and feel for any loose change or torn clothes that pluged it.
Mar 05, 2011 | Frigidaire GLEQ2152ES Electric Dryer
How to disable buzzer from frigidaire gallery series stackable washer/dryer?
Here is a site showing all of the steps to disable both buzzers on the Frigidaire Gallery series stackable washer/dryer.
http://www.scribd.com/doc/34420420/Buzzer-Disconnect-Frigid-a-Ire-Gallery
Nov 19, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
Clothes dryer squeaks when running
Fixing Frigidaire model # FER641FSO, not stacking, but had similar problem. turnsout one of the coils came off. might try that...
Mar 01, 2009 | Frigidaire GLER331A Electric Dryer
Dryer will not run
dryer starts sometimes if you hold in button. frigidaire gallery series model # GLEQ942CSO. serial # XD350164472. flat panel control board.
Mar 31, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
1,286 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
